Results 1 to 12 of 12
    NedwannaB
    Reputation: JMac47's Avatar
    TallBoy shock choice
    Looking into the Alum model frameset. Anyone have some input on these set up with both an RP2 vs a Float CTD? Interested in VPP design and wondering if there is a big difference or not in ride quality.
    Thanks in advance.
    Wait whuuut, who did he tell you that!?!?....
    NedwannaB
    Anyone have input on what the issues the CTD has might be?
    some know me as mongo
    I just ordered mine with the ctd, I figure if it doesn't work out the rear shock is not all the expensive to replace. The only thing that I have heard bad about the ctd is that it can blow through its travel
    NedwannaB
    Aluminum frame?
    Quote Originally Posted by sir_crackien View Post
    I'm looking into one of the sale 135 dropout frames. Yeah that's what I heard from another. I'm 140# so hopefully won't be an issue. And same thoughts on it can always be sent to PUSH or? and be dialed in better.
    Yeah I bought the clearance frame with the ctd shock. You can always send it to push or buy a different shock all together. I have heard that many people really like the monarch on the tallboy.
    NMBP
    Reputation: gfs69's Avatar
    I really like the CTD shock on my Tallboy C so far. I have the Kashima version with trail adjust, and find that using the Trail 1 setting is pretty good for me. It works ok in open mode as well, just not quite as "snappy".
    NedwannaB
    Quote Originally Posted by gfs69 View Post
    Thanks all. Corresponding with SC now. Not sure the sale alum frames have "trail adjust" but assuming all the CTD's were Kashima coated.
    Reputation: d365's Avatar
    Quote Originally Posted by JMac47 View Post
    I believe the coating is extra $.
    NedwannaB
    Quote Originally Posted by d365 View Post
    Yeah, no doubt $$. Now that I look at close up of frame it's not Kashima, but ad disclaimer says pic may not depict exact shock coming with frame and to follow description. I thought CTD shocks came out after they started to do the Kashima. No problem for me if not coated anyway.
    JMac47, the CTD is not kashima coated and it does not have the trail adjust feature either. Its an OEM spec shock for Santacruz.
    Thing Maker
    Apr 2013
    I run the OEM spec CTD Float on my tallboyC, and its pretty on point. I recommend dialing in the sag just under factory settings in the D mode, like 20-25%, and in trail you'll be fine. Set it and forget it.
    The Boombot REX, ultraportable speaker/speakerphone/siri assistant. With the ability to deny phone calls on the trail Huzzah!
    NedwannaB
    Quote Originally Posted by Chris McKleroy View Post
    Thanks for info.
  1. New Slayer Shock Choice
    By abbike18 in forum Rocky Mountain
    Last Post: 06-10-2017, 03:13 PM
  2. Delirium air shock choice
    By juan pablo in forum Knolly
    Last Post: 04-08-2012, 05:20 AM
  3. Endo Shock hierarchy \ choice
    By erringtonnc in forum Knolly
    Last Post: 05-06-2011, 05:42 PM
  4. Shock choice on the Uzzi VP
    By TejasMTB in forum Intense
    Last Post: 01-31-2011, 09:52 AM
  5. Helius AM - Shock Choice ?
    By The_Lecht_Rocks in forum Nicolai
    Last Post: 01-19-2011, 11:42 AM
