Results 1 to 21 of 21
    Would love to get the Solo but...
    Why they heck does Santa Cruz only offer a 2 x 10 build kit in the XTR grouping? SC's prices are ridiculously high enough. Then if you want to get the 2 x 10 setup you have to jump up to the XTR group. I am perfectly happy riding either XT or X9 but want my bike to be 2 x 10. The only XT group they offer on the Solo build kit is 3 x 10. It is a head scratcher. I also think Santa Cruz prices are a little high personally. When you compare SC to Pivot and Ibis you get better deals from both Pivot and Ibis.
    Chuck
    Dec 2010
    Quote Originally Posted by procos View Post
    Chuck
    Coloradocyclist.com. Build it how you like it
    Quote Originally Posted by h20-50 View Post
    I thought of that but usually a factory build kit is a lot cheaper. Usually when you custom build a bike the price get's even more out of hand.
    Dec 2010
    They're a great company. I'm not sure when they will have the Solo in stock but give them a call and explain your price concerns. I'm sure they will be willing to work with you plus normally if you build it with them they discount everything except the frame.
    um... yeah
    It doesn't matter which chainring setup they spec (1, 2 or 3 rings), people will want something else and complain.
    Thanks for the info. I'll give them a call when I am ready to pull the trigger.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    +1 for going custom. Except for their "package bikes" (i.e., the R-AM and SPX-AM kits) SC quite clearly marks the component groups either at or above MSRP, which to be honest is pretty absurd. You'd have to be either A) an idiot, b) lazy or c) super-baller to buy one of their builds.
    SC, I really hope you're reading this . . . .
    Where are you guys seeing the pricing on the kits? Bike builder doesn't show up for me...
    How do you talk SC down on price, you can't buy direct? Or can you?
    Quote Originally Posted by 007 View Post
    Great info thanks.
    Ted
    Ted is offline
    Ted in real life
    Reputation: Ted's Avatar
    +1 for Colorado Cyclist. I built my TallboyC there last year and was/am very happy. The SC build kits were not quite what I wanted.
    Oct 2007
    There is no frame only price for SoloC. If assuming that it will be ~2700$ like most of SC carbon frames, custom build turns up to be more appealing than complete kits. But, as long as they don't sell frames separately, there is no choice.
    Imagine the royal pain in the ass it would be to stock 1X, 2X, and 3X groups at multiple price points. Then multiply that by two manufacturers. Then multiply that by the number of models in your line-up. Friggin' nightmare!
    Also 2X10 doesn't make a lot of sense to me, and there is growing consensus on this. You still need a front derailleur and shifter, but you have a range that is less useful than 3X, and you don't get the middle chainring where lots of people spend much of their rides (and for which many suspension designs are optimized). So, no less complex, only a slight weight savings, and a more limited range.
    Go 3X or all-in with 1X.
    Dec 2005
    Quote Originally Posted by OGRipper View Post
    This is where I've ended up after a few years of experimentation as well. Only exception being when replacing the big ring of a triple with a bash
    here we go again
    Reputation: vikb's Avatar
    I started off with a 3x on my Nomad.
    Dropped the big ring for a bash guard.
    Then realized I wasn't using the granny and that I was climbing tech better than ever since I wasn't spinning the back wheel as much with the higher gear.
    So I dropped the front der, run a single ring with chain guide and haven't looked back.
    My GF is going down the same path on her Nomad and is down to using only the middle ring most of time and finding her techy climbing improving despite not being a uber strong rider. Next bike we'll get her a XX1 type setup with a single ring and uber wide range cassette.
    If I bought a new SC bike I would do a custom build and get what I wanted right off the bat.
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2010
    I built up a 2x XTR at coloradocyclist and love it. It has a middle middle chainring but no granny chainring. I usually stay in the largest chainring up front and rarely have to ever leave that one. It wasn't about weight savings, it was about getting rid of a gear I never use. Who needs 30 friggin gears anyhow, hell out of the 20 that I have I'm only in 7 of them 95% of the time. I agree 1x is optimal but there have been times where I was glad to have a 2x
    Cant agree more. For those of us that hammers uphill on big chainrings in sprints, 2x just doesnt do it. Same for working on intervals. I actially lost a sprint two weeks ago with the 2x10
    So you have a 42 and 32? That is not what you would get with a typical 2X kit anyway. And if you can push a 42 around all day, I don't see why you are not going 1X.
    In any case, to each their own. Personally I don't see any advantage to 2X. If I'm running the additional weight and complexity (such as it is) of multiple rings, I'll take 3, thanks.
    I disagree, though I think it in part has something to do with location. Here in the PNW I can't imagine why I'd ever want 3X, there is simply never an instance that I need to pedal a gear higher than 38x11. 2X10 works great when you run the proper 2X10 specific gears, for example a 26/38 front and a 11-36 cassette (perhaps smaller front rings for a 29er). 3X has so many overlapping and near-duplicate gears; 1X is the most efficient and every additional front ring lowers that efficiency. Also, where I ride, clearance is much more important than top-end speed.
    Quote Originally Posted by LostBoyScout View Post
    I really don't want to belabor this any more, particularly since it's just personal opinion and yes, based on part on where you ride. That said, I don't see the problem with overlapping gears - on the contrary, with a 3X it's nice to be able to stay in one of 3 rings up front and avoid shifting the front der., which happens more often with a 2X.
    Again, to each his/her own. I see the obvious advantages of 1X, and am loving XX1. After trying it for a while on one of my bikes, I just don't see the point of 2X.
    If you're ponying up $6k for a new bike, any decent LBS should be able to swap out a 3x10 with a 2x10 for NO charge. Really not an issue.
    Dec 2010
    I have a 42/30 and yes I can push the 42 around all day on my local trails. It comes down to location and riding style. I like 42 because I stand and ride...everywhere!! I come from BMX so I'm really comfortable standing all the time. My friends think I ride awkward and nuts but when I have to stop and wait for them to catch up it proves my point, and they are not bad riders by any means. My local terrain is decently level besides a couple of quick climbs. Once you know the trails you know what to expect and can prepare for the climbs really quickly by gaining speed. The only time I use 30 is when I'm out of town, say Comfort, or Austin area as they can be really hilly. Plus I don't have every turn memorized so I can't carry speed comfortably as I can on my local trails. I want to go 1x someday but honestly having 2x comes in handy from time to time
  1. Chain Love MTB Love
    By cman8 in forum Where are the Best Deals?
    Last Post: 09-25-2014, 08:39 AM
  2. Songs You Love To Hate, and Hate To Love?
    By petey15 in forum Off Camber (off topic)
    Last Post: 03-18-2013, 09:12 PM
  3. Do you love your Pivot 5.7? Do you love your Turner 5.Spot?
    By nando in forum Bike and Frame discussion
    Last Post: 10-03-2012, 08:23 AM
  4. Is 12 hour solo pacing any differant than 24 hour solo pacing?
    By crimecrusher in forum Endurance XC Racing
    Last Post: 02-21-2012, 09:04 PM
