Results 1 to 30 of 30
Thread: RP3 for Heckler
    RP3 for Heckler
    Has anyone thought about putting the 7.875 X 2.25 RP3 on the Heckler?
    I know they have that size for the Blur LT and Tim from SC says it would fight fine (or was it Josh?)
    Spam to follow, I've placed a classified on the site looking to swap my DHX Coil 5.0 (same size) for the RP3, or sell it. Mine has less than 400 miles.
    Santa Cruz says...
    It's not a recommended shock for the Heckler, it does work but it's not the right tool for the job.
    A DHX Air with all the bells & whistles would be a better option for you and not too much heavier than the RP3.
    ok, another question then..
    Ok, so why isn't the RP3 the right tool for the job? Would my medium 05 Heckler frame accept the DHX air? I read something about dimples on the 06 to accomodate the DHX air.
    Thanks a million
    Reputation: Sway?'s Avatar
    Feb 2006
    Quote Originally Posted by velez3000
    Thanks a million
    I see no dimples on my 06 frame..
    Quote Originally Posted by DMFT
    I disagree.
    I've had an RP3 on my Heckler for awhile now and am quite satisfied with the performance('03 frame w/ 7.875"x2.0"). I also have a Progressive 5th Element coil that came stock. I purchased the RP3 to lighten things up and to improve overall XC and trail performance. It all depends on what ride characteristics you're trying to achieve. A coil is obviously better suited to rougher terrain, drops, etc., but the RP3 is a great all arounder performer IMHO. I am leary of trying a DHX Air right now because of the less than favorable feedback I have heard and read on this and other forums. I would much rather use a DHX coil or a Marzocchi Roco coil if I desired a more freeride/all mountain setup and take the weight penalty, just my .02.
    Fox Float R
    Since the Heckler comes with the Float R as an option, why wouldn't the RP#3be a good choice........anyone?
    I feel the RP3 is a great choice and that is why I currently have one installed on my Heckler. I have found it to be a good lightweight option to make your bike more versatile for xc/trail applications. The 3 ProPedal settings are great for overall xc trailriding/climbing/descending and I have had zero reliability issues thus far. I don't know why anyone would say that this is not a good shock option for the Heckler. I have found it to perform well on my Heckler, as well as my Blur. Go figure.
    Sep 2004
    Quote Originally Posted by Duh-luth
    I disagree.
    I've also been using an RP3 on my 2005 Heckler. It replaced the heavy and sluggish feeling 5th coil (whose rebound blew after the third ride). I will admit I am not much of a suspension tinkerer, but I've been very happy with the RP3. It's given the bike a livelier feel and helped shed more than a pound. I ride a little of everything and althought I've bottomed out the RP3 a couple of times, it's seems to be running just fine after 500+ miles.
    I thought about the DHX air, but that seems to be overkill in an air shock. Plus, the RP3 allows me to squeeze a bottle in the front triangle for those shorter rides when a Camelback just isn't necessary.
    I disagree.
    - That's fine, we all have opinions & different experiances....
    - The RP3's (not all but many) are having the same issues. Fox has sent memo's to pretty much every customer of theirs on this issue.
    Here's why.
    The RP3 does not have quite the same air volume as the Float R, and it's Pro-Pedal feature is custom valved from Fox to deal with the leverage ratio. The aftermarket RP3's can and do work, they just are not as tunable as the DHX Air. The DHX Air also helps to cover up some of the negative traits of the single pivot.
    Spoke to Fox racing
    Allright, the guys at Fox said the RP3 would work great on the Heckler. My LBS can get me the shock in the OEM 2.25 size. DMFT they did mention the tunability of the DHX air would let me get the plushest ride but I'm not much of a suspension tnikerer.
    Fox racing was super helpful. I spoke to the dept that deals w/ manufacturers and even though I wasn't buying from them he spent 10 minutes on the phone with me giving me the in's and out's. I feel bad for forgetting his name
    I'll make sure to report back with the experiment. Thanks for all of your feedback....LONG LIVE THE HECKLER!!!!!!!!!!!!!!!!!!
    Ultimate Poseur
    Reputation: moff_quigley's Avatar
    I'm quite surprised that Fox is willing to sell you a "custom" RP3 with the 2.25 stroke. It's not a normal size that they offer. There was a guy on the board not too long ago that couldn't get Fox or SC to sell him the OE High Volume RP3 (7.875*2.25) to fit his BLT.
    I think running the RP3 would be sweet. Personally, I would run the 2" stroke for 5" of travel though. Another option and the one I'm likely to pursue would be a "Pushed" Float R.
    According to the dialogue that I've had with SC you'll want to avoid the "high volume" version of the RP3 as well.
    Reputation: PUSHIND's Avatar
    Almost ready for prime time. We're just waiting on one last produciton piece for our "Heckler" long travel kit. With this kit, we'll be able to take a stock 7.875" x 2.0" Float R, or Float RP3 and convert it to a 7.875" x 2.25". The kit will also include a Heckler specific "air volume disc" to adjust the air spring curve to optimize perfromance. The long travel kit will add $34.95 to the price of either our Factory Rebuild, or Factory Tuning System packages.
    Darren
    Got A Lust for Life...
    Reputation: indyfab25's Avatar
    Good job! Well now...
    Quote Originally Posted by PUSHIND
    Darren
    I know what my next shock will be. I have a float r sitting here unused. Apparently, not for long.
    I am immune to your disdain.
    ahhh man....
    Nah, Fox or SC isn't selling me the the 2.25 RP3, My lbs is hooking it up. But How do I know it's the high volume version, can that be specified.
    And then all this PUSH goodness comes up!!!!!!!!!! I'm confused
    Will I be able to buy the heckler RP3 from PUSH or do I buy the normal 7.875 x 2.0 and then send it in to get PUSHED?
    Thanks guys
    Could always pick one up used on ebay cheap...use it...and have it PUSHED when it needs it.
    Ultimate Poseur
    Thanks guys
    The high-volume version has a noticeably larger shock body. You don't want to get the high-volume version. Unless your shop is able to pull some strings or call in some other favors they aren't going to be able to get a normal or small volume RP3 with the 2.25 stroke either.
    If I was you I'd see if your shop really can come through with a 2.25 RP3 for you. If not source a new one from them or find a used one, with 2" stroke, and send it to Push if you really need that .25 of stroke.
    Either/Or. We'll be offering a complete kit for your existing shock, or you'll be able to purchase the 2006 Float R, or RP3 with the kit installed from us.
    Due to the linear leverage rate of the Heckler, a high volume air sleeve is not recommended. We actually reduce the volume of the stock air canister in order to get the spring curve necessary.
    Darren
    Ultimate Poseur
    Darren...is this "air volume disc" user adjustable? On the fly? Can you get this without lengthening the stroke? I don't really think I need the extra .6" of travel a 2.25" shock gives.
    Sep 2004
    How would this PUSH upgrade compare to the performance of the DHX-A on the Heckler? I have the original Float RL sitting in a box and might be interested...
    Darren, would this kit be useful on a 2003 Fox AVA RL (7,875x2,00)?
    It would be great!!!
    Bye
    Meduix
    No, it's preset here at the Factory based on your rider weight and style.
    Yes. Our Heckler "Factory Tuning System" will be available in normal and long stroke applicaitons.
    Different. With the RP3, we're able to tweak the air spring curve a little more and can build a speed sensitive compression circuit into the shock. From a tuning standpoint, we're really able to squeeze out big performance in a very lightweight package.
    Yes.
    Darren
    When will be this heckler tuning kit available?
    Quote Originally Posted by mtic
    What he said!
    Please let us know when
    First week of April.
    Darren
    Darren, will that kit be available for european bikers (TFTuned shocks...), and will it be available in Europe the first week of April also...or must we wait....
    I'm from Spain, and I think the closest place to find Push services&products is TFT, in the UK, but maybe I'm wrong and there's a closest one.
    Meduix
    Yes, as with all of our products and services, they will be available within a short period of their USA release. As for TF Tuned, they are currently our only technical center outside of our US facility.
    Darren
    I can't find anything about heckler tuning kit on push website... So, is this kit available now or not?
    Aug 2005
    High Volume Float R
    Would the Heckler Kit work for a 7.875 X 2.25 Fox Float R high volume. I know a high vol float is not recommended for a Heckler (it bottoms out) but you would be able to convert it for use?
    Brent
    Mar 2006
    I am curious also. I originally had a 2005 Fox Float R w/ pro-pedal on my Heckler. I ran the shock for a few months and never got it to feel like i wanted. It was either too harsh on fast rough terrain, or blew through the travel on medium to large hits. I switched to a DHX and have the thing set-up perfectly. I would however like to drop the extra pound off the frame by going back to the air shock. Does it make sense to have my air-shock modified and ditch the DHX. I make a few trips to Snowshoe each year, race a few sport DH races, some super D races and ride fast rocky terrain every chance i get. I also do a ton of backcountry rides up to 30 miles. Will the "heckler" mod on my 2005 Float R be up to the standard as my DHX? Will i still get the 5.6" of travel the DHX provides? Will i be able to set the bike up where it is plush in beginning stroke but resists bottoming out? Or should i just suck it up and deal with the extra pound of the DHX.
