Results 1 to 6 of 6
    May 2013
    SC BLUR 115 mm......that fork place ???
    ALL GOOD!
    Nothing so far had mounted on my Santa Cruz Blur purchased in 2006 that has a 115mm rear travel ............... to which at the time I put a fork ROCK SHOX REBA TEAM AIR U-TURN 85-115.
    And now I have to change and as I'm a bit lost as to the material currently used ........... and I have a bit of ignorance .............. . which fork would you advise me to this bike to make it ................... versatile.
    You think that putting a forked path variable???? ...................... Fixed route better??????????
    In order to have if you can help me with the topic.
    thanks
    GREETINGS
    May 2013
    sorry for my bad English, I use an online translator !!! not if you will understand my question now
    my question is.
    I have a SC Blur of 115 mm of rear travel purchased in 2006.with a ROCK SHOX REBA TEAM AIR U-TURN 85-115 mm.
    Now I need change, and I would like to give me your opinion on which fork make this bike???
    for I have a versatile bike also because I have to also one SC Superlight I use for XC
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    So you want a different 115mm travel fork for your BlurXC? Why not go with 120mm? Plenty of options available at that travel.
    May 2013
    Quote Originally Posted by 007 View Post
    Thanks for your answer
    if I want to put something between 120-130 mm .
    what options do you think better??
    to have a versatile bike.
    007 is offline
    b a n n e d
    Jun 2005
    Do you like your Reba? Have you ever ridden Fox? What about Bos?
    May 2013
    GOOD.
    Say 007.
    What if I liked my RS Reba response. but since the purchase in 2005.
    No new RS as Reba respond now.
    And on FOX because I have not ever used it ............... and not just go and answer.
    And the brand BOS not know.
    In order to have you give me advice about buying in a range around 120-130 mm for my SC Blur with 115 mm of rear travel
  1. Blur XC with 120 fork or Blur TR
    By Shift Worker in forum Santa Cruz
    Last Post: 04-10-2013, 08:49 PM
  2. Replies: 6
    Last Post: 09-04-2012, 03:02 PM
  3. Rigid in place of 100mm fork?
    By hitechredneck in forum Singlespeed
    Last Post: 02-11-2012, 05:30 PM
  4. Place to have fork lowers painted or polished?
    By gticlay in forum Downhill - Freeride
    Last Post: 02-02-2012, 12:40 PM
  5. 32 to 36 fork on Blur LT2
    By maxwolfie in forum Santa Cruz
    Last Post: 09-30-2011, 08:38 AM
