Page 71 of 75 FirstFirst ... 2161676869707172737475 LastLast
Results 3,501 to 3,550 of 3739
  1. #3501
    Reputation: nathanbal's Avatar
    I have an Elevensix on the HT at the moment and love it - it really is as transforming as everyone says. I also have an X2 on the way to try out so will report back!
  2. #3502
    Reputation: LCBooger's Avatar
    Apr 2014
    Quote Originally Posted by tuckerjt07 View Post
    I, especially with the possibility of getting a new link, just wish there was a shock where the user could change travel as easily as some forks allow.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    New link isn't a guarantee. I wouldn't get too hung up on that.
  3. #3503
    Apr 2014
    Santa Cruz Hightower
    Anyone else obsess about their cable tidiness?
    https://www.facebook.com/MTBEU/posts/1340035026064251:0
  4. #3504
    Nov 2016
    Quote Originally Posted by LCBooger View Post
    Doesn't matter, that's optimal but a readily available offset will serve the purpose if no new link.
  5. #3505
    The dark side is quicker
    Reputation: evilbullit's Avatar
    Sorry of I missed it, but has anyone actually ridden with a M/M tune shock?
    After reading though a lot of this tread, and searching various key words, I couldn't find anyone who did.
    I did see a few people complain about "bad shocks" though, so that may be my issue?
    Situation is...215lbs + gear and I have to inflate to 285+ psi go even get close to 30% sag and then the shock feels like crap (super stiff) when it gets moving. Small bump is decent, but not impressive and I do get frequent pedal strikes.
    Im going to order a RC3 plus anyway, and then send the RT in for warranty, but what about L/L vs M/M tunes?
    TIA
    "The Truth is Absolution."
  6. #3506
    Reputation: SDMTB'er's Avatar
    Feb 2014
    Quote Originally Posted by robnow View Post
    Yeah SDMTBer, was just perusing through the Switchblade thread and noticed you are coming off the SB on to the HT. Curious on your reasons for change. Did you consider the 5.5 as well?
    I don't have a Pivot SB but that was in the running. In the end I didn't want the 157 hub and wanted to go a new direction as I have had a number of Pivots. Very happy with my choice but something about the HT isn't giving me the same traction on steep loose climbs. Strange because the STA is steeper than the 429 Trail. I don't have my oval ring on yet so maybe that is part of it.
  7. #3507
    Feb 2014
    Quote Originally Posted by Pau11y View Post
    But your avatar...
    Still have two Pivots - 2017 Firebird and 2016 429 Trail
  8. #3508
    Reputation: Pau11y's Avatar
    Quote Originally Posted by SDMTB'er View Post
    Ovals help. But from reading a ton of posts, it seems the bike does better w/ a better rear shock. The X2 is fantastic, but limited to ppl weighing around 220 and less...because of its 250 psi max.
    Naysayers never apologize. Critics go to their grave thinking everyone else is wrong.
    ╭∩╮( º.º )╭∩╮
  9. #3509
    Reputation: chris9888's Avatar
    My first 3 rides without oval ring compared to now with oval ring makes hell lot of difference. Think the stock shock affects the descent more than climb. Looking to get X2 soon.
  10. #3510
    Reputation: Dr.T's Avatar
    Mar 2017
    It should be, as well as XXL frame.
  11. #3511
    _____
    I can second Pau11y's x2 experience. Traction on techy, rocky climbs got much better when I got my x2.
  12. #3512
    Reputation: Whiptastic's Avatar
    Mar 2016
    What do you recommend rear shock wise for the 220+ crowd?
    2017 Santa Cruz Hightower 29C-S
    2016 Soma B-Side 27.5 Belt Drive E-Build
  13. #3513
    Quote Originally Posted by Whiptastic View Post
    DHX2. I think coils will work better w/ bigger riders. If you want ramp up control, something like a X-Fusion HLR coil also works well. I've tried on on the HT and it feels fine. And with ovals, you won't have too much pedal bob.
    Or, if you want to stick w/ air, CCDBaCS? I've also seen someone on here w/ a Vivid Air.
    ╭∩╮( º.º )╭∩╮
  14. #3514
    For HT shocks you really want an EVOL or debonair. They play well on VPP.
    Long shocked the HT is a beast. I have a DBair that ive run and its planted. I ended up with an X2, but that may change b/c I just picked up an intense spider for a 275 - and I'm thinking of HT being an enduro beast and the Spider the play/jump bike.
    Have to quit braking parts first... bars, stem...
    believe in yourself! I believe in you!
  15. #3515
    Hightower, 1 year later
    It's been a year since I bought this bike. Still enjoy it! Over time changed a few items; carbon bar at 780mm, 35mm length stem, 26t chainring, XT ICE tech rotors. Went with a Roval carbon 29er wheelset and recently had Colorado Cyclist build a 27+ wheelset. Fork is still 140mm, just went with a 3.0 tire upfront. I prefer the bike in 29er mode, but the 27+ is a lot of fun. It really is like having 2 bikes in one.
  16. #3516
    Quote Originally Posted by 25lbs&counting View Post
    How was the bike handling in 27+ wheels with 140mm fork? Flip chip at high?
  17. #3517
    Jul 2015
    I rock Roval Traverse SL Fattie 29's too...They're great super wide and light
    Sent from my XT1585 using Tapatalk
  18. #3518
    Reputation: OldManBiker's Avatar
    Nov 2016
    26t Chainring..?? Wow. Is that like Grannie on steroids? I've often thought of what it would be like to go from 30t to 28t but.....26t...??? Say it ain't so!
    Old Man Biker
    2017 Field Staff Member of MagicShine - LED Bike Lights
  19. #3519
    Nov 2016
    So I've finally decided on my latest and newest bike upgrade which most likely could be my last. After hours of reviews, research, questioning folks here, and demo's I finally pulled the trigger and ordered my new Santa Cruz HT C (Matte Carbon & Mint) in the 27.5+ mode. Riding those 2.8" tires over my current 3.0" was unlike anything Ive ever experienced. Not to mention going from a hardtail to FS! But the bike felt like BUTTER in my hands. It's getting a few extra "bells & whistles" added above the normal stock bike. After I pick it up on friday (crossing my fingers) I'll be sure to list what I'm adding. Nothing major. I appreciate all the great positive comments on all of your SC HT bikes here! It really helped make my decision much more easier.
    Due date: 3/24/17
    Old Man Biker
  20. #3520
    Jul 2015
    Quote Originally Posted by OldManBiker View Post
    Due date: 3/24/17
    I hope all 3,600 posts helped you out!
  21. #3521
    Reputation: mtnbkr80015's Avatar
    With a 9-44 it works out to the same as Eagle on a 1x11
    Enjoy the ride...
  22. #3522
    Quote Originally Posted by mtnbkr80015 View Post
    Well 28 tooth with 9-46 1x11 would be closer, but the eThirteen TRS-r wasn't available when I did mine
    Enjoy the ride...
  23. #3523
    Oh, and where do you ride? Some of us here ride at 7,000+ feet with super steep extended climbs and are middle aged and out of shape due to 6 months of snow on the ground. XC skiing can only do so much, and fat bikes aren't allowed in Yellowstone National Park nor does the snow level enable it. By the way it is the same as a 22-36 on a double
    Enjoy the ride...
  24. #3524
    Reputation: yuppie's Avatar
    Mar 2013
    Thinking about some upgrades for my S build.
    Rear Shock
    Wheelset
    Drivetrain
    I've heard the DVO Topaz and some of the FOX EVOL stuff is good, but I think I could get a better experience out of the stock shock with some adjustment/tuning put in.
    The wheelset and hubs are probably going to be the most noticeable improvement. I'd really like to find a used ENVE wheelset with DT Swiss, Chris King or HOPE hubs. I've heard the the rear hub is pretty important when delivering power to the wheel. I've also heard light bicycle, ibis and those carbon roval hoops aren't too bad. I'm seeing some ENVE wheelsets M70 with DT Swiss 240s for ~$1700, not bad?
    The drivetrain would be cool to replace, but other than carbon cranks and faster shifting, I don't think it'd be a good way to spend $1k at this point. But I'd like an X01 Eagle setup.
    What do you guys think?
    What bike is that?
  25. #3525
    No Clue Crew
    Apr 2005
    Don't let tough-guy chainring talk bum you out, man. Run what works for you and your terrain.
    Just like a raindrop, I was born to fall.
  26. #3526
    How cool to ride Hightower like they did in NZ!
    https://youtu.be/N7AK1vl5FXk
  27. #3527
    Reputation: themanro's Avatar
    Mar 2014
    Quote Originally Posted by chris9888 View Post
    That's some proper fun, screw the race. They are killing it on 29ers. Looks just as fun when they ride 5010s.
  28. #3528
    Too funny!!!
    NZ Enduro Day 2: The Nydia Bay massacre ? Dirty Nomad
    "To try and distract myself from my own mental instability and catastrophizing, I resorted to EWS PRO Bike stalking, purely because the idea of watching the MTBR Hightower Forum regulars head’s exploding in a cloud of pink spray like they’re Marvin seated behind Vincent Vega holds massive appeal."
    LINKAGE:
    "Unfortunately I was physically restrained as I tried to get my 6mm allen key out"
  29. #3529
    Nov 2016
    Quote Originally Posted by wytemike21 View Post
    I'm not sure I follow your comment about the 3,600 posts as I only have a whopping 151. So maybe you have me confused with someone else. But the few I have made in regards to an upgrade have been quite helpful so thank you for the care Mikey!
    Old Man Biker
  30. #3530
    Jul 2015
    There are 3,600 posts on this hightower thread, hopefully reading through them helped you out. cheers!
  31. #3531
    Mar 2014
    Do you guys know if it's ok to use 15wt oil instead of 0w30 in Pike lowers?
  32. #3532
    Quote Originally Posted by nathanbal View Post
    Can't wait to hear about the differences. Is the X2 going to be a long shock or standard 51mm?
  33. #3533
    Reputation: 8 1/2's Avatar
    There you have it just waiting for the official release..
  34. #3534
    Quote Originally Posted by yuppie View Post
    Rear Shock
    Wheelset
    Drivetrain
    I will give an opinion here, but it is just that, my opinion.
    First do not pay the premium for Enve unless you just have to have Made in the USA. They are not as durable as LB/Ibis and provide no additional performance despite the massive increase in price. I would also stay away from Roval unless you are a lighter/less aggressive rider. While durable they do flex quite a bit (not in a good way) which makes for difficulty holding lines in rough, fast or off camber sections. My personal choice (having owned Derby/Enve and LB) is Light Bicycle laced up to your hubs of choice. For $1700 you can just about get two sets, one 29 and one 275+, brand new or just one set and have enough left over for your shock upgrade.
    On the shock upgrade, it depends on what you are looking for. The Topaz is a nice shock, similar to the Float X. Great balance for an all around Trail shock with slightly more tuning options stock. X2 will provide a much more plush feeling on the descent, but is definitely more active on the climbs. Where I ride it is a huge benefit since it absorbs a lot of the chatter going uphill and also provides a lot more traction. I do 4K climbing days on my X2 without ever flipping the climb switch so it just depends on what you are looking for.
  35. #3535
    Quote Originally Posted by 8 1/2 View Post
    Very interesting, 160 fork and an obviously non stock rear link.
  36. #3536
    Jul 2016
    Is that just somebody's bike check or what's going on here?
  37. #3537
    Quote Originally Posted by Salespunk View Post
    Not quite that Miami Vice scheme...
    Getting touch-up paint might involve some...work! HAH!
    ╭∩╮( º.º )╭∩╮
  38. #3538
    Quote Originally Posted by sparkyCO View Post
    Giving away a Hightower EWS replica. Setup with a 160 fork and other parts they won't talk about.
    Sent from my SM-G920V using Tapatalk
  39. #3539
    Saddlebag for the HT?
    Anyone running some form of saddlebag w/ the tire to saddle clearance of a fully squished down HT? Or, is there some form of a frame bag that'll fit in the small area right behind the head tube and in front of the shock mount, and between the top and down tube?
    ╭∩╮( º.º )╭∩╮
  40. #3540
    Reputation: schuster.ryan's Avatar
    Oct 2011
    [QUOTE=Pau11y;13092555]Anyone running some form of saddlebag w/ the tire to saddle clearance of a fully squished down HT? Or, is there some form of a frame bag that'll fit in the small area right behind the head tube and in front of the shock mount, and between the top and down tube?
    You could use the Valais dropper mounting point which subtracts 25mm and might provide sufficient clearance for a small saddle bag. Valais 25 ? wolftoothcomponents.com
    Santa Cruz Hightower CC 27+
    Soma Double Cross
    (hoping to get a 29/27+ hardtail)
  41. #3541
    Reputation: alexbn921's Avatar
    http://cyckit.com/products/
    seat bag that will fit.
  42. #3542
    Dec 2013
    Rear Shock
    Wheelset
    Drivetrain
    see me about a deal on brand new DTSWISS XM1501 30mm width with Freeza Rotors
  43. #3543
    EC3
    EC3 is offline
    Nov 2016
    My pedals were clogged with ice the other day so i did the slo-mo lay down in a techy section as I hopelessly tried to eject. Of course a sharp rock went right into the front triangle. I'm not usually that concerned with scratches but it left three large ones right on top of the downtube. Looks like chaulk on a blackboard.
    Anybody have a touch-up idea for this? I thought I saw where someone sanded it with fine grit. Is this a good idea?
  44. #3544
    Looks to me like they're still using a 200x50 shock with longer lower link and fixed shorter upper. Based on my new spider moving that upper alone may do the trick and add ramp up at the end.
  45. #3545
    Oct 2011
    I used the SWAT Bandit and it buzzed the tire at full compression. My dropper post seems to be at a similar insertion height as the one in your picture. Keep in mind I was uzing 27+ and low setting. I need to try the high setting.
    Soma Double Cross
  46. #3546
    Mar 2017
    I'll bet that's the new linkage which will allow officially to install longer rear travel suspension.
  47. #3547
    Dec 2013
    Quote Originally Posted by Grizzy View Post
    i kind of agree. But i think travel numbers would only be bumped to around the 140-145range per my unscientific unjustified guess. i think because of the fixed link position they didnt need to use the longer stroke shaft and just stick with a dedicated 50mm stroke.
  48. #3548
    Quote Originally Posted by schuster.ryan View Post
    That pic was taken w/ the chip in low setting, but w/ an additional 3.4mm in i2i length via offset shock hardware.
    ╭∩╮( º.º )╭∩╮
  49. #3549
Name:	Seat to wheel - saddlebag clearance.jpg
    Alpine Threadworks Ltd.: Performance Satchel
    Most of my crew is running this and very happy...but we are local to him.
  50. #3550
    Dude, you are the MAN! That is exactly what I'm looking for! Thanks! I guess I better get it soon before Cheetolini repeals NAFTA!
    ╭∩╮( º.º )╭∩╮
  1. Stolen Santa Cruz Tallboy - XXL Carbon, Santa Cruz, CA - 12-8-15
    By jasonpriz in forum California - Norcal
    Last Post: 12-16-2015, 08:57 AM
  2. Replies: 7
    Last Post: 01-08-2015, 07:06 PM
  3. Replies: 4
    Last Post: 05-06-2013, 11:47 AM
  4. Replies: 4
    Last Post: 01-21-2012, 08:04 AM
  5. Replies: 9
    Last Post: 01-16-2012, 01:04 PM
