Results 1 to 22 of 22
    Reputation: jazzanova's Avatar
    Santa Cruz frames real weight.
    Does anybody know real weight of carbon Solo and Branson? Medium or Large?
    Feel free to post any other frame weight...
    I just weighted a medium orange solo 5:12 and M Black Bronson was 5:14 = 5.87lbs, both carbon. Very close indeed... I would like to confirm the readings.
    Paint is heavy. I read somewhere that it is 1/4 lb for the TBLT.
    Reputation: JHwick's Avatar
    Had a large black/orange Bronson. It was 2,510g for the frame and regular CTD shock (no thru-axle or anything else).
    For comparisons sake, a large black Pivot Mach 6 frame/FloatX shock is 2,881g.
    Not had a 5010 but the Bronson is very light for a 150mm 27.5 bike.
    My yellow medium Bronson carbon with thru axle, Fox CTD shock and seat clamp weighed in at 6lbs.
    Feb 2007
    Quote Originally Posted by jazzanova View Post
    5:14 = 5.87 lbs ????
    Re: Santa Cruz frames real weight.
    Quote Originally Posted by burpp View Post
    Yup, 5lbs 14oz = 5.875lbs for M black Bronson.
    5lbs 12oz = 5.75lbs for M orange Solo.
    I asked the shop to weight them and they gave me the readings in oz...
    Feb 2007
    I asked the shop to weight them and they give me the readings in oz...
    thx I wasn't reading the ounce part ! if that's correct, way different than sc claimed weight of 5.3 lbs for the Bronson and 5.03 lbs for the 5010
    5.15 lbs large black 5010, CTD TA shock (includes derailleur hanger and headset cups, no axle or seat clamp)
    62 g DT axle
    47 g seat clamp
    5.39 lbs large black 5010, CTD TA shock (includes derailleur hanger, headset cups, axle and seat clamp)
    chasing simplicity
    Reputation: MattMay's Avatar
    Dec 2013
    New out of box 5010 Carbon Medium, (note/edit: black frame) with Float CTD Kashima, weighed w UltraSport 50 digital hanging scale:
    With DT axle and seat clamp: 2280 g (5.03 lbs)
    Removed axle and seat clamp, weighed on postal digital scale, same as wheatgerm's above:
    Axle: 62 g
    Clamp: 48 g
    Removed shock (sending to PUSH), weighed without bolts: 268 g
    Weighed bolts: 36 g
    Quote Originally Posted by MattMay View Post
    New out of box 5010 Carbon Medium, with Float CTD Kashima, weighed w UltraSport 50 digital hanging scale:
    Axle: 62 g
    Clamp: 48 g
    Weighed bolts: 36 g
    Orange or black frame?
    Sent from my KFTT using Tapatalk 2
    chasing simplicity
    Dec 2013
    Black frame. Will edit above.
    Reputation: KrisRayner's Avatar
    Any actual weights on the alloy Bronson?
    Dec 2011
    L Tallboy2 Alu= 7lbs 00oz
    weighed with seat post clamp and shock. no headset bearings or cups
    Reputation: reformed roadie's Avatar
    Quote Originally Posted by KrisRayner View Post
    ^^^ this. Shopping now…curious about this.
    May 2005
    Axle: 62 g
    Clamp: 48 g
    Weighed bolts: 36 g
    MattMay: so the black 5010 frame alone weighs 1866 g?
    2280 g (frame with shock, shock bolts, DT axle and seat clamp)
    - 62 g (axle)
    - 48 g (seatclamp)
    - 268 g (Float CTD shock)
    - 36g (shock bolts)
    =1866 g
    Is this correct?
    Thank you
    chasing simplicity
    Dec 2013
    Correct.
    I know what it's like to be dead. "To Die & Live In LA."
    Reputation: giantdefy's Avatar
    Jun 2010
    Had the Aluminum bronson frame weighed at 6.8lbs.
    Quote Originally Posted by giantdefy View Post
    Which size?
    Jul 2013
    Hmm... my medium black carbon weighed 2330 grams with DT Swiss Axle (62g) , Direct Mount dropout, mounted shock, and seat QR (46g). That's 5.13 lbs. (5 lbs., 2 oz.) total. All weights were done on a very accurate lab scale.
    I forgot to weigh the dropout before installing but I'm sure it weighs more than the standard one.
    Medium black carbon... But which bike are you talking about?
    Jul 2013
    sorry... 5010c
    Reputation: LCBooger's Avatar
    Apr 2014
    I have an Aluminum Bronson just on the brink of sub 30lbs. It's at 30.18lbs as of now.
  1. Replies: 0
    Last Post: 12-29-2012, 11:36 AM
  2. Anyone looking for a deal on Santa Cruz frames?
    By Pau11y in forum Colorado - Front Range
    Last Post: 08-21-2012, 07:28 PM
  3. Santa cruz frames???
    By 918biker in forum Santa Cruz
    Last Post: 12-28-2011, 03:46 PM
  4. Santa Cruz phasing out Aluminum frames?
    By jpk1080 in forum Santa Cruz
    Last Post: 09-19-2011, 09:21 PM
  5. Santa Cruz Frames?
    By Tamim in forum Santa Cruz
    Last Post: 05-23-2011, 01:13 PM
