Results 1 to 14 of 14
    Reputation: Swerny's Avatar
    2010 Scott Scale 29 fork replacement
    Hey guys,
    I'm considering changing my fork to a 15 mm from the standard QR.
    In researching, i came across this article which states a tapered steerer can be used with using the right headset.
    Scott Scale 29 Comp Review - BikeRadar
    While it comes rigged for a straight-gauge steerer, a tapered fork can be used if you fit a larger diameter external bottom cup.
    I could obvously use a fork with a straight steerer, but if the tapered can be used, it should be even stiffer.
    So, my question, has anyone successfully done this, and if so, what parts did you use?
    I also read this thread about not using a King headset:
    WARNING-Do not use a King Headset on the new Sparks!
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6 with Lauf
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    Bike Virgin
    Interesting review. I have a '12 Scale Team which seems to only share the frame and wheels. I can't believe that I've never heard/read that our bikes can be converted to a tapered steerer. You would think that would be a huge selling point. I guess it's not really a tapered tube since it would have to be a 1 1/2" tube converted to a taper. I would also like to go with a 15mm QR hub.
    I am planning on upgrading my fork to a Manitou Tower Pro to accommodate my status as a Clydesdale(255 lbs and dropping). It would be great if I could buy a version of the fork that I could transfer to a new bike down the road.
    Let me know if you find an answer please.
    I wouldn't bother upgrading to the Rockshox xc32 TK that came on my bike, I doubt it's any better than yours. It is heavy, unpredictable and it is leaking after one month. The springs for it are $50 which is almost half the cost of the fork.
    Adam
    Adam, cane creek makes a 44OD to 1.5 tape external cup headset.
    2012 Cane Creek 40 Series 44 Tapered Headset - Competitive Cyclist
    This will raise your stack height but you should be ok. I've done this setup to several customers.
    Bike Virgin
    Thanks Pumaking.
    Could we just buy the bottom?
    Amazon.com: Cane Creek 40-Series Traditional 44 Race Bottom Headset OE: Sports & Outdoors
    Sorry for the hijack Swerny, I just figured it'd be OK since we had the same question about the same bike.
    Adam
    Yes, you can buy the bottom. It was just quicker to post up the one I posted but yes it is offered bottom only.
    Quote Originally Posted by Treebumper View Post
    Thanks Pumaking.
    Adam
    No worries, thanks for the responses and info!
    Mike
    Toronto, Canada
    Bike Virgin
    Does the headset and/or bottom cup come with the bearings?
    Yes as well as the crown race.
    Mike
    Toronto, Canada
    So, has anyone run a 120 MM travel fork on their Scale 29?
    Thinking a lighter version of the Trek Stache.
    I am looking to run a Fox Float 29 120....Kashima/Fit/15QR
    Mike
    Toronto, Canada
    Anyhow, I went so far as to buy a 2012 Fox Float 29 120....Kashima/Fit/15QR fork with plans to run it on my Scale.
    I then decided to sell my bike and bought the actual bike I was impersonating.
    Proud new owner of a Trek Stache 8.
    EDIT: Fox fork is sold
    Mike
    Toronto, Canada
    Dang that sucks, i just changed my fork to 120mm on my Scott Scale 29 and it ROCKs.
    Quote Originally Posted by zephxiii View Post
    I'm sure it does...but I got a good offer for my Scott and a great deal on the Stache.
    Mike
    Toronto, Canada
    Re: 2010 Scott Scale 29 fork replacement
    Quote Originally Posted by Swerny View Post
    :beer: right on, I just wanted to chime in since I had done it and argue against trading a HT for another HT ...but too late.
    But yeah, the 120mm with this particular fork is just...perfect for this frame. I couldn't be happier, and in fact it solved a number of problems for me....only cuz this fork was 10mm A2C shorter than the original.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    '12 Scott Spark 29 Team
    '13 Scott Scale 970
    '11 Scott Speedster S20
    '99 Spec' FSR Comp
    '9x Spec' Hardrock Cromo rigid
