Page 1 of 2 1 2 LastLast
Results 1 to 25 of 32
    Santa cruz solo creaking while climbing
    I've been riding the Solo for 8 months minus the winter months. Recently I noticed an annoying creak while I was climbing. It would creak on every pedal stroke. At first I thought it might have been the seat. I checked and tightened the seat. Still creaking. Greased my lower pivots. Still creaking. I had similar issues in my Blur classic and Blur LTC. I was hoping they had this issue taken care of. Do I need to have my pivots replaced like the previous bikes or is there any adjustments/maintenance that can be done?
    Pedals? BB?
    Dec 2008
    Grease up your cassette body
    Reputation: 11053's Avatar
    If your pivots are loose and need adjusting, just greasing them won't be enough.
    Have your pivots and bearings ever been adjusted properly since you got the bike?
    Tech Tuesday: Adjust the Pivot Bearings on Any Santa Cruz VPP Suspension - Pinkbike
    Reputation: Steve.E's Avatar
    Check for play in the frame, check pivots as above.
    Reputation: Gman086's Avatar
    8 Months without a shock bushing change? 99% sure it is the above!!! No way do the pivot bearings wear out in 8 months. And loose pivot axles just cause frame play, not creaking (as long as the corresponding bearing is still loctited in that is). And I never grease cassette bodies as that just attracts dirt (and I've never had a creak). Trust me, the teflon is worn off your DU bushings on the rear eyelet side of the rear shock. Amazing you got it to last that long!
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    May 2010
    Check:
    Seat - where rails connect to seat and were rails connect to post.
    Seat post - pull out, clean, regrease, and clean down inside seat tube. Including seat collar.
    BB - remove, clean it and shell, regrease.
    Crank arms - same.
    Chainring bolts - tight.
    Pedals - check torque on crank arms. Pedal bearings.
    Shock mount - DU bushings
    Links as mentioned
    Headset - remove, clean, regrease, adjust, ect
    Stem - clean, tight, etc.
    At some point I've had creaking issues from the above areas and resolved it when I cleaned and reinstalled with proper lube and/or torque. Sometimes a creak resonates though from an unlikely source. What frustrates me is finding the specific part causing the creak but can't find a way to silence it - like weird clicking in Freehub bodies.
    Reputation: scfreak's Avatar
    Oct 2007
    What drivetrain? Xx1 or x01 grease your hub body and tighten the cassette.
    tighten your rear axle.
    Quote Originally Posted by Gman086 View Post
    Have FUN!
    G MAN
    G MAN - How do you decide which inner ring to use? I have a TRc and each of the rings seems to be basically the same, so I just went with the "+" one.
    Also, if I push down on the suspension, I get a creak after pulling the rear triangle and the front triangle away from one another (even without the chain on). Any idea how to resolve this?
    Thanks.
    Ok. Thanks everybody for the input. I ordered the needle bearing kit. Hopefully this will get the creak out. There seems to be a lot of play now, so I hope it will fix it. I really appreciate the replies.
    Reputation: JumpinStumps's Avatar
    Oct 2013
    Hi all - I just picked up my SOLOc X01 last night after a 6-week wait and had a blast on the first ride!
    Don't mean to hijack the thread, but I noticed the same kind of noise while climbing this morning. Although I would describe it more as "clicking" vs. creaking. Could be the same noise as you guys, but I almost wondered if the rear triangle was flexing and the chain was getting slightly out of alignment with the cassette? This is my first full suspension bike and first carbon bike, so not sure if this is normal or if perhaps the LBS didn't tighten up the pivots enough?
    What do you think?
    Thx!
    Quote Originally Posted by JumpinStumps View Post
    What do you think?
    Thx!
    The clicking might be the type 2 derailleur. Check out the SRAM forum, including this link: XX1 knocking/clunking
    Quote Originally Posted by LowLow View Post
    Thanks.
    I use the biggest inner ring that fits without forcing it on (even if tight it will rotate a lot easier than any DU bushing).
    As for the creak - is that with the shock off? If so, adjust your pivot axles:
    If not then I think you'll find the needle bearings to do the trick!
    Have FUN!
    G MAN
    Reputation: dirtyjack's Avatar
    Have FUN!
    G MAN
    DO NOT Torque to 100 in/lbs!!! I have snapped more than one of the outer bolts when torquing to spec. I traded emails with SC and this was their recommendation: "our torque specs are a bit on the high side and have heard of bolts snapping when going to spec. I think 85 in/lbs is much better, and works fine."
    Have FUN!
    G MAN
    Thanks! Regarding the creaking, it turned out that it was the upper axle, the one that connects to the shock. I cleaned and greased it per SC's website and it's quiet now: VPP upper axle maintenance | Santa Cruz Bicycles.
    Mar 2013
    I had my 5010 a couple of months and it started creaking. Thought it may have been the X01 cassette that had been mentioned in other threads. But the other day I decided to check the pivots. Clean, re-grease, lock tight and torque. Fixed the problem right away.
    Oct 2013
    I finally found the source of my creaking / clicking. It's a bit embarrassing, but in the spirit of helping out... My bash guard (1x11) had a really tight tolerance against the chain. When out of the saddle on a steep climb the bottom bracket must have flexed ever so slightly so that the chain touched the bash guard and clicked as it passed by. I adjusted the guard and haven't heard it since.
    Reputation: GnarBrahWyo's Avatar
    Jun 2012
    Will have to take all of these into account. My Solo has been creaking like a MoFo too.
    Quote Originally Posted by dirtyjack View Post
    My answer from another post:
    "SC has always had their specs "too high" (thank goodness for Willie and generous customer service for free bolt replacements) BUT if you torque in increments (I go 70 in/lbs then to 85 THEN 100), the specs are fine."
    If you try to go to 100 in/lbs from zero then... yeah, good luck. Also know the upper 4mm one is spec'd to 90.
    Have FUN!
    G MAN
    Jun 2012
    Hey guys, a little update:
    I had my LBS replace my bearings, bottom bracket and lube/locktite axles properly. Creaking while climbing is gone. However another issue has surfaced, one that was emerging before I took my bike in to have creaking fixed. It's my rear shock. Squeaking like crazy. It's even worse in pro-pedal mode. Have a race on Tuesday and am still dealing with weird noises. Very annoying...
    My rear shock has also developed a squeak in the last couple rides. I thought it may have been dry air sleeve seals but there was still a bit of float fluid in there. I added a bit more and it still squeaks faintly. I haven't tried changing the CTD lever yet (I run it in trail 1 mostly).
    My old Pushed RP23 "squeaked" in different lever positions. This was normal harmonics from the shock. Perhaps this CTD squeak is similar to the old RP23 squeak.
    Update, the CTD lever has no impact on the squeaking, It squeaks in all positions. Fox is really starting to piss me off.
    Jun 2012
    My air sleeve was pretty dry and I lubed it up and it helped a bit. Stil annoying for a $4k bike to have to deal with this.
  1. Is a Santa Cruz Solo too much bike for XC?
    By bootsie_cat in forum 27.5
    Last Post: 06-26-2014, 06:16 PM
  2. Santa Cruz Solo aluminum project
    By mrbeef523 in forum Santa Cruz
    Last Post: 02-27-2014, 01:22 PM
  3. Did I Buy the Wrong Bike? Santa Cruz Solo
    By MarkP in forum All Mountain
    Last Post: 11-22-2013, 12:01 PM
  4. Replies: 8
    Last Post: 10-16-2013, 06:21 PM
  5. Santa Cruz Solo NYC
    By karlonC in forum Santa Cruz
    Last Post: 08-20-2013, 07:55 AM
