Does anyone know if there is a difference in the trail measurement on the TLc between the Fox 34 & the RS Revelation RCT3 DA dual air (2013)? Both were options when I recently bought my TLc.
From what I can tell, the Fox has a 51 mm offset and 552.8 mm axle-crown measurement.
The RS (the Solo version which I assume is the same as the dual) has a 46 mm offset/rake, and I think the axle-crown is 548mm.
I'm wondering if the handling would be any different?
