Results 1 to 8 of 8
    DaFaJa
    Reputation: Corbinworks's Avatar
    DT Swiss XR39 Hubs
    So I trashed my front rim the other day, are the XR39 Hubs that some with the Expert worth building off of, I was thinking 3 cross and Stan's Rims...
    2012 Trek Superfly 100 Carbon /Sid W/C XX / Fox CTD RP / xx1 / xo type2 / Stans Flows
    Tampa FL USA
    DaFaJa
    oh heres some photos..about 4 miles in to the ride and hit a root that turned my wheel and it folded, sending me end over end...
    Tampa FL USA
    Front hubs are simple. Depends on the weight. An $80 midrange hub is about 160g. An ArchEx rim is about $88. I used Dt Supercomp spokes for an ArchEx build It hits roots and rocks a lot. I'd reuse the hub. The Park TM-1 tensioning tool makes it an easy job.
    DaFaJa
    Are they worth reusing or should I just upgrade and start from scratch?
    Tampa FL USA
    If it weighs less than 190g I'd reuse it Upgrades to check on.include better bearings and endcaps for RWS thru-bolt. The weight weenies section is a good place to look for better hub discussions.
    DaFaJa
    Picked up a new WTB SX24, to get me back on the trail & then later that day picked up a set of Bontrager 28-hole FCC alloy front hub, Bontrager Race 32-hole rear hub; Bontrager Mustang Disc 29 rims from a Trek Rig for cheap...
    Tampa FL USA
    Reputation: iamspartacus's Avatar
    May 2012
    Dang, that sucks. I am glad you got a replacement. On Oct 27th, we are having the Ride of the Living Dead at Santos. Bring friends for a fun day. Registration is at OMBA.org.
    Heading to Alafia this weekend for FSC# 4.
