Results 1 to 6 of 6
Thread: Tallboy XC
    Jan 2014
    Tallboy XC
    New build on the way can't make my mind up on front forks Fox Talas 90-120mm or Rockshox what have you guys fitted.
    Warrior's Society
    Reputation: mtnbikej's Avatar
    Sep 2001
    As a "not a fan" of adjustable travel forks.....I say go with something 120mm. Low bottom bracket means lots of pedal strikes, even at 120mm. Going 90/100mm is just too short.
    The bike will still climb really well at 120. If is really really steep, you might need to add a bit of body english into it...but it really brings the bike alive on the downs.
    Personally, I am a RS fan....so I would look at Revelation/SID/Pike...they are all available in 120mm.
    I crashed hard enough on my Tallboy to break my leg,
    The carbon is way more durable than most people.
    Rockshox Revelation 120mm is the perfect choice for a Tallboy.
    And it's a front fork (no "s"). Last I checked, there's only one up there.
    I've got a 120 pike on mine that has exceeded my expectations thus far. Highly recommended.
    I got a 140 mm Float 32 CTK Kashima on the way... will try it as so with a little bit sag (30%) will try it in this configuration... can't wait for it to arrive in the mail... =)
    Currently in Exile
    Reputation: Frozenspokes's Avatar
    I'm running a 120 mm Rockshox Reba. Works great and the bike is still very nimble. I have yet to hit any steep climbs with it as it's quite flat where I live so I won't comment on climbing.
  1. Replies: 5
    Last Post: 04-13-2015, 05:46 AM
  2. 2013 Tallboy carbon or 2014 Tallboy aluminum?
    By davidfrMi in forum 29er Bikes
    Last Post: 02-22-2014, 09:40 AM
  3. Question for Tallboy or Tallboy LT owners
    By rdb in forum Massachusetts
    Last Post: 10-30-2012, 09:12 AM
  4. Tallboy al vs Tallboy Carbon vs Jet9 vs epic comp
    By SaxMan2001 in forum 29er Bikes
    Last Post: 08-14-2012, 08:41 PM
  5. Upgrade my Tallboy or switch to a Tallboy LT?
    By Jarlaxle in forum Santa Cruz
    Last Post: 06-29-2012, 07:20 AM
