Results 1 to 7 of 7
    What Fox tune does a Nickel need.
    I can get a new fox RP23 200x57mm that has a medium tune. Would a medium tune be right for a Nickel?
    Reputation: ColinL's Avatar
    Feb 2012
    You would be best served to ask Santa Cruz. There are 3 things to be tuned based on your bike, weight and riding conditions:
    velocity tune
    rebound tune
    boost valve pressure (if equipped)
    Fox will also know the right velocity and rebound, at least.
    legal alien
    There's a fourth tuning parameter: the volume spacer. As mentioned, call/email SC and they'll give you the specifics. As an example, here's the OE tune for a Float CTD on the Nomad:
    Velocity: L
    Rebound: L
    Boost: 175 PSI
    Volume spacer: 0.6
    Wēk Ss
    Reputation: IAmHolland's Avatar
    For posterity
    Santa Cruz Nickel RP23 Shock Tune
    Code:
    model         : RP23
    eye-to-eye    : 7.875in
    stroke        : 2in
    spring        : n/a
    air sleeve    : XV 1.88
    hardware      : 22x8 (2pc)
    comp tune     : VTL
    rebound tune  : RTL
    boost         : 175
    volume spacer : 0.4
    Thanks! Someone might be able to use that. I ended going with a RS Monarch RT3 with a 57mm stroke. It's night and day better the the Fox shock.
    You can read more about it here: 200 x 57mm shock on a Nickel = 142mm of travel!
    Reputation: reformed roadie's Avatar
    Quote Originally Posted by Mountain Cycle Shawn View Post
    I am surprised you didn't go for the white air can.
    I have been contemplating the change to a Monarch from an RP23 on my BLT2...not sure if I'd see as big a difference, as I have read that the RP2 is a dog (the only option on the remaining closeouts).
    Quote Originally Posted by reformed roadie View Post
    I tried to get a white one, and Suspension Experts didn't have one and RS didn't have any left. I thought I would look for a used one that is blown and have the parts switched when mine needs to be serviced. That would finish it off perfectly.
