Results 1 to 5 of 5
    Jan 2014
    Should I apply anti-seize compoun to VPP on brand new Tallboy (Or any other SC bike)
    Hi!
    I read the thread about taking apart VPP ink and applying anti-seize compound on axles to bikes that been used for year or so..
    I was wondering if this should be done with brand new bikes, as a "pre-use" service maintenance.
    Reputation: sooner518's Avatar
    i would use (non lithium) marine grease. the bike should come with a grease gun filled with blue marine grease. thats what all the instructional videos from SC says. they never mention putting an anti seize compound on anything.
    aside from that grease and Loctite on the threads, i wouldnt put anything else in your VPP links....
    Jan 2014
    Quote Originally Posted by sooner518 View Post
    Thank you .. They are referring to anti-seize compound in the sticky posted on top about overhaul of VPP link VPP Linkage Overhaul Pictorial
    Reputation: Pau11y's Avatar
    Yes you can.
    Just loctite the chainring bolt looking thing.
    Edit: I anti-seize the collet wedge, the expansion sleeve, the axle, BUT I loctite the M5 and M4 collet bolt into the axle, torqued to spec.
    Naysayers never apologize. Critics go to their grave thinking everyone else is wrong.
    Quote Originally Posted by pavlov0032 View Post
    just FYI - that is a really old overview, for the 1st gen VPP hardware. SC has a bunch of updated videos on their website going over all this maintenance: VPP lower axle maintenance | Santa Cruz Bicycles
    i guess you CAN use anti-seize, its just not what SC specs....
  1. Anti-seize, loctite, grease ??
    By b12yan88 in forum Wheels and Tires
    Last Post: 06-20-2014, 02:44 PM
  2. Anti-seize compound
    By telemike in forum General Discussion
    Last Post: 09-11-2013, 10:57 PM
  3. Grease, Thread Lock, or Anti-Seize?
    By Tsetse in forum Tooltime
    Last Post: 04-23-2013, 08:45 AM
  4. anti-seize for Ti frame?
    By veritechy in forum Bike and Frame discussion
    Last Post: 04-21-2013, 03:39 PM
  5. Anti seize paste for Ti frames
    By Green Monk in forum Frame Building
    Last Post: 04-26-2011, 08:40 AM
