I recently ordered a set of offset bushings for my 06 Mk1 Nomad (using 3/8" shock bolts). Despite pointing this out in the order form, the bushings arrived with a 8mm hole for the shock mount.
Before going back to offsetbushings, is there a quick fix to make this work? Can I simply replace the original 3/8" shock bolt with a 8mm bolt from the hardware shop?
