Results 1 to 6 of 6
    Reputation: dseybert's Avatar
    Superlight Chain Drop
    I have a Superlight 3.1 with a 3x9 setup. I have all Shimano drivetrain except for a Sram chain. My problem is I constantly drop the chain in the front rings. Anyone else have issues with this or a possible cause? I know I could swith to a 10 spd setup and get a clutched derailleur, but I'd prefer to avoid throwing down that kind of cash.
    Reputation: 11053's Avatar
    Are the limit screws correctly adjusted on the front derailleur?
    Is your chain the correct length?
    If it's dropping off the small ring towards the frame and bottom bracket when shifting, you could likely benefit from checking the adjustment of the limit screws.
    If it's dropping off any of the front rings while just riding, your chain could be too long.
    Combo of too long chain + limit screws out of adjustment will allow for chain drop.
    Park Tool Co. » ParkTool Blog » Chain Length Sizing
    Park Tool Co. » ParkTool Blog » Front Derailleur Adjustments
    If it continues to be an issue then you are correct-clutch type rear derailleur is a fix.
    There's also this:
    E Thirteen Heim 3RS Chain Guide | Chain Reaction Cycles
    JKA
    JKA is offline
    Reputation: JKA's Avatar
    I agree. Front derailleur adjustment sounds like the problem. Limit screws and alignment. Chain length as was said could also be an issue. Shift it to the large front ring and largest rear cog and the derailleur should be pretty stretched out, but still have a tiny bit of slack in the chain (just enough not to bind up), if it's more slack than that, chain is too long.
    I have a superlight 3x10 without a clutch rear derailleur and chain drop is VERY rare.
    Thanks for the replies. I'm pretty sure it's not derailleur adjustment. I'll double check the chain length.
    Fence guru
    Nov 2008
    Front chain rings worn
    Chain worn or too long
    Or front der
    Certainly not the frame
    Re: Superlight Chain Drop
    Quote Originally Posted by supercusty View Post
    Or front der
    After checking this morning I think my chain was too long. Test ride in the morning will hopefully verify.
  1. Does the Superlight 29 have less chain slap?
    By solidass in forum Santa Cruz
    Last Post: 07-03-2013, 10:34 AM
  2. Superlight Chain Rub
    By aikane in forum Santa Cruz
    Last Post: 12-24-2012, 05:52 PM
  3. Chain Drop on RIP 9?!
    By sonoranbiker in forum Niner Bikes
    Last Post: 10-03-2012, 06:53 AM
  4. Chain drop drop off and misalignment a norm?
    By boardrider02 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-03-2012, 01:20 PM
  5. Chain drop on a 1x9
    By otisinLA in forum 29er Bikes
    Last Post: 12-02-2011, 04:34 PM
