have a 910 on order. considered going frame only to get it built earlier but decided to wait on it and have the fork that was made for it. hoping magura comes out with a 140 or 130 29er fork eventually.
parts i have waiting to go on it:
king hubs on arch ex rims
renthal fat bar/stem
sram x0 cranks with MRP 28t bling ring (dropping front der/shifter)
xtr rear der/shifter
magura mt8 brakes
could not be more psyched about it. could not be more bummed about having to wait ha.
mnt bike laws of physics
magura mt8 brakes
Yea, If I get one I am going for the frame only and putting a Lefty on it.
I am concerned about the rear end stiffness. I have a friend who has the Spark and his rear end is super flexy as well as the one in the shop. It doesn't look like the Genius' rear end is much different than the Spark's.
It is about the only long travel 29er bike available without the stupid "new school" geometry....this and the Tallboy LT.....but I like the Genius numbers better.
Post up your new ride when it gets here
Just curious, what do you consider new school geometry?
Erik
which spark? the ones with the thru rear and the right wheel havent felt flexy to me and im a big kid...
i considered frame up but want that frame/fork/seatpost combo as is until i decide what fork i want to swap to (if any) eventually. im goo goo over the maguras after getting a friends spark off him until my genius comes in.
Erik, By that I mean short and slack. You know, for the lazy young kids who get dropped off at the top of the climbs (no offense to you youngsters).
Weaver, It was the new Spark 29. Maybe you don't notice it but I do....especially in tight technical terrain where stiffness is key to control.
there are a bunch of models of the new spark 29... and what wheels? the wheels probably make as much if not more difference.
Oh, I see why you asked now.
There was flex in the rear wheel but the frame had quite a bit too....more than my Tallboy which I consider to not be very stiff either.
On my TB, I have a Single Speed DT Swiss hub with 2.0/1.8/2.0 spokes. This wheel is very stiff and there is still more play back there that I prefer. It's not bad, but I still feel it in certain situation. You should know that I ride at a very high level and push my bikes very hard.
are you assuming that i dont?
makes a difference on what model spark.. some have carbon rear, others dont. some have thru axle rear, others dont. some have stock wheels, others dont... etc...
im guessing my 142x12 rear axle + carbon + stans arch ex rims oughta be stiff enough once mine is built up.
Ha, no I'm not assuming anything about you.
It was the top of the line ridden by a pro rider so it was full carbon with 142x12.
I can tell the difference between wheel and frame flex which is why I didn't mention that.
Edit: and I should add that he lost yesterday's race by less than a minute on an awesome course. He may have won with a stiffer chassis. For me it makes a big difference - esp. in the rough sections which this course had it's share.
im sorry but this is kinda comical... as if the rear stays were at fault for his loss... if you can narrow it down to that one variable then you are way better of an analyst then this world has ever seen...
It was supposed to be comical
success!
Just put in an order for a 910 Genius. Looks like end of December. I was hoping it was going to be earlier, but in reality it looks like after the New Year.
Erik
Erik
Who said end of dec?
Pumaking u heard anything yet aboit 1st deliveries?
Im gonna have a bunch of badass parts sitting around with no bike to go on!
Scott Genius 910 tricked out as much as I could without getting a divorce
I ended up ordering from Rei. This is from the Scott Rep that they are back ordered until 12-27. I placed my order today.
Erik
We have a tentative supply date just after the 1st of the year.
Depends on the model, but for the most part New Years looks to be the date. However the frameset is supposed to be available in 2 days. One of the guys at my shop has a frame on order so we'll see.
New years for even the preorder batch?
What fork is he putting on it?
Erik
Just heard back and hearing the same... And i put in my order as soon as the specs were available to shops
Yup, even the pre-order batch is supposed to be early december now.
Probably a Fox Talas CTD
Damn...
Is the frame only option one color?
puma do you the true axle to crown measurement of the fork they are putting on the genius 900 models? or do you know the measurement for a fox in 120 or 140 similar to it? trying to figure out if another fork will work.
For a 32 120mm it is 520.8mm
For a 32 130mm it is 530.8mm
For a 34 130mm it is 542.8mm
For a 34 140mm it is 552.8mm
Erik
Erik
why such a difference for the 32 and 34??
interesting to see. a magura 120mm is the same as the fox 32 130mm as i suspected... hmmm
- You may not post replies
- You may not edit your posts
Forum Rules
