Page 57 of 101 FirstFirst ... 74753545556575859606167 ... LastLast
Results 2,801 to 2,850 of 5015
  1. #2801
    Still working with Santa Cruz to figure out why my tire rubs my seat tube. They want to know my part numbers on my upper and lower links and I can't find them anywhere. Also, my RP23 Boost Valve tune is 225, do other riders with this shock have the same tune?? Thanks for your help!!!
  2. #2802
    Demon Cleaner
    Reputation: Structure's Avatar
    Tallboy LT and LTc Owners Thread
    I saw the write up on Art's blog for Cory's bike. Wish he'd explained the shock choice. Everything else is pretty obvious (IMO since I have it sans carbon wheels), but the shock is novel.
    Bicycling is politics by other means.
  3. #2803
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Quote Originally Posted by Miker J View Post
    Rear drop-out question...
    The non-drive side rear drop is a hub to carbon interface, correct?
    I mean, my frame has no metal insert, or spacer, in that area to buffer the carbon drop from the hub end.
    The drive side has a metal insert connected to the RD hanger.
    While the rear wheel fits perfectly as is, and no signs of adverse wear, it does seem like there should be something in there to protect the carbon from the hub end. I want to be sure I didn't loose a frame part.
    Anyone able to take a look at their frame?
  4. #2804
    Reputation: Pau11y's Avatar
    Re: Tallboy LT and LTc Owners Thread
    Had the wheel off my bike yesterday putting on some IceTech rotors...yes, direct carbon contact. But my rr hub is a King and they have that smooth steel c-ring that snaps onto the axle end...no teeth to bite into the carbon.
    Naysayers never apologize. Critics go to their grave thinking everyone else is wrong.
  5. #2805
    Keep on Rockin...
    Nov 2003
    Quote Originally Posted by Pau11y View Post
    Thanks.
    Yep, I've got the Kings too and it fits great, but just wanted to be sure.
  6. #2806
    How is this for customer service... I'm the second owner of my slightly used Tallboy LT frame and rode it for a total of an hour and a half. Discovered a frame issue and SC is giving me a new frame. Cheers Santa Cruz!!!
  7. #2807
    Thanks.
    Just checked my wife's Bronson and it's the same.
  8. #2808
    Nov 2012
    Tallboy LT and LTc Owners Thread-img_6724.jpgTallboy LT and LTc Owners Thread-img_6720.jpgTallboy LT and LTc Owners Thread-img_6717.jpgTallboy LT and LTc Owners Thread-img_6718.jpgTallboy LT and LTc Owners Thread-img_6725.jpg
    Complete Custom Build, Derby Wheels w/ I9 Hubs
  9. #2809
    Quote Originally Posted by lstone84 View Post
ID:	880672Click image for larger version.
ID:	880673Click image for larger version.
ID:	880674Click image for larger version.
ID:	880675Click image for larger version.
    Pretty much perfect.
  10. #2810
    Nov 2012
    Thanks Hillarman. Only had one ride w/ the DB and Pike and the fork was the wrong offset so it will need some work. could use some pedals... i like the custom pike decals. It really ties the blue/black/white theme together.
  11. #2811
    Oct 2013
    Anyone measured the chain growth on a TBLTc?
    Converting to 1 x 10 and trying to work out what rear mech to use.
    Thanks.
  12. #2812
    Mar 2011
    Not sure about chain growth, but fwiw, I have 28tooth crank and 36 tooth Max in the rear cog, and I'm using a short cage Shimano Zee derailleur without any issues.
  13. #2813
    Quote Originally Posted by lejordi View Post
    Thanks.
    I run a med cage derailleur with a 2 X 10. Largest rear cog is 42 and front chain ring 38. You should be able to run a short cage derailleur.
  14. #2814
    Quote Originally Posted by jpo1 View Post
    20th with a 42 cog? What size is your small chainring?
  15. #2815
    Quote Originally Posted by smilinsteve View Post
    Ha. I don't know what I was thinking. My largest rear cog is a 36 and my smallest chainring is a 22.
  16. #2816
    This is what I run. I checked out the 42T conversion thing and did a quick calc w/ my 22T ring...I think I might have a hard time keeping the front wheel on the ground w/ that combo. But if I up'd the front ring to a 24, then it's a reasonable jump and don't think I'd have an issue w/ keeping the front wheel down.
  17. #2817
    Reputation: LB412's Avatar
    Nov 2012
    OneUp recommends no smaller than 26 up front. Any lower and you risk damaging the hub.
  18. #2818
    Quote Originally Posted by LB412 View Post
    Even w/ Ti or steel driveshells?
  19. #2819
    Nov 2012
    I don't think they specify. I would send them an email.
  20. #2820
    The driveshell material definitely matters.
    It is also interesting to note that torque on the hub is the same regardless of ring size, if you are moving the bike at the same speed. Big cogs create a bigger lever arm, but lower force. Small cogs, smaller lever, bigger force. Torque is the same.
    The damage from a big cog would come if you smashed down on the pedals and the wheel was blocked and couldn't turn. So there is some risk, but there is no magic line between a 26 and 24 ring.
  21. #2821
    I'm lost. Are you talking about a 22x42 low?!
    And how does that effect keeping your front wheel down?
  22. #2822
    Nov 2012
    Just passing on info from their site.
  23. #2823
    Right man I know. Its a similar thing with rotor size limits that fork manufacturers set. They do it for liability reasons, but I was just explaining the physics behind it.
  24. #2824
    Quote Originally Posted by hillharman View Post
    How'd you pull this off?
    Hey hill, notice that black Monarch damper body on the new Nomad?
  25. #2825
    I did... do you have one/are you going to get one? The larger volume positive and negative chambers sounds like a great improvement.
  26. #2826
    The real question is: where is the black Lyrik with 160-180mm travel?
  27. #2827
    That's called an X-Fusion Vengeance
  28. #2828
    Had dreams about carbon wheels last night
  29. #2829
    Needs black stanchions!
  30. #2830
    Who can tell me which Wolftooth direct mount ring to order for the X1 crank on my TBLTc?
    Attached Thumbnails Attached Thumbnails Tallboy LT and LTc Owners Thread-bb30_long_vs_short_spindle_v2.jpg
  31. #2831
    Neither of the ones in that picture, as they are both BB30. You need the ring for the GXP cranks.
    Direct Mount for SRAM GXP Cranks – wolftoothcomponents.com
    Hope that helps.
    Edit: I now see that the long spindle BB30 and GXP rings are the same, but regardless, you have GXP cranks, so you need the GXP ring.
  32. #2832
    That's what I thought. Thanks!
  33. #2833
    Too much torque to the rear wheel. I already have to watch it w/ a 22/36...the wheel comes up pretty easily in the steep ups.
    Sent from my MyTouch 4G Slide using Tapatalk
  34. #2834
    You're welcome
  35. #2835
    Sharpie Magnum...best I can do.
  36. #2836
    Not too many pictures of the new carbon with green (which is really more yellow IMO) in this thread, so here's my new baby, straight out of the bike shop.
    It was a very emotional moment, almost felt like picking up my first born from the hospital
    Attached Thumbnails Attached Thumbnails Tallboy LT and LTc Owners Thread-20140401_161123.jpg
  37. #2837
    del
  38. #2838
    Beautiful rig. Give us a ride report, and let us know when you are ready to start upgrading the suspension
  39. #2839
    JTB
    JTB is offline
    Dec 2009
    Nice... I have one on order in this color (although I preferred the 2013 with orange TBH).
    Are the tires High Rollers II? That's what the specs mention on SC website, but their picture has Ardents on it.
  40. #2840
    Quote Originally Posted by JTB View Post
    Yeah they are putting the Higher Roller 2's on them. Tubeless with Stans.
    I like the Ardents, but these seem pretty similar to Ardents, in terms of block height and even the tread pattern.
    I think last years orange looked nicer also!
  41. #2841
    JTB
    JTB is offline
    Dec 2009
    Thanks! I was hoping for the High Rollers.
    I'm jealous - can't wait to get my hands on mine - should be here by the end of April. The wait is killing me...
    What an awesome bike - hope you have fun with it!
  42. #2842
    I didn't know there was a wait on them. Luckily, my shop had this one in the box on the shelf.
    I hope I have fun with it too. Tomorrow was going to be my first "real ride" on it, but a snowstorm blew in last night. I guess I'll have to go skiing instead. Life is rough.
  43. #2843
    JTB
    JTB is offline
    Dec 2009
    SC is out of the black frames (blue is in stock aparently) at the moment but is getting a new shipment in a couple weeks. My dealer had one in stock, but not my size...
  44. #2844
    May 2013
    I have the same colors and I love them!!! As stated above the HRs come on them and I put an ardent on the rear. Love the high roller up front but wanted a faster rolling tire out back. LBS let me swap the fox for the Pike and wow!!! Defiantly impressed and a huge upgrade in performance.
  45. #2845
    May 2013
    Here's a pic when I picked it up
  46. #2846
    JTB
    JTB is offline
    Dec 2009
    Quote Originally Posted by Hoop5 View Post
    Sick!!! Did you snatch my bike though? I ordered the exact same config - Enve wheels with yellow outline decals. Do the Enve decals match the yellow on the frame more or less?
  47. #2847
    May 2013
    Yep.... Looks great together!!!
  48. #2848
    I know the yellow Maxxis lettering doesn't match the yellow/green on the bike, but it still looks good together.
  49. #2849
    Reputation: eurospek's Avatar
    I think the red pedals are a bigger eye sore to the overall color scheme than the yellow Maxxis lettering.
    konahonzo
  50. #2850
    Quote Originally Posted by eurospek View Post
    Yes I was hoping they were just the shops test ride pedals.
    The shop tried to talk me into fluorescent green pedals but I stuck with some nice gray Azonics for a more sophisticated look
