Results 1 to 6 of 6
    Proud lame eBiker
    Reputation: Internal14's Avatar
    Sm. Nomad, 4mm or 7mm crown race?
    Building a small Nomad for a cust. He says he needs a taller lower crown race so that the fork clears the downtube.
    With a King Headset which lower crown race should I use? Ventana makes a 4mm and a 7mm for the King HS for this case, but not sure which on is enough/overkill.
    Thanks SantaCruzians!
    nerfherder
    Reputation: scruffylooking's Avatar
    I would think it depends on the fork...
    Old man on a bike
    While the customer may always be correct, why do you think the 3mm is a make or break situation for you? What fork is it?
    suum quique
    Proud lame eBiker
    thanks guys. I got a response from Tim@santacruz.
    For what it's worth he said to use the 7mm option.
    So there ya have it. Done.
    Cheers.
    SC inform me to run a 4mm for my Fox36 Talas=WRONG!
    Need to go with the 7mm Ventanna(King) race instead.
    If I would have known I would be jackin up my front end by 7mm, I would have gotten a MED Nomad instead of the SMALL.
    One of the guys at my store just built up a small and had to go w 7mm for his 36 Talas. (Sorry, i just saw this thread.)
