Page 14 of 26 FirstFirst ... 410111213141516171824 ... LastLast
Results 651 to 700 of 1259
Thread: Superlight Love
  1. #651
    I've got XT brakes on my SL. Best upgrade I've ever done, and I did it last July. The original Avid5s (or maybe they were 7s), would fade pretty badly on descents...
  2. #652
    Reputation: Eville140's Avatar
    Frame- 17" 2003? Superlight
    Fork- 08' Reba Race
    Wheels- Mavic Cross-Trails
    Tyres- 2.2 Racing Raplh
    Tubes- Ghetto Tubeless, Homebrew sealant
    Crank/BB- SLX
    Pedals- Eggbeater SL's
    Rear Der.- Sram X.9
    Front Der.- E13 XCX chainguide
    Cassette- Sram 970
    Chain- Cheap KMC
    Stem- Sette Edge
    Bar- Sette carbon riser bar
    Shifter- Sram X.0 Gripshifter
    Grips- Ritchey WCS foam
    Brakes- Elixer 5
    Post- Kalloy Uno SP-357 with Woodman Deathgrip clamp
    Seat- WTB Silerado
    A few to bolts here and there.
    Should be right around 26#
    Today was my first ever ride on a full suspension bike. Swapped frames to the new to me superlight and headed too the trails. Couldn't be happier.
    Attached Thumbnails Attached Thumbnails Superlight Love-uploadfromtaptalk1354146561732.jpg
  3. #653
    Quote Originally Posted by stencil View Post
    Yeah that does look good.
    Is yours a Small or Medium?
    Medium.
  4. #654
    Reputation: ATXZJ's Avatar
    Quote Originally Posted by Flash View Post
    Question for all of you SL 29er owners. I am 5"11 with 32 inseam. I like a compact fit. Trying to decide between a medium and large. What are people my size riding?
    I'm about the same size and had a medium and swapped it for a large. The bike felt a little numb so I just switched from a 120mm stem to a 75mm and added 765mm bars. Feels way more responsive than before and I can get the front wheel up without throwing my back out
    Stats:
    2012 SL RXC 29er
    Continental Mountain king II tubeless
    Shimano 530 SPDs
    WTB Pure V
    Stylo 75mm stem
    Azonic 765mm double wall riser bar
    WTB weirwolf grips
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  5. #655
    Just Ride!
    Reputation: kustomz's Avatar
    Are these pictures of your medium or large?
  6. #656
    Quote Originally Posted by kustomz View Post
    large
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  7. #657
    Just Ride!
    Hmm, I may need an XL based on looks. I am a tic over 6' with a 35.5" cycling inseam. My current bike has a 24.7" ETT and I run a 100mm stem. Anyone else between L and XL with feedback?
  8. #658
    @ kustomz : i'm 6ft1, and have the large, with 90mm stem. My inseam is 90cm.
    If in doubt, best is to go smaller.
    Also dépends on the trails you ride and the position you want on the bike.
    Sent from my LG-P500h using Tapatalk 2
    The Quebeco-Flandrien in B.C....
    SC SuperLight
  9. #659
    we are pretty much the exact same mesuments and after riding a medium and large i went with the large. Overall fit is right on but might drop the stem down to 70mm...
  10. #660
    Got a chance to take the bike out after swapping to a shorter stem and wider bars and wow, what a difference. I can now get the front wheel up with ease by just throwing my body weight around. Who knew manuals on a 29er was so much fun!
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  11. #661
    Quote Originally Posted by ATXZJ View Post
    How wide did you go on the bars? Thinking about going with a 70mm stem with 730mm bars.
  12. #662
    Quote Originally Posted by SCFast View Post
    swapped from the factory 680mm & 120mm stem to Azonic 762mm bars and a 75mm stem.
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  13. #663
    lol i guess i could have just paid attention to your earlier post for the answer..Sorry
    Sounds like a dramatic change but overall reach looks to be very close. Factory stem on mine is the 90mm really strongly considering a 70 with 730 bars for that just right feeling.
  14. #664
    Nov 2012
    My SL should arrive early next week. Called them yesterday and had them upgrade from the Avids to XT brakes based on feedback here. Cost to upgrade wasn't too crazy.
  15. #665
    Aug 2010
    I just built up an XL 26er. I am 6'1" with kind of gangly arms. I am running an 80mm 6 degree stem, spaced up 30mm, and 730mm low-rise bars, and the fit is amazing, much better than my previous bike. it feels like i'm more 'in' the bike, if that makes sense.
    my old bike was a size large gunnar rockhound 29er, which i ran with a 120mm stem. the reach is pretty much identical between the two bikes, but i like the feel of the shorter stem and wider bars a lot. the rear suspension isn't so bad either...
  16. #666
    Nov 2012
    Hey all - the '13 R XC has a 15mm front axle, correct? Ordering a rack now.
    EDIT: Nevermind. Found out that it does.
  17. #667
    No worries. Is your bike a 26 or 29? Unless you are riding super-narrow singletrack, wider is better on the 29.
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  18. #668
    it's a 29 i do not ride anything narrow enough that 2-3 extra inches of bar will be a detriment. The 680mm bars feel a little to narrow but the reach is about right so dropping the stem and widening the bars should keep the reach and liven it up.
  19. #669
    I don't really see the link between wheel size and bar width
  20. #670
    This thread will turn 9 years old next month, and is still going strong! That has to be some kind of record.
    And it says a lot about the Superlight. Great bike.
  21. #671
    Quote Originally Posted by smilinsteve View Post
    true. I guess it comes down to preceding that comment with an IMHO
    We have a SL26er for comparison and the 29er feels like it's quite a bit bigger (obviously) and benefited from wider bars to control that big wheel up front.
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  22. #672
    Oct 2012
    Superlight is a classic that with the minor updates over the years still gets the job done to near perfection. I wouldn't be surprised to see this thread going strong for another nine years.
  23. #673
    Oct 2012
    Stats:
    2012 SL RXC 29er
    Shimano 530 SPDs
    WTB Pure V
    Stylo 75mm stem
    WTB weirwolf grips
    I can't imagine this is a picture of a large frame 29er. Here is a picture of my Large 26. That frame looks way smaller.
    " width="549">
  24. #674
    Quote Originally Posted by Bone Saw View Post
    It does look small, but the medium was even smaller. The seat tube is 19.5" with the longer L/XL shock. For comparison, my large butcher is 19", Both measure as specified from santa cruz
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  25. #675
    Oct 2012
    Wow. It has to be the totally different frame geometry for the 29 set up. Granted, the larger hoops make the frame look smaller, but all the tubes look shorter too. Maybe it's because the top tube has to angle down so much more due to the larger wheels to give the same standover height. I would have bet big money that it was a medium size frame. Glad you love it. I sure love mine. It fits me perfect.
  26. #676
    The oddest thing is that the 29er frame is lighter. Top tube is the same length stand over is not the same and is about 3/4 to 1in higher on the 29 and BB sits 8/10ths lower on the 26.
  27. #677
    The oddest thing is that the 29er frame is lighter. Top tube is the same length stand over is not the same and is about 3/4 to 1in higher on the 29 and BB sits 8/10ths lower.
    something else
    my wifes small juliana only weighs one pound less than my large 29er. Both are RXC kits
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  28. #678
    Must be thinner wall tubing on the 29er's. It's only about 1/10lb lighter for a given size.
    Ordered a thomson 70mm X4 stem today...Now to get bar's squared away.
  29. #679
    Oct 2012
    I've never looked real close at a 29 SL until now. I didn't realize there was that much difference in the frame. That's amazing.
  30. #680
    Dec 2010
    I bought my SCSL29 on March 2012; after a quick riding the rear shox began oil leaking. Today Im going to take it to my LBS to check it up. Maybe Im going to apply guarantee...
    I have changed the Recon Silver TK for the Reba 29er 15mm thru axle.. the front stiffnes is great... also I have changed for a Race Face Deus CrankSet, pictures to come....
  31. #681
    heads up
    Santa Cruz SUPERLIGHT29 Complete Mountain Bike XL | eBay
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  32. #682
    Oct 2012
    Be careful about buying a stolen bike. Cheap price, no local pick up...all signs of stolen.
  33. #683
    not sure about stolen but whoever it is seems to have access to SC bikes at a good price. they have listed 20-30 bikes and a box of 15 or 20 fox shocks so if they were going out the back door of SC, somebody would have noticed by now. I hope
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  34. #684
    Reputation: MrPretty's Avatar
    Feb 2012
    My dad bought a frame from the Santa Cruz sale and we built it up with a few new parts and a some extra parts I had laying around.
    New Parts:
    Cane Creek 40 Headset
    Shimano XT Cassette
    Shimano M590 Crankset
    Tack Jockey Wheels
    Ergon GP-1
    KMC X9.99 Chain
    Re-Used Parts:
    Rockshox Recon Race SLite 100mm Fork
    Truvativ Bars & Stem
    Shimano XT M775 Brakes
    Shimano Deore Shifters [3X9] & Derailers
    Shimano XT Hubs laced to DT 420 Rims
    Specialized Saddle
    Specialized & Maxxis Tires I had laying around
    He has since replaced the specialized seatpost with a Raceface Turbine and the pedals with Wellgo MG-1s
    He loves the bike and it rides great, especially considering he spent less than $1,000 on the whole thing.
  35. #685
    Oct 2012
    That's an amazing bike for less than $1000. Nice that you had lots of the expensive parts laying around that you could re-use. Looks like a great set up.
    It looks very nice next to that cherry wood finish on the piano as well. I'm sure mom loves seeing the bike in the fancy front room on her pretty carpet. My wife gives me crap everytime my bike comes in the house. By the way, hydraulic fluid really messes up carpet...I found out the hard way.
  36. #686
    Feb 2012
    After working on ATV parts in the house a few years ago when it was too cold outside, she doesn't mind bikes inside anymore.
  37. #687
    Lol. Replied to a very old post.
  38. #688
    Nov 2012
    It's alive. ALIVE!
  39. #689
    NedwannaB
    Reputation: JMac47's Avatar
    650b?........
    Wait whuuut, who did he tell you that!?!?....
  40. #690
    Dec 2010
    [QUOTE=stencil;9973691]It's alive. ALIVE!
    tell us about your rides.... in the uphills a 29er is a very hard hammer to start the ride.... it is hard...hard....to get it start...... once it is on the way... i just let it go...
  41. #691
    Nov 2012
    [QUOTE=Fparra;9978028]
    It's alive. ALIVE!
    Will do! Have only ridden around the hood so far. I have a fitting tomorrow at the LBS when I'll be choosing new shoes to go with the new ride. Hope to hit the trails this weekend. Will keep it to fire road and basic single track as I get used to it, but there's a good mile of climbing at the beginning of the loop so we'll see how she climbs. I'm coming from a light hard tail 26er so I'm sure I'll be feeling it.
    I also realized that picture sucks.
    For those interested, it's a '13 Superlight RXC. All stock except I upgraded the Avid 5's to Shimano XT brakes.
  42. #692
    [QUOTE=stencil;9979747]
    Quote Originally Posted by Fparra View Post
    The bike climbs great...Especially for a signal pivot
  43. #693
    Jun 2012
    Just snagged SL 29 2013! This bike was a great choice for me. This is my first fs mtb. Had a trek marlin 29er ht (great bike) but was feeling pretty beat up after long rides (I'm 39) . My riding buddy suggested a fs bike and after some careful consideration I went and test rode both the tallboy and SL 29. Both bikes felt great and sorta similar,but my budget was 2000$ so I went with the SL. Wow! what a difference! Great climber I have more confidence tackling the more technical stuff and I don't feel so torn up after longer tougher rides.
  44. #694
    Jun 2012
    Will post pics soon
  45. #695
    Jun 2012
  46. #696
    Jun 2012
  47. #697
    Reputation: SIM37's Avatar
    My superlight and Iron Horse MK III Expert.
  48. #698
    Gleaming after being cleaned.
  49. #699
    Nov 2012
    Quote Originally Posted by nelson73 View Post
    Congrats! I test rode both as well and went with the SL and I could have afforded the Tallboy. I just love the simplicity and geometry of the frame.
  50. #700
    Jun 2012
    Nice rides indeed. Very clean!
  1. No love for Trek yet?
    By PmbH in forum Trek
    Last Post: 05-03-2004, 04:32 PM
  2. I love my Avids!
    By Brandon in forum Brake Time
    Last Post: 01-13-2004, 09:32 AM
Members who have read this thread: 47
