Results 1 to 21 of 21
    PULL
    Reputation: NoManerz's Avatar
    Feb 2006
    Shot/Ball peen in frames?
    Has anyone else noticed an absurd amount of left over shot/ball peen inside their frames?
    Edit: Anodized frames that is.
    Natural body armor
    Reputation: Zen_Turtle's Avatar
    Quote Originally Posted by NoManerz
    NoManerz, NoPics?
    "There is no A-line"
    Savvy Bike
    PULL
    Feb 2006
    Sorry, I just couldn't believe what I saw. I tried to snap some photos, was not very easy.
    This is a year later. King headset was installed, frame faced, and all work done and inspected by professional shop. No balls anywhere. Clean frame. I even eyed it over.
    I pulled my king out for some strange sounds and I find this mess. I'm blown away not at the shop who installed my headset, but by the SC ano guys QA job.
    Jan 2005
    Geez that sux, mind you ive never noticed any shot peen in my Ano Bullit? I imagine the shot peeners would normally block the holes so the balls dont go into the frame, id say they forgot to block the top and bottom tube holes in the headtube! Stoopid Shotpeeners!
    I had plenty in the seat tube of my Ellsworth Rogue. Couldn't even remove my seat post, a Thomson, which was completely scratched... I had to sand paper the inside to fix a (new...) seatpost...
    abnormally aspirated
    Jun 2005
    I don't know much about this stuff. Are these "hard" in that they are metal or ceramic or another material or are they soft? I have something similar in a used 4X frame I picked up, but the little balls seem to crush with very little pressure between my fingers and look like lube in ball form....
    SC Junkie
    Reputation: SATANRULES's Avatar
    I have seen this
    Hey NoManerz what kind of frame is that?
    PULL
    Feb 2006
    These are steel balls. They scored the living crap out of my king headset and fork.
    Frame is a vp-free.
    Reputation: damaltor's Avatar
    Dec 2005
    Yeah I had them too... first noticed in the seat tube, scored the heck out of my post. Tore the bike down and found them in abundance in the HT and BB as well. Spent a considerable amount of time blowing them out of the frame with compressed air.
    Reputation: mainecorrado's Avatar
    good friend had the same problem, did a lot of damage to his steer tube. starting to cut through it and the bottom of the headset and top of the crown. would be a good idea to check the ano bikes just to be sure. if the steer tube is cut/broke/falls out you're in BIG trouble.
    PULL
    Feb 2006
    Quote Originally Posted by mainecorrado
    I pulled out the fork and almost crapped my pants when I saw the same exact thing. It looked like a pipe cutter was on my steer tube. My headset looked like it got threads put into the inside of it.
    I hate to say it but I am looking else where for a new frame when the time comes.
    looking at your pictures, they look exactly like my friends bike. scary!!
    i love my santa cruz, but will stay away from the ano bikes.
    ewww, that looks terrible gd, is this in the ano frames only? i have an 07 heckler powder coat, should i be concerned?
    to my understanding, it's just the ano frames because of the shot peening to give the finish.
    ohh ok thanks
    This is double fault. SC should not send out frames that are "dirty" like that. However, the LBS (or you if you are assembling) should make sure everything is clean before assembly.
    LDH
    LDH is offline
    Reputation: LDH's Avatar
    I just picked up a used 2007 blur lt for my daughter and the BB thread were galled from the shot. Had to pay the LBS $25 to chase both side so I could fit my parts without damaging them.
    legal alien
    really sorry to see the damage to your parts. i had an ano vp-free and the same thing happened to me. when i first got the bike there was loose shot and we tried to blow it out (in hindsight vacuuming may have been a better idea). we put the bike together, no problem. but, normal riding redistributed the shot resulting in:
    - a totally marred seatpost and pretty good guages in the seatube
    - after i removed the bottom bracket for normal service and subsequently re-installed, the bits of shot which fell through the seattube when the bb was removed resulted in thread damage when i went to put the bb back in.
    given this experience, i would hesitant to get another ano frame. if i did, i would be obsessive about getting the shot out.
    Jun 2005
    any tips for removing shot besides compressed air? seems like if the bike is completely apart, this should do it, but sometimes static charge (or some other phenomenon I don't understand) can hold those things like a mother effer....
    has anyone tried dropping a small magnet attached to a string in the frame tubes to collect the shot? i am not sure completely what they are made of but if they are steel then you should be able to remove the loose shot with a magnet. just an idea no idea if it is possible
    Legend
    Should be steel; cheap. I worry about my SL Ano now Oh well, I wanted to take my frame apart anyways for it's 1st year maintenance.
