    Reputation: BTTR's Avatar
    Jun 2012
    So which XX1 crankset for a Nomad C?
    Since Shimano is taking ages to come up with a XX1 beater i'm entertaining the idea of, in a not so near future , getting a XX1 for my NomadC
    I was just checking the cranksets and i realized there are a lot of options to choose from and i'm kind of confused
    Besides the arms lengths and the chainring tooths (which i understand) i see there are Q-Factors (156mm or 168mm) and BB30 or GPX???
    Of these (Q-Factor and BB30 or GPX) which are recommended for a Nomad C?
    TIA
    ban
    ban is offline
    GPX & 168mm
    PULL
    Reputation: NoManerz's Avatar
    Feb 2006
    From their FAQ it says
    What size bottom bracket do I need?
    The Nomad uses a 73mm threaded bb shell, so make sure you always get something compatible with that. Pretty much any external bearing crankset will work. If using XX or XX1, use the wider q-factor spec (166 or 168mm respectively)
    I looked it up last week. http://www.santacruzbicycles.com/nomad/faq.php
    Jun 2012
    Good job!
    Perfect. Thanks guys!
    In the meantime i was searching and was realizing it should be GPX, as BB30 is a pressfit BB. (is this right?)
  1. Differences in strength between XT 780 triple crankset and the 785 double crankset??
    By zoro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2013, 03:11 AM
  2. Tallboy with XT crankset to XTR crankset?
    By Rev. 14 in forum 29er Components
    Last Post: 04-15-2012, 06:11 PM
  3. Can I put the small ring (22) from an M542 Crankset onto a Deore XT M781 crankset?
    By bobonker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2012, 12:04 AM
  4. Chainline difference in a 2x crankset vs a 3x crankset?
    By fire_strom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-09-2011, 06:50 PM
  5. Changing my AM Nomad to DH Nomad
    By stunzeed in forum Santa Cruz
    Last Post: 04-09-2011, 06:15 PM
