Results 1 to 3 of 3
Thread: SL Frame Q's
    SL Frame Q's
    Bought a used 17" SL frame for my wife, it has the older style swing arm. The bike should be shipped today but want to have all the parts for a quick turn build. Few q's:
    FD: Top pull, but what diameter and swing?
    BB: What Diameter and length?
    Seat Post: What Diameter?
    Thanks in advance.
    disregard, didn't see the info on the website first go around, unless the front triangle has changed significantly.
    Quote Originally Posted by pwork
    Thanks in advance.
    The pre-07 SL frames are different than the current model frames.
    Here's the info you requested:
    FD: TP,TS Edit: 31.8 mm derailleur clamp size
    BB: 68mm shell width (spindle length depends upon the crankset you intend to use)
    SP: 27.2mm (seatpost clamp is 31.8/32mm)
    Recommended fork travel: 80-100mm
    Ask if you have any other questions.
