Results 1 to 8 of 8
    Jun 2005
    Where to get FOX DHX 5.0 Coil?
    Hello,
    Yet another Nomad rider that will give up my DHX Air. As I ride more and more FR/light DH I really need another rear shock.
    I live in Sweden and FOX doesn´t have any working distribution over here. Please let me know if you now an affordable and reliable dealer. I have a shipping adress in the Bay Area that I can use.
    Also what spring rate is recommended for me at 180lbs?
    Hakan
    Reputation: al_bullit's Avatar
    You can order from TFTuned in the UK I think. They deal with Scandinavia quite a lot.
    Reputation: biketavioumaximus's Avatar
    Quote Originally Posted by the Swede
    Hello,
    Hakan
    Don't believe the lambastering........ I'm 180lb, I run about 220 in the main chamber, 150 in the small chamber with about 1 line showing on the bottomot resistor thing???
    Mine rides as good as a coil???but lighter!
    Knolliac
    Reputation: EastBay_Slim's Avatar
    if you can have it shipped to the bay area, try universalcycles in oregon. at check out enter vip15 into the discount code section and get 15% OFF. great deal, very reliable company.
    Jun 2005
    Ancientwidom: Thanks for the advise, I will contact them!
    biketaviomaximus: Tanks for the encouragement. I think my Fox Air is ok for trail-riding but on rougher lift asssisted slopes I really can't make it work properly.
    Old man on a bike
    Quote Originally Posted by biketavioumaximus
    Many many people have discovered on the Nomad the DHX Air just doesn't work as well as the DHX 5 coil....have you tried one?
    OP - SC recommends the 500 lb spring for your mentioned weight (I use the 550 on mine but I weigh 200+ geared up).
    suum quique
    I'm 200lb and DHX Air was fine upto a point , but as soon as you start getting slightly aggresive the mid stoke is gone, coil beats it hands down, pedal stikes with the air 2 or 3 per ride with the coil 2 or 3 per 10 rides, get it Push'd and its even better
    Jun 2005
    Thanks to a forum member I got hold of a DHX coil instead. Tried it out all weekend and it is such an improvement from the DHX Air.
    I´m much more in control in sharp berms and after jump landings.
    Can´t really explain why but the stability "sideways" of the bike also feels much better.
    I´ll try to sell the Air shock one and if impossble keep it as a back up.
