Results 1 to 7 of 7
    Reputation: ciocc's Avatar
    Dec 2005
    New question here. What shock mounting hardware for Blur LT2.3
    Sorry for the newbie question. I'm a bit confused about shock mounting hardware vs reducers. I'm replacing my stock Fox shock on my Blur LT2.3 with a Marzocchi Roco shock. According to SC website, the mounting hardware size is 8mm x 22mm.
    However, should I use:
    1. From SC website: Name:  04-15136_fox_bushing_kit.jpg
    2. 8mm x 22mm mounting hard: Name:  38735.jpg
    3. 8mm x 22mm reducer: Name:  58029_md.jpg
    Which of the above should I use? Thanks for your help.
    Dec 2005
    Found the answer. Thanks.
    Rear Shock Reducer Maintenance
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Coincidentally, you have them numbered in the order of preference.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Reputation: sooner518's Avatar
    i replaced the reducers (#3 on your list) with the polymer bushings (#1) about a month ago. not only did it eliminate the knocking/play in my rear end, I swear the back end feels plusher now. I had to get my LBS to special order the bushings from Fox, (like $17) and then had to have them press the old bushing out of my shock, which they did in 1 minute for free. Really nice, cheap upgrade. super easy to install as well if you can get someone to bush the old bushing out.
    Big Gulps, Alright!
    You can get them direct from Santa Cruz too:
    With 3 piece hardware: https://shop.santacruzbicycles.com/p...-reducers.html
    Just the bushings: https://shop.santacruzbicycles.com/p...-reducers.html
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Curious how the polymer bushings are holding up for you guys. I've got a set going on about a year now and damned if they aren't creaking like mad.
    Dec 2005
  1. 07 Blur Fox rear shock - mounting hardware
    By mtbmesa in forum Santa Cruz
    Last Post: 08-06-2013, 06:45 AM
  2. El Guapo shock mounting hardware
    By meSSican in forum Titus
    Last Post: 01-28-2013, 09:56 PM
  3. Rune V1 shock Mounting Hardware
    By freeriderB in forum Banshee Bikes
    Last Post: 01-28-2013, 08:25 PM
  4. New Fox rear shock mounting hardware
    By jpk1080 in forum Santa Cruz
    Last Post: 11-21-2012, 08:08 PM
  5. Shock Mounting Hardware
    By gticlay in forum Santa Cruz
    Last Post: 02-08-2011, 08:38 PM
