Results 1 to 25 of 25
    Mar 2013
    Old School Santa Cruz Heckler
    Hey guys I'm new to the forum and looking for some advice.
    I've had my Heckler for about 13 years and still love it to bits.
    However I'm looking to upgrade some components and wondered where would be a good place to start?
    All the chain and drive shift mechanisms are in good condition and so I am not looking to replace these.
    I'm really a weekend rider and as I have other hobbies I am looking to do this within a reasonable budget if you know what I mean.
    I'm a total newbie when it comes to bike parts and repair so I took it to my local bike shop yesterday to have the front derailleur set up properly and while he was doing this the guy said that the back end has gone and needs a new wheel bearing. I wasn't too sure what he meant so did some research and I think he may mean the bottom bracket (I've put an arrow on the picture)? Any ideas where I can get a part for this and how it needs to be installed (I'd like to start learning how to maintain and fit new parts to the bike myself)?
    In terms of upgrades I'd like to get an air suspension part for the rear suspension - which ones would fit and what do you recommend?
    As I'm starting to take mountain biking more seriously I want to go clip less. I've taken a photo of my current pedals - can these be converted so I can clip in? The look similar to the Shimano SPD M324 ones but don't have the middle bit in which the shoes clip onto - can this be purchased separately?
    Thanks in advance
    Attached Thumbnails Attached Thumbnails Old School Santa Cruz Heckler-wp_000070-1-.jpg
    Nov 2012
    The arrow is pointing to your suspension pivot. The only thing replaceable in there is a bushing.
    The bottom bracket is where your cranks rotate in the body of the frame and connect to the chainrings.
    If he said "the back end has gone and needs a new bearing" that means that the rear wheel's hub needs to have its bearings repacked. You can do it yourself but by the time you're done buying the tools and learning how you're probably better off having the shop do it.
    As for the pedals, unfortunately you'll need to buy completely new pedals (and I would do it anyway). If you want something with platforms that you can also clip into, the PD-M324 (Shimano PD-M324 Pedals > Components > Pedals, Cleats, Toe Clips, Straps > Pedals | Jenson USA Online Bike Shop) may be a good choice for you because it has a platform on one side and clip on the other, and it can be had for only about $50.
    Good luck!
    Mar 2013
    Thanks for the response.
    I will order some of those pedals.
    He actually pointed to the suspension pivot point and said the bearing needs replacing. He basically just pressed down on the seat - what was noticeable for him to make this comment? He didn't explain it very well.
    Any ideas on how to replace it or get a part from?
    Do you know what rear suspension would fit this model?
    Also the front forks are Rock Shox Judy XC - they have two holes for brake disc mounting - would it be easy to convert the front to a hydraulic brake disc system?
    Nov 2012
    At this point I'd have the shop work on it - sounds like you're not terribly well versed in this stuff and suspension pivot maintenance is not something you want to do wrong. Ask if you can sit in on the repairs and learn how to do it yourself for next time maybe.
    For the record, though, yes, you can order replacement bushings and pivot parts from Santa Cruz.
    As for mounting brakes, it's certainly doable, but if you haven't installed them before you might be in over your head. They're relatively intricate systems. The mental pain you'll save having a shop would be worth it, imo. Again, ask if you can sit in.
    Reputation: BacDoc's Avatar
    Your bike has V brakes - keep them! Discs are better but in your situation you would need new wheel with rotor mount and the expense is not worth the return.
    The mechanic probably noticed some play or clicking on cycling the suspension but I think that same symptom can come from rear shock bushing. If you replace the rear shock and bushing this might fix it. A decent rear shock can be picked up on the web/eBay for under $200. You measure eye to eye and off the top of my head think that may be 6.5" or about 200mm but you need the exact measurement.
    My advice, if you really like the bike, replace rear shock and get new brake/shifter cables and maybe some new tires and that Heckler will rock! At the time your bike was and is a very competent all round MTB.
    Singletrack Slacker
    Reputation: Heckled's Avatar
    The rear suspension actually has a cartridge bearing, not just bushings. They are easily replaced, just a pinch bolt to loosen and they pop right out. I had a 98 heckler that i loved, awesome ride. I took out the bearings and took them down to a local bearing supply. They said the OE bearings were junk and gave me something they claimed were 10x better, $10 and lasted another 5yrs.
    I need to ride moooore
    Reputation: reamer41's Avatar
    I believe the rear shock length is 7 7/8" with a 2" stroke. Should be plenty available.
    --Reamer
    I'm actually looking to buy a 2000 heckler - call it nostalgia from my college days. What do you guys figure a 2000 heckler mid range spec is worth these days?
    Reputation: sooner518's Avatar
    Quote Originally Posted by gringopapo View Post
    depends on condition/parts, but a couple hundred bucks if you can find one.
    old school heckler
    Since I chimed in about buying an old 2000 heckler I thought I'd followup. I found an XL dark blue 2000 heckler here local. Here's the specs:
    Front shock-marzocchi bomber flylight 100
    rear shock-fox float rc
    Headset-chris king
    wheels-bontrager maverick
    Hubs-shimano deore lx
    crank shimano deore lx hollowtech
    Front derailleur-sram 9.0
    rear derailleur-sram 9.0
    grip shift shifters/brake levers-sram 9.0
    brake calipers-avid arch rival 40
    saddle-bontrager
    Its pretty worn out and I had to adjust the stem and seat position (the guy who owned this previously must have been about 6'7" with everything in his torso). I picked it up for $200.
    Quiet Professional
    Reputation: chef7734's Avatar
    Re: Old School Santa Cruz Heckler
    Congrats. I know how you feel on the nostalgia part. I am looking for a 2003 giant ac2.
    Sent from my Transformer TF101 using Xparent BlueTapatalk 2
    Rubber Side Usually Down
    Reputation: Mr Crudley's Avatar
    Phwoar, bargain, great deal.....
    That high altitude stem and seatpost looks wack, he must have left MTB'ing for basketball.
    'Geez, I wish I had a witty signature'
    Jun 2013
    Hey this is my first time posting, I have used this forum for countless mountain bike wisdom over the past year or so. Right now I have a piece of dump bike, it's done well but I'm ready to get deeper into this sport. I am looking and an older heckler, Im not sure what year it is and I was wondering if you guys could give me a clue.Old School Santa Cruz Heckler-3ea3l63nc5e65f55m4d6363e8ca33ae861abe.jpg
    Quote Originally Posted by Vdubbus View Post
    I am looking and an older heckler, Im not sure what year it is and I was wondering if you guys could give me a clue.Click image for larger version.
    Looks to be about a 2001 or 2002 model in Large size. The swingarm is the rising rate one that this came shortly after the one in the link below which is similar to the same vintage as mine.
    Santa Cruz 2000 Heckler X Full Suspension Bike Reviews
    My Big Blue with bonus cat that is also into bike pr0n.
    The rear shock looks like a Fox Float. You can fit any shock in there as long as it is 200mm eye-to-eye in length. I've had a Fox Vanilla, Fox Alps, Fox AVA and not a Fox RP23. The flexibility for shock swappage great.
    You'll love riding that one
    I wonder if this old thread can still get some traction for us vintage folk.
    Question for you guys on stroke length. I believe the stroke length was stock 2" for the 2000 - 2001 Heckler. Will a 2.25" stroke shock interfere with the tubing? I'm looking at a 2.25" vanilla RC for my 2000 heckler (pics posted above).
    I think that it would interfer since 51mm/2" is the stroke length. I'd guess any longer would allow the swingarm to compress too much and end up hitting the seat tube.
    So I did some more lookin on the net and found that Santacruz has some archives of their old hecklers.
    Regarding stroke length, interestingly, the version 1 and 2 had a 2.25" stroke coil but then the version 3 only had a 2" stroke air option.
    version 1:
    Heckler .1 1996-1997 | Santa Cruz Bicycles
    version 2:
    Heckler .2 1997-1999 | Santa Cruz Bicycles
    version 3:
    Heckler.3 | Santa Cruz Bicycles
    My year falls under a version 3. One difference between the version 1,2 and 3 was that they went from a leverage ratio of 1.9 to 2.
    I looked at the clearance of the rear tire on my version 3 and I really don't think that extra .25" of stroke is going to interfere.
    So I decided to try it. I'm going to get the Vanilla RC on it (old school shock for an old bike) and report back to you guys.
    Good find - great links. I have V1 and V3 which is my main ride. V3 specs mentions 200mm/51mm. Hopefully the extra 6mm of the 57mm stroke won't interfer.
    Let us know how it goes. I always loved the feel of coil shock.
    So a 2.25" stroke shock works just fine. No clearance issues. Plenty of tire clearance and no other interferences (not even close). 2.25" stroke = 4.5" of rear wheel travel. It's odd that Santacruz said it wouldn't work. I suspect its because I believe they only had an air shock specced for 2000-2001 and that's just what their literature says - 2" stroke only (for air shock).
    Now I've got to figure out how to get a 1.25" ID 450# spring...
    Good to know.
    I have a few varieties of 200mm shocks so I'll have to pass on the 4.5" of travel.
    I remember the air shock was only spec'ed for the early Superlights that had the falling rate swingarm. See link below for the details.
    The History of the Superlight - NSMB.com
    Look for a cheap Ti coil if you can. That would be nice way to go for coil over if it can had for 'cheap'.
    Nov 2007
    Good info on here. Any idea as to the difference between v1 Heckler and V1 superlight? I'm trying to figure out what this is:
    Cycologist
    Reputation: chazpat's Avatar
    Quote Originally Posted by eporter View Post
    The Superlight was developed to be a lighter weight Heckler and I guess it was one of those "working name stuck" deals. Both V1 versions were 100mm bikes. I think the Heckler normally had a coil spring over shock as in your photo whereas the SL did not.
    That photo is not a SL and probably not a Heckler either, unless it is a really old one; I've never see that type of shock mount and the rear triangle is different, unless it is a pre 1999 that I'm not familiar with. But I don't think that would have disc mount, the 1999 SL did not.
    I imagine someone else here will be able to ID it.
    There are two types of people in this world:
    1) Those who can extrapolate from incomplete data
    Nov 2007
    In looking at the first old Heckler pic in this thread, I realize this isn't V1. V1 had the straight top tube, and this one is bent.
    That shockmount just has black duct tape on it, so it's a lot like the one in this pic:
    v2 Heckler:
    Just can't tell what the differences are with the v2 heckler, and v1/v2 Superlight? For ID purposes, it looks like a V2 SL has the angled/offset shock mount at the top of the swingarm.
    v1 superlight
    v2 superlight
    Also, all these frames had disc tabs, and canti/v posts. You can see the tabs in the above pics.
    Last year I rebuilt & upgraded an old 2001 Juliana SL XTR for my girlfriend with a new fork, disc wheels, BB7 discs, wider bar, etc. It was of the era of really just being an XSmall superlight. Great old bikes!
    Cycologist
    Post #20 above has a history of the SL, the first year did not have disc tabs. I actually have my old one that my son rides, it has discs so it is a 2000 or 2001. On the V1 SL, the small and mediums had straight top tubes, large and x-large had bent top tubes, not sure about the Hecklers. Interesting that the Julianas had a bent top tube, for more clearance for the ladies I guess.
    I think it is a Heckler since it only has a down tube gusset near the head tube. I'm pretty sure the SL's have a gusset on the top tube and down tube near the head junctions.
    Kibd of looks very similar vintage to mine.
    Sent with added typos from a tiny mobile keyboard and spellchecker that makes a mess of everything.
  1. Santa Cruz Heckler - Talk to me
    By Horacek in forum General Discussion
    Last Post: 12-17-2012, 09:38 PM
  2. Santa Cruz Heckler Build, my first AM set up.
    By JookupVandetti in forum All Mountain
    Last Post: 06-29-2012, 03:09 PM
  3. Santa Cruz Heckler or HT 29er
    By motoroilmccall in forum General Discussion
    Last Post: 03-27-2012, 08:49 PM
  4. Giant Trance X4 or Santa Cruz Heckler XAM
    By Musichead13 in forum Bike and Frame discussion
    Last Post: 04-24-2011, 12:16 PM
Members who have read this thread: 4
