XX1 Chainring Size for Bronson
I am fixing to order a Bronson and am trying to decide which chainring to buy for XX1. I am debating between 32 and 30 tooth. I would prefer the 30 tooth ratio wise. Will the bike pedal well with 30 tooth or would I be better with the 32?
From my experience, VPP rides better with a "bigger middle ring". If your legs require you to ride a 30T, that's going to by your solution, but a 32T is going to give a lot more ring options and replacements later down the road. You can also modify your final gear ratio with the cassette range you choose.
The XX1 offers a lot of options in versatility as long as you set it up correctly.
Ibis Ripley LS
Intense Spider 29 C
Cervelo S2
Trek Boone 5 Disc
Spech Tricross Expert
Raleigh RX 1.0
I ride a 30t on my 29er. Unless you have ridiculously steep hills, I would think that the 32t would be a better bet.
Agree, atleast LT2 pedals clearly worse with smaller ring than 32, guess vpp is designed to work as best at 32-38 ring etc.. Maybe 30 is still ~ok but wouldn't compromise if you have 42 on back..
This sorta should go without saying, but it depends on the terrain you ride, what climbing gears you currently use, and whether you are willing to sacrifice some top end for lower gears. With a quick search you can find gear calculators so you can compare gear inches.
Luckily the xx1 rings are not too expensive (relatively), and they are easy to swap. So for example you can run a 32 for most terrain and swap it for a 30 if you're looking at a particularly nasty day.
I know this ones been asleep - but I put a 38 on and it had me running propedal 3 on flat trails to feel like it didn't have an anchor. Huge difference between a 34 and 38.
And when it got steep without the propedal was very obvious by the lactate buildup and bike just sinking into the travel with every pedal stroke that the 38t was past the inflection point - no longer anti squat to any degree.
I'll try a 36 and tell you how it goes. Hopefully it still pedals normal.
 believe in yourself! I believe in you!
How does the sprocket size have an effect on the anti-squat characteristics? I don't get that. Is it a leverage thing?
I have a 30T front sprocket on my Bronson. I could probably climb fine with a 32T as well but I find that I'm never spinning out with a 30T so I might as well keep the granny gear.
I ride in CO. I started with a 32 for a season and switched to 30. Much better for me.
I am the OP. Ran 32t for about a year. Switched to 30t two months ago. 30 is much better IMO, better granny for the long steep grinds. If I ever did a 29er I would go 28t for sure.
I just switched from the stock 34 to a 32. It's a huge improvement more than I expected. But I now wish I had went with a 30. I feel like this gear ratio issue had been the missing component in my riding. Not having a low enough gear was preventing me from making sharp switch back climbs at slow speeds.
I also find that the very fastest I ever go is about 22mph and that still doesn't have me in the highest gear.
I switch between a 28 tooth and 30 tooth depending on the trails I'm riding. I set my chain length very precisely with the 30 tooth (read, tight tolerance on # of links) so as to not have it be too long with the 28. Switching chain rings take a few minutes.
ETA: I'm not a super powerful rider with epic aerobic capacity. I find the 30t is fine for 70% of my rides. 28t comes into play on trails with steep, technical climbs where I must stay seated to keep traction or on my rare trips to locales with long fire road uphill grinds.
I run 30t on my Nomad 650, 28t on my Tallboy LTc.
I started w 32 & 30 respectively, but I appreciate the extra climbing gear for extended Colorado climbs and don't miss that extra gear on the other end at max speed. I prefer to sit and spin v. mash
I have only spun out the 28T front on my XX1 setup on my Bronson once, going all-out down the last sections of Phil's Trail in Bend (below the chicken). Relatively flat trail with mild turns, one-way only.
Most of the time the trails I ride are steeper, and I'm not looking to pedal.
Chain grinding due to wear-and-tear on the front ring is something that others have reported, and I've found as well. I'm going through about 2 rings per chain. There's anecdotal evidence that it's more common on the 28T. My thinking is it's just going to happen with an aluminum ring.
See this thread from the SRAM forum:
XX1 28t chain grinding?
By shackleton47 in forum Singlespeed
Last Post: 11-16-2012, 11:52 AM
By Ninjaboym5 in forum All Mountain
Last Post: 09-20-2012, 09:27 AM
By juan pablo in forum Canfield
Last Post: 07-14-2012, 10:35 AM
By Scarier in forum Downhill - Freeride
Last Post: 07-09-2012, 10:20 PM
By daytona in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 08-04-2011, 10:21 AM
- You may not post replies
- You may not edit your posts
Forum Rules
