    offset bushings on a 650b Nickel?
    Can anyone confirm if you can use offset bushings on a Nickel and still have enough clearance?
    There's not a ton of room in the rear as it is. Will the offset cause the tire to rub the seat post? Will I be limited by tire choices?
    guess no one has tried this
    Jun 2012
    I guess it depends on the tire you are using. I have an 27.5x2.25 Ardent on the back and I have about 1mm of clearance at full bottom out. I assume you could do this with a travel limiter in your shock.
    Hoping not to reduce the travel. 125mm is where I would like to keep it. I guess this probably is not feasible.
  1. Offset Bushings, Yay or Nay??
    By curbhuck in forum Ibis
    Last Post: 04-20-2014, 12:05 AM
  2. Offset Bushings.
    By rpm100 in forum Nicolai
    Last Post: 04-19-2013, 07:38 AM
  3. offset bushings
    By fua in forum Turner
    Last Post: 03-17-2013, 04:01 PM
  4. The One AM with offset Bushings
    By gavind in forum Canfield
    Last Post: 02-27-2013, 10:38 AM
  5. Offset bushings?
    By twebeast in forum Ibis
    Last Post: 05-31-2011, 05:18 AM
