    Aluminum Scale 29 max tire size?
    Can anyone tell me the max tire size on a 2011 Scale 29er Comp? I can find various accounts for the carbon but not the alloy version, and I don't have it in my hands yet.
    May 2012
    I'm not sure about max size but 2.35" will fit as that's what I'm running on my comp, hope that helps a bit.
    Thank you so much! I want to order up some Panaracer Rampages in 2.3 front and rear, but it would be nice to know they fit. I'd like a little more cush in the back as this is my first HT in a while.
    May 2012
    NP glad I can help, I actually just measured the distance on the back end (smaller distance between posts than the forks) and found that you could probably even go with a 2.5" tire, if anyone makes one. The distance between the two trailing arms on the back is 2.734", but the bottom arms is
    2.54". Either way good luck and have fun.
