Results 1 to 3 of 3
    Jun 2012
    Superlight 29 Main Pivot Maintenance?
    website says "check back soon" for maintenance instructions. I think it has said this for a while.
    after nearly a year of riding my main pivot is very loose, just noticed. I am pretty much a rookie at this but figure it can't be that hard, IF I have some direction. Anyone??
    Dec 2005
    its easy. use a 5mm hex wrench, and take out the bolt. use the wrench to take out the brown washer under it. use an 8mm hex wrench to tighten up the axle. just make it barely snug so you don't crush the bearings, just enough to take out the play and not any more.
    grease the taper on the washer, and loctite the threads on the bolt, and crank that bolt down to lock the shit in place. about how tight you'd want a stem bolt.
    here we go again
    rdb
    rdb is offline
    Quote Originally Posted by wgerow View Post
    Bearing Overhaul Instructions The instructions are for the 2006 Superlight 26er, but I don't think the pivot changed for the 29er. These instructions are for a major overhaul, follow eleven-yo's instructions for basic maintenance. The link has pictures and step by step instructions.
  1. Replies: 5
    Last Post: 12-24-2014, 05:54 PM
  2. GT RTS main pivot
    By zonoskar in forum GT
    Last Post: 04-18-2013, 01:43 AM
  3. 2012-13 Superlight - uneven gap at the main pivot
    By purple dog in forum Santa Cruz
    Last Post: 10-31-2012, 09:36 AM
  4. K2 EVO main pivot bearings
    By Bark Rash in forum Vintage, Retro, Classic
    Last Post: 08-02-2011, 01:41 PM
  5. Seven main pivot bolts
    By belljeffw in forum Yeti
    Last Post: 06-13-2011, 08:53 AM
