Results 1 to 7 of 7
    May 2010
    TBLTc Upper link seatstay collet axle wear
    Has anyone serviced their TBLT and noticed that the upper link lower axle wears quite quickly. Check out this pic:
    The top axle (seatstay collet axle) in the pic was after approx 6 months average 1 2 hour ride per week. It was a pita to remove and you can see the threads were pretty bad. I had to re-tap the rear triangle female end to clean it out.
    The lower axle in the pic was after approx 2 months.
    The other 3 axles don't wear quite as fast. I suspect since this axle is the near the rear shock mount is probably why it wears the quickest.
    I'm wondering if others are seeing the same wear.
    unpossibles
    Reputation: Josh_SL2's Avatar
    Mar 2012
    I'll try to take a look at mine later today, but I don't recall seeing that much wear last time I cleaned/greased my pivots.
    rox
    rox is offline
    thats not a wear part. the axle tension/preload was set too loose.
    May 2010
    Quote Originally Posted by rox View Post
    The top one was from the factory. The bottom was one that I installed. I checked the one I have in now and it is showing wear similar to the lower and I torqued the axle and bolt to SC specs. I guess the lesson here is to check the torques from the factory.
    Got A Lust for Life...
    Reputation: indyfab25's Avatar
    Every VPP bike I owned had that wear on that bolt.
    Sent from my SCH-R530U using Tapatalk
    I am immune to your disdain.
    Mine had some wear there as well.
    Aug 2014
    Quote Originally Posted by dkestar View Post
    Hi dkestar,
    I have exactly the same problem on my Bronson. I called the SC dist. and soon they will actually have a "special tool" to re-tap the female thread in the seat stay, but I would have thought it was just a normal tap of diameter x thread pitch x?
    I have always torqued this to the point where the play is removed from the pivot, so I was surprised when this happened. Do you mind sharing the specs of the thread tap that you used i.e. thread pitch, diameter?
  1. TBLTc Upper link seatstay collet axle seized
    By dkestar in forum Santa Cruz
    Last Post: 12-01-2013, 09:18 AM
  2. Replies: 12
    Last Post: 11-26-2012, 04:59 PM
  3. squeaky upper link on SS2
    By wonny in forum Intense
    Last Post: 06-19-2012, 10:53 PM
  4. Stripped axle bolt upper link
    By mcandy in forum Santa Cruz
    Last Post: 04-06-2012, 08:51 PM
  5. Spider 2 Upper link on XVP?
    By jrsbike in forum Intense
    Last Post: 08-23-2011, 09:30 AM
