Results 1 to 12 of 12
    May 2010
    Request for CC DBair CS settings for Tallboy LT
    Got a CC DBAir CS on the way. I'd like to get a feel for how other users are setting them up. If you are running a DBAir could you post your weight, PSI and LSC, HSC, LSR and HSR settings. Thanks
    Reputation: cecald's Avatar
    Feb 2010
    Great request. Subscribed.
    Also subscribed. Planning to try one of these out in a few weeks.
    May 2010
    Ok, got the CC DBAir CS installed on my TBLT. I have started with the following settings and so far have not made any changes since:
    120 PSI
    HSC:2
    LSC:7
    HSR:2
    LSR:7
    Which btw is the recommended settings for the Intense Carbine 29er that CC has on their website and is a similar bike to the TBLT.
    Dke, how much do you weigh? I just finished a trip to SW Utah with a demo CCDBACS on my TB LTc. I'll report in with settings and impressions as soon as I get a chance.
    May 2010
    Quote Originally Posted by hillharman View Post
    180 fully kitted
    Feb 2010
    Just got mine mounted up tonight, so let the testing begin!
    Feb 2014
    I started with the Blur LT settings, given that it was also VPP, and also the same 200x50mm shock.
    I weigh 185 with a full pack of water, tools, etc.
    I put 125 PSI
    .5 HSC
    4 LSC
    2 HSR
    5 LSR
    I run a 1x10 with a 42t wolftooth and a 28t chainring.
    I find that I don't benefit too much from a high LSC or LSR given that the climb switch changes both of those settings. If I'm going downhill, I'd rather compress just slightly in banked corners and maintain better wheel tracking on roots. Better wheel tracking for me also = better braking.
    Even with these low settings, I don't bob at all when spinning, since the VPP still activates well with a 28T ring.
    I am an intermediate rider, don't do too many drops, rarely get more than 1.5 feet off the ground. I ride Bay Area trails.
    I have a Pike 150/130 up front, and have found the DB Air CS to pair well with it.
    Insanity later
    Reputation: Serenity Now's Avatar
    Hey, are you all on std or HV cans? I just got a DBAir CS and it blew me away. Only problem is I couldn't get full travel. Needed about 145 psi to get tegu right sag for my weight 200# or so. Even with no HSC at all and some decent jumps to flat I still had travel left over. Maybe I need to drop pressure more but then I start suffering with crank strikes from the low BB.
    Quote Originally Posted by Serenity Now View Post
    Measure the stroke you are getting where the o-ring stops. The LTc uses a 200 x 51mm shock, and the CCDBA-CS in that size is a 200 x 57 with the stroke limited. So you will see some space left between the bottom out and where the o-ring stops. My guess is that you are actually getting pretty close to full travel.
    Insanity later
    Hillharman, Thanks for the tip. Indeed initially I made that mistake, but quickly measured to 51mm to work out where full travel is. Dropping to around 140psi helped, but now I'm getting 16mm of sag which is a bit much. I'll call CC today, but obviously they don't recommend an XV can.
    I'm 225 lb geared up to ride, and with 155 psi in the regular air can, I have no problem getting full travel. Just an FYI.
  1. Tallboy shock/fork settings
    By wakejunky in forum Santa Cruz
    Last Post: 06-02-2014, 05:48 PM
  2. Tallboy LTc DBair CS - anyone riding one
    By gweb in forum Santa Cruz
    Last Post: 10-09-2013, 07:59 PM
  3. Tallboy LTc and Fox CTD settings
    By ejfiii in forum Santa Cruz
    Last Post: 01-02-2013, 06:50 AM
  4. Pressure Settings for Tallboy Rear Shock????
    By bowler1 in forum 29er Bikes
    Last Post: 07-04-2012, 05:13 AM
  5. Tallboy Fork Sag Settings....??????
    Last Post: 07-02-2012, 06:36 AM
