Results 1 to 6 of 6
    Reputation: Steve.E's Avatar
    Shock hardware 21.8mm, is 22mm ok?
    Hi all
    I need a new shock bush for my rp23 on my Blur TRc, is a 22mm wide one OK to use? When ordering a 21.8mm in the past for a different bike the shop (tf tuned) said that a 22 would be OK, but I'm a bit cautious this time as that was for an alloy frame.
    I should add that the bush comes with the spacers and mounting pin.
    Reputation: zoro's Avatar
    Same here. Anybody care to comment?
    Well, I ordered the 22mm hardware and I've been using it for a few weeks, seems completely fine and bolted up as normal.
    certified mtb addict
    Reputation: Micka's Avatar
    It's just some laziness from rounding the numbers. This is in the FAQ on SC's site for the Blur XC (not sure why it's not in the FAQs for all SC's dual suspension bikes, it should be).
    "Mounting hardware on both ends is 22mm wide (21.84mm to be exact), with an 8mm through hole."
    Fit perfectly on my Nickel. I'd think this goes for most SC models.
    Fox - 803-03-165, 8mm X 21.84mm
    Mar 2015
    I know on my LT it says 22x8 unless using SRAM (Rockshox) and then use 21.8.
  1. ASR5 Shock Hardware
    By heckler_asx in forum Yeti
    Last Post: 11-18-2015, 07:38 PM
  2. Shock hardware SS
    By banano in forum Intense
    Last Post: 10-24-2012, 05:43 PM
  3. Shock Hardware
    By Prophet Julio in forum Shocks and Suspension
    Last Post: 11-15-2011, 01:14 PM
  4. Romic Shock Hardware
    By Freerydejunky in forum Shocks and Suspension
    Last Post: 07-19-2011, 01:45 PM
  5. Shock Mounting Hardware
    By gticlay in forum Santa Cruz
    Last Post: 02-08-2011, 08:38 PM
