Page 50 of 58 FirstFirst ... 40 46 47 48 49 50 51 52 53 54 ... LastLast
Results 1,226 to 1,250 of 1437
  1. #1226
    Quote Originally Posted by rglsr View Post
    Haven't even touched dirt yet, but riding around the street it sure feels good. My BB height is just under 13", 12 7/8" or so with a Fox 32 100mm 650B fork. With 34/20 gearing the rear tire is a bit close at the BB, but with some chain stretch it should be better. Or I could drop a tooth and move it back. Up top there is plenty of room.
    just going to ask you the same question.
    I wonder what size your frame is and what length you have on your stem?
    And how tall are you? If you can use cm i would be happy..
    Im thinking of buying one but is between the size M and L.
    Im 176cm tall and is going to use it for xc riding, singeltrack only.
  2. #1227
    Quote Originally Posted by qvick View Post
    I'm 178cm tall, Large frame with a 90mm x 10 degree Thomson X4 stem. Main reason I went 90mm on stem was I wanted the rise. (and I had it laying around) Since the 650b fork is only 100mm travel I wanted the bars higher. I ride this mainly xc/light trails, also since it's a SS.
  3. #1228
    thanks for the anwers.
    looks like a large will be the choice for me then.
    just the LBS who has to get the delivery and i will be running a SC again.
    thanks again.
  4. #1229
    Mar 2013
    Post your lizards. (Chameleon)
    Finished my build today, really happy with the way it's turned out
  5. #1230
    Cool-blue Rhythm my new/old sc chameleon
    Medium 3.0 lime green frame with 100mm fork. Seat tube is 16in and the top tube is about 21.5 to 22in. It came with a straight post (needs a set back), 60mm x 5deg stem (I like), low-rise bars (thinking high-rise can get me more lift). I also want lighter, but strong wheels. I am 5'-9" tall and could fit on a 17in frame but I can get this little lady to pop a wheelie real good. Also, thinking of putting on a pair of 165 cranks that a friend just kicked down.
  6. #1231
    Oct 2013
    Anyone looking at getting one of the 2015 models? I am in the market for a new bike.
    I was wondering if these bikes make good trail bikes? Seems all i see people doing is jumping/pump tracking them.
  7. #1232
    Mar 2013
    Quote Originally Posted by impulse2010 View Post
    The 2015 650b frames look good
    They make a great trail bike and my frame was built up with that intention. I find mine just as capable as my full suspension trail bike and maybe even a bit faster in certain situations. Go for it I say
  8. #1233
    old school no.9
    Reputation: miqu's Avatar
    Here's my not-so-serious XC racebike.
    Some updates since the last year. General Lee 40t cassette adaptor and Mallet DH clipless pedals. I really like the allround Maxxis Ardent 2.25" tires
    I love the smell of the TF2 chain lube in the morning.
  9. #1234
    Mar 2013
    Nice
  10. #1235
    Oct 2013
    Yeah your bike looks great.. I love that color
  11. #1236
    Reputation: JPBakerIII's Avatar
    Mar 2012
    I have a 2011 frame setup for XC / All-Mountain duty. It's a great climber and goes down most single track and trails without much issue. If you are riding mostly smooth trail, it is really fast. The only time I would rather have my full suspension is when the trail is choppy, rocky, and with lots of roots. I threw a drop post on it to make it easier to do steep drops and trail jumps.
    1990 Schwinn Sierra MOS
    2011 Santa Cruz Chameleon
    2012 Cannondale Claymore 2
  12. #1237
    I would say it's a great trail bike. They're built with 120 to 140 forks, 26 in wheels and a 27 speed drive. And notice the rather stout frame with a tapered head tube, ISCG tabs and replaceable dropouts. Not to mention a nice mix of semi-slack geometry.
    I plan on getting one if and when they offer different colors or raw so I can do a custom paint without breaking the bank.
  13. #1238
    Chameleon 3.0
    Post your lizards. (Chameleon)-021.jpgChameleon 3.0
    Attached Thumbnails Attached Thumbnails Post your lizards. (Chameleon)-10487293_691002274282556_7982181977522198834_n.jpg
    Post your lizards. (Chameleon)-10532799_691058910943559_2878220185232079587_n.jpg
  14. #1239
    An afternoon project of 650b
    Bought the Chameleon 5 for less than a year ago, and was quite unhappy that the new Chameleon 6 is finally 650b. But looking at the chainstay, I can see that the Chameleon 5 is very likely to fit 650bs with a 1X setup as the FD might be too close to the tires. So spent an afternoon to confirm.
    The fork is a RockShox Revelation 27.5 with 140mm travel, which gives me the exact same A to C height as a Revelation 26 in 150mm travel, which I have been using. Therefore all the geometry change shall be due to the wheels only.
    The wheelset is the new ENVE M70 with Maxxis Minions 2.3 on them. You can see that there is still more than 10mm left at the closest point, so any decent XC / trail tires with rims less than 25mm internal width should give you even more clearence!
    Post your lizards. (Chameleon)-1919636_10154298073360471_7445860016001204452_n.jpgPost your lizards. (Chameleon)-10455650_10154294030395471_5212056973962060830_n.jpgPost your lizards. (Chameleon)-10478729_10154298076005471_7769933162862709214_o.jpgPost your lizards. (Chameleon)-10479596_10154298074555471_2913278501236201281_n.jpgPost your lizards. (Chameleon)-10509630_10154298074430471_1157387960007358950_n.jpgPost your lizards. (Chameleon)-10533899_10154298074305471_6942889903439178812_o.jpgPost your lizards. (Chameleon)-10535819_10154298072940471_1041839082957694512_o.jpg
  15. #1240
    Mar 2013
    That looks brilliant. Good to know you can get away with the bigger wheels. Would the front mech have come into contact with the tyres?
  16. #1241
    Mar 2012
    How does it ride? Did you measure the BB height? Looks nice!
  17. #1242
    Jul 2014
    New Chameleon Build
    -2012 Large Frame
    -Marzzochi 55cr 160mm Fork
    -SLX groupset
    -Sunringle Charger Expert wheelset
    ----Really fun all mountain bike and aggressive trail rider.
    Attached Thumbnails Attached Thumbnails Post your lizards. (Chameleon)-a0svjch.jpg
  18. #1243
    Oct 2013
    Ddid the 2013/2014 change the angles? Some chameleons look badass while some just look ok to me lol.. Guess i am weird
  19. #1244
    Feb 2012
  20. #1245
    I think it depends on the frame size vs. fork length. SC is now labeling their old medium frame size as small (16 in seat tube), the medium now with a 17 in seat tube. I would guess the tube-set is as burly as ever ... they got ISCG 05 tabs. I really want one cause I totally dig the new dropout ... plus no more creaky eccentric BB. They also look super badass to me when running chain guides, 1 x 9 or just single speed.
  21. #1246
    Quote Originally Posted by RIDEALL View Post
    that's the best hardtail XC / trail bike I ever seen ... I have the same frame and still loving it
  22. #1247
    Oct 2013
    I think the news one are out now. Saw a guy on instagram that had one in pieces from just getting it yesterday. Looking forward to more pic's of it.
  23. #1248
    Feb 2012
    Quote Originally Posted by Number5 View Post
    Thanks!!! Such a fun bike to ride. This will stay with me forever in some form or another. Very versatile.
  24. #1249
    covered in dirt from wet season of tropical country
    Frame: M size MK3
    Fork: X-mission Velvet 140/110mm (140 for descend, 110 for XC with a lot climbing)
    Brake: Trusty old mechanical Avid BB7
    Tyre: Kenda Nexcavator 2.3 (had enuff of puncture running on 2.1)
  25. #1250
    OB Junkies
    Aug 2014
  1. Seat post & Seat rail postion
    By spacoli in forum Beginner's Corner
    Last Post: 09-23-2004, 02:26 PM
  2. Blur seat post shim (30.9mm OD) Anyone make one?
    By CraigH in forum Santa Cruz
    Last Post: 04-15-2004, 09:11 AM
  3. Help with screwed up brake post removal
    By furball in forum General Discussion
    Last Post: 02-27-2004, 12:55 PM
  4. Seat post & Seat rail postion
    By spacoli in forum General Discussion
    Last Post: 01-24-2004, 03:13 PM
  5. Pazzaz seatpost vs. Stock Spec Enduro post weight?
    By phil. in forum Weight Weenies
    Last Post: 01-21-2004, 05:49 PM
