Results 1 to 13 of 13
    2013 vs 2014 910
    ok, so i actually found a 910 in xl but it's a 2013. big pic, not a big deal to me. the biggest difference i can seem to come up with of '13 vs '14 is the rear shock. it's $3600 which from looking all over the freakin' country seems like a pretty darn good deal.
    can anyone give me a reason why i may not want a 2013?
    any help would be greatly appreciated, if it's a good deal i want to snag it asap.
    thank you
    Reputation: brentos's Avatar
    Genius or Spark?
    doh, sorry about that.
    genius
    Reputation: GR1822's Avatar
    to warranty or not to warranty?
    OP never said what year the bike that had the problem is is.
    I have a '13 genius and LOVE IT (930 though)
    day-um.
    that's not real warm and fuzzy.
    thx gr
    Reputation: ktm520's Avatar
    The DT shock is terrible, but that's a good enough deal you could upgrade.
    Other than the shock I believe they are the same. Are both triple cranksets?
    best i can figure out via spec sheets is they are both doubles.
    do you think i could put the fox nude on a '13 frame? the shock that is on the '15?
    You can put any inline 190x51 shock on it. The Fox nude is an improvement but it has the same damper as a CTD Evo. It won't ride as well as a CTD boost valve or better yet a Monarch.
    I have a 2013 910 and don't have an issue with the DT Swiss rear shock, personal preference. Haven't ridden many other shocks to compare it to, but the twin loc gives you good control over it, and the lock out is solid. If I had to upgrade I'd probably go with the DB Inline.
    Feb 2014
    Did they change the CTD-lever on the '14?
    I have a Genius 710 with Fox Nude and must say the shock is not as plush as I had hoped it would be. It certainly feels a bit less than 150mm travel. I love the bike for its climbing ability and it is a great all rounder. The shock on my Spec Enduro, also Fox, feels a lot plusher.
    It is still a superb bike with a great geometry. I'd just not put it in all mountain category.
    Oct 2014
    Is the rear shock the only difference between the 2013 and 2014 Spark? I'm looking at a 2013 Spark 930 at my LBS. They offered to pull the Fox nude off a 2014 Spark 940 and swap it with the DT swiss on the 2013 in my size. Is this compatible? They are asking the same price as the 2014 with the new shock. Any reason to beware on this deal?
    Oct 2012
    2013 vs 2014 910
    I've got a 2013 910 and it is an amazing bike. From enduro to ultra XC I have ridden it. My only complaint is the syncros rims are a bit narrow and maybe not as beefy as you would expect for a longer travel bike. I am now running Stans Flows. This problem is true of all Scott mtn bikes it seems (my bro just bent his rear rim on 2014 Scale 710) so it shouldn't be a difference between the two you are looking at.
  1. 2014 Fuel EX 5 29er vs 2013 or 2014 EX 6
    By TheChefJPratt in forum Trek
    Last Post: 07-23-2014, 11:54 AM
  2. 2013 SL 2 vs. 2014 SL 2
    By ItalianBOS in forum Cannondale
    Last Post: 06-13-2014, 09:33 AM
  3. 2013 f29 2, or 2014 f29 5?
    By fat_tires_are_fun in forum Cannondale
    Last Post: 06-10-2014, 08:35 AM
  4. Replies: 11
    Last Post: 01-28-2014, 09:54 AM
  5. Replies: 3
    Last Post: 05-13-2013, 06:34 PM
