Results 1 to 15 of 15
    Oct 2011
    2012 Scott Scale 29 PRO = 2013 Scott Scale ??
    Guys,
    Is there any info or spec's on the 2013 Scott Scale 29er that is replacing the " PRO " form 2012 ??
    Sharky1528
    Reputation: Heretic Skeptic's Avatar
    Mar 2012
    Should be the Scott Scale 930
    FRAME Scale 29 Carbon , IMP3 / HMF net / Tapered
    HT, PM 160 Disc / Carbon dropout, PFBB92 /
    replacable hanger, SDS shock damping system
    FORK FOX 32 Float 29 Evolution CTD Air, CTD damper
    with 3 modes, tapered steerer , reb. Adj. / 100
    mm travel
    REMOTE SYSTEM Scott LRD suspension technologie, lock - ride /
    platform - descend , activate by Rideloc Remote
    Lever, Lockout - Platform - 100mm
    HEADSET Ritchey Comp Plus Tapered 1.5" - 1 1/8", semi
    integr. OD 50/61mm / ID 44/55mm
    REAR
    DERAILLEUR
    SRAM X9 long cage, 20 Speed
    FRONT
    DERAILLEUR
    SRAM X7 / high clamp / dual pull 34.9mm
    SHIFTERS SRAM X7 Trigger, adjustable clamp,
    BRAKELEVERS Shimano BL-M596 Disc
    BRAKES Shimano BR-M596 Disc, 180/F and 160/R mm
    SM-RT66 IT Rotor
    CRANKSET SRAM S-1000 GXP PF, 38Ax24A T
    BB-SET SRAM GXP PF integrated / shell 41x89.5mm
    HANDLEBAR Syncros FL1.5 Tbar, Alloy 7050 D.B. / T shape Flat
    / 9° / 700mm, Syncros Pro lockon grips
    STEM Syncros FL1.5, 7050 Alloy / oversize 31.8mm,
    1-1/8" / 6° angle
    PEDAL Shimano PD-M520, Clipless pedal
    SEATPOST Syncros FL2.0 / 34.9mm
    SEAT Syncros XR2.0 / CROM rails
    HUB FRONT Syncros XR 2.5 29, made by DT Swiss
    HUB REAR Syncros XR 2.5 29, made by DT Swiss
    CHAIN SRAM PC-1031
    CASSETTE SRAM PG-1050, 11-36 T
    SPOKES DT Swiss Champion Black 1.8mm
    RIMS Syncros / DT Swiss XR 2.5 29, 28H
    TIRES Schwalbe Rocket Ron, 29 x 2.1 / 67EPI Kevlar
    Bead, Performance Serie
    WEIGHT 10.7 kg / 23.57 lbs
    Oct 2011
    Looks like the limited info I can dig up the 2013 Scale 910 or 920 is close to the 2012 Scale " PRO "
    but I haven't seen exact spec's on the 910 or 920 ?? If anyone has that info that would be great..
    Sharky1528
    Scott Scale 910
    Specifications
    FRAME - Scale 29 Carbon , IMP3 / HMF net / Tapered HT, PM 160 Disc / Carbon dropout, PFBB92/replacable hanger, SDS shock damping system
    FORK - FOX 32 Float 29 Factory CTD Air, CTD damper with 3 modes, 15mm QR axle / tapered steerer, reb. Adj. / 100 mm travel
    REMOTE SYSTEM - Scott LRD suspension technologie, lock – ride/platform - descend , activate by Rideloc Remote Lever, Lockout - Platform - 100mm
    HEADSET - Ritchey Pro Tapered 1.5" - 1 1/8", semi integr. OD 50/61mm / ID 44/55mm
    REAR DERAILLEUR - Shimano XT RD-M786 SGS, Shadow PlusType / 20 Speed
    FRONT DERAILLEUR - Shimano XT FD-M786 / 34.9mm
    SHIFTERS - Shimano XT SL-M780, Rapidfire Plus / 2 way release, Ispec clamp
    BRAKE LEVERS - Shimano XT BL-M785 Disc
    BRAKES - Shimano XT BR-M785 Disc, 180/F and 160/R mm SM-RT64 CL Rotor
    CRANKSET - Shimano XT FC-M785, hollowtech 2, 38Ax24A T
    BB-SET - Shimano SM-BB71-41A / shell 41x89.5mm
    HANDLEBAR - Syncros FL1.5 Tbar, Alloy 7050 D.B. / T shape Flat / 9° / 700mm, Syncros Pro lockon grips
    STEM - Syncros FL1.5, 7050 Alloy / oversize 31.8mm, 1-1/8" / 6° angle
    PEDAL - nil
    SEATPOST - Syncros FL1.5 / 34.9mm
    SEAT - Syncros XR1.5 / Titanium rails
    HUB FRONT - Syncros XR 2.0 29 CL / 15mm, made by DT Swiss
    HUB REAR - Syncros XR 2.0 29 CL / RWS, made by DT Swiss
    CHAIN - Shimano CN-HG74
    CASSETTE - Shimano XT CS-M771-10, 11-36 T
    SPOKES - DT Swiss Super Comp black
    RIMS - Syncros / DT Swiss XR 2.0 29, 28H / Tubeless ready
    TIRES - Schwalbe Rocket Ron EVO, 29 x 2.1 / 127EPI Kevlar Bead, Tubeless ready / Pace star compound
    Weight 10.1 kg / 22.25 lbs
    Scott Scale 920
    Specifications
    FRAME - Scale 29 Carbon , IMP3 / HMF net / TaperedHT, PM 160 Disc / Carbon dropout, PFBB92/replacable hanger, SDS shock damping system
    FORK - FOX 32 Float 29 Evolution CTD Air, CTD damper with 3 modes, 15mm QR axle / tapered steerer, reb. Adj. / 100 mm travel
    REMOTE SYSTEM - Scott LRD suspension technologie, lock - ride / platform - descend , activate by Rideloc Remote Lever, Lockout - Platform - 100mm
    HEADSET - Ritchey Comp Plus Tapered 1.5" - 1 1/8", semi-integr. OD 50/61mm / ID 44/55mm
    REAR DERAILLEUR - Shimano XT RD-M786 SGS, Shadow Plus Type / 30 Speed
    FRONT DERAILLEUR = Shimano SLX FC-M671 / 34.9mm
    SHIFTERS - Shimano SLX SL-M670, Rapidfire plus / 2 way release, w/gear indicator
    BRAKE LEVERS - Shimano SLX BL-M676 Disc
    BRAKES - Shimano SLX BR-M676 Disc, 180/F and 160/Rmm SM-RT66 IT Rotor
    CRANKSET - Shimano XT FC-M780, hollowtech 2, 42Ax32Ax24A T
    SEATPOST Syncros FL1.5 / 34.9mm
    HUB FRONT - Syncros XR 2.5 29 CL / 15mm, made by DT Swiss
    HUB REAR - Syncros XR 2.5 29 CL / RWS, made by DT Swiss
    CHAIN - Shimano CN-HG54
    CASSETTE - Shimano CS-HG81-10, 11-36 T
    SPOKES - DT Swiss Champion Black 1.8mm
    RIMS - Syncros / DT Swiss XR 2.5 29, 28H
    WEIGHT - 10.6 kg / 23.35 lbs
    Scale 910 retails for $3850 and the 920, $3300, fyi.
    For the bump to the 910 you get a full XT group and those reportedly sweet M785 brakes. You lose a chainring up front and no pedals on the 910. (Less to chunk I guess.)
    I am looking strong at the 910 but the 920 is no slouch. Just do not want that triple and would have to change it out. Otherwise that group is pretty strong, IMO.
    Oct 2011
    I'm kinda stuck too.. 910 or 920 I have been going back and forth on both!! I first need to get rid of my 2012 Scale Expert
    Sharky1528
    Sep 2012
    my decision
    I'd go 910.
    Far better compnentry and the 2x10 drivetrain to eliminate all those un-needed gears
    Quote Originally Posted by #2hundy View Post
    I'd go 910.
    I would go 1x10, even less uneeded gears!! LOL
    jju
    jju is offline
    I also chose 910, it is a lot better than 920.
    Feb 2006
    SRAM's XX One 11-speed rear derailleur does look amazing.. in a year or 2 we should see this trickle down to decent prices..
    Quote Originally Posted by Brazilian Climber View Post
    Quote Originally Posted by amdmaxx View Post
    Yup, if you got lots of money you can go that way also, i went 1x10 on my 2012 scott scale pro 29, e13 chain guide $100), 36t single chain ring in the front ($60) and 11-36 10 speed cassetet!
    and im hella happy!
    Attached Thumbnails Attached Thumbnails 2012 Scott Scale 29 PRO = 2013 Scott Scale ??-photo.jpg
    looks good. what crank and spider is that?
    Quote Originally Posted by tate6969 View Post
    Thx man, those are the stock arms Sram Carbon S-2210 GXP PF 175mm and MRP Bling ring 36t
Hot Deals
Contests
Latest Mountain Bike Articles
