Results 1 to 3 of 3
    May 2013
    140mm Float on a Genius 700
    I have a Genius 700SL and I'm planning on putting a 140mm Fox 32 on it. The stock version comes with a 120-150mm Talas. How will it affect the ride by going with a Float 140 instead of a 150? I'm not planning to use the twin loc.
    Determine the Axle to Crown of both forks then compare. If the A2C is less on the 140mm then you will steepen the head and seat tube angle.
    '12 Scott Spark 29 Team
    '13 Scott Scale 970
    '11 Scott Speedster S20
    '99 Spec' FSR Comp
    '9x Spec' Hardrock Cromo rigid
    May 2013
    Thanks, I decided to try out a 150mm float and see how I like it. I can only assume the 140mm would make the bike feel a little more XC while the 150mm would excel on the downhills.
  1. Replies: 4
    Last Post: 01-28-2015, 12:16 PM
  2. Replies: 10
    Last Post: 06-12-2014, 09:49 AM
  3. Replies: 8
    Last Post: 05-06-2013, 05:37 PM
  4. Best price on Fox 34 Float 140mm?
    By DFYFZX in forum 29er Components
    Last Post: 04-21-2012, 12:55 PM
  5. Fox Float 32R 140mm, should I use 31mm bar?
    By chimpanzee00 in forum Shocks and Suspension
    Last Post: 02-13-2012, 07:26 PM
