Results 1 to 12 of 12
    Nomad vs Pivot M6, HDR and E29
    XPost from Pivot forum
    A lot of people have asked for my feedback on this since I have both bikes. For a little history I like to try the newest hot bikes out on the market and am fortunate enough that I can get the bikes I want and have them simultaneously. As for me I am an over 40 guy who started racing BMX at 13 and got my first MTB in 1988. Today I am fast enough that I can stay in the top 5 on any local descent, but I am more about having fun. My preferred trails are fast a rocky descents. About a year ago I was on my trusty Mojo HD which was a fantastic introduction to what an efficient long travel bike was like. That bike was a revelation for me and I realized that there was merit to the newer geometry, carbon etc.
    After being on that bike for 2 years I was big wheel curious. I have tried demo'ing bikes in the past, but for me it is completely worthless. Riding a bike for 45 minutes with a stock build and marginal suspension setup at best told me nothing about how much I liked or disliked a bike. Because of this I went out and bought an Enduro 29 while I still had my HD. I created my ideal build on that bike and rode it for 3 months. Outcome was 29'rs are not my thing or it was just too radical a change from my HD. What I found over those 3 months was that "feel" means nothing in terms of speed. I am a Strava geek and my testing showed that there was zero difference in speeds based on wheel size. On every type of segment my HD and E29 were less than a second apart. That includes long smooth fire road climbs, tight rocky twisting descents and everything in between. Before everyone starts jumping up and down saying that 26 sucks, 29 rules and 275 is better than both, make sure you step up with actual hard data. I don't care if it feels faster someplace or if your times improved after a month. Show me back to back days on two wheel sizes running the same tire setup, riding the same trails that you already know on both and then I will start to listen. There is way too much disinformation out there where someone switches to a new bike that is 4 lbs lighter and is running XC tires and then they exclaim how much faster it is than their old rig. Well no kidding!
    So onto the bikes. I came onto my M6 from my HDR which had replaced my HD. I found the M6 to be better in every way compared to my HDR. The progression in geometry was significant along with the Pivot implementation of DW on the M6. As a side note I do not like the M5.7 or Firebird and not a Pivot fanboi. The M6 is much more stable at speed, but also changes direction better than the HDR. The only word I can think of that describes the M6 accurately is AWESOME. I can throw down fast times on the descents and still stay in the top 10% on the climbs. My build is definitely on the more burly end of the spectrum with Derby carbon wheels, Pike 160, 750 gram tires because anything lighter gets destroyed within a week, etc.
    When the Nomad came out I was very excited about the geometry, but not excited about getting on a VPP bike again. Prior to my HD I was on an Intense Tracer and I found the differences in suspension to be significant. From a geometry perspective I do not buy into the wide bar/short stem idea that I should be running a 35 mm stem with 800 bars on a bike that has the same reach measurement as a bike that ran 600 bars with a 90 mm stem. My current preference is to run 740 bars and whatever stem feels comfortable which is an 80 mm on my Pivot. My bikes have also gotten progressively more slack with the final iteration on my HDR being 65.5 and my M6 virtually identical. The Nomad at 65 is exactly where I think things will stabilize and the increased reach measurement would allow me to run a 60 mm stem comfortably. Overall I think that SC nailed the geometry on the Nomad.
    When you get on the Nomad the first thing you notice is that the bike feels BIG. Second is that you feel like you are in the bike instead of on the bike. Overall it feels like my E29 with smaller wheels mounted in the parking lot. Where the M6 feels like an offroad buggy that you can throw around at will, the Nomad feels like a Truggy/Class 8 truck that destroys anything in front of it. I thought there was a lot of hyperbole around the new Nomad when it came out and everyone was raving about the bike just charging downhill. I was wrong, it is not hyperbole. The acceleration out of corners is simply shocking and I have been carrying way too much speed into corners and blowing through them. In corners you do have to manhandle the bike much more. It is not a scalpel, but instead a samurai sword. The harder you push it the better it responds and I have to modify my riding style to accomodate. With the M6 it feels very balanced and responds to every input. With the Nomad I have to smash the outside pedal into the ground and throw it around the corner by the scruff of its neck. Completely different style between the two. Climbing is where I thought I would see the biggest difference, but descending is night and day, not because of speed, but because of style. As of right now the Nomad is the faster descender. I have been taking 5-10 seconds off my fastest times when riding the Nomad even though my fitness is not up to par right now.
    When it comes to climbing I would have thought the M6 would blow away the Nomad by the way it feels when riding, but again the data shows differently. SC has done an outstanding job modifying the leverage curve with this bike and it has a very DW like feel. It does not have the snappy feel of the M6, but it has been showing faster times on the climbs. Think of it as a big turbo diesel vs a small high revving V8. Again I am setting PR's going up so at a minimum there is no penalty for the descending capability.
    So overall right now it sounds like the Nomad is killing the M6, but that is not really the case. The differences climbing are pretty small. The descending difference means it takes a completely different style of riding where you have to be much more aggressive. For the rough terrain we have local to my house it is faster/funner right now, but for most areas and riding styles it may not be more fun and that is what really matters for most of us.
    One last note, I only have 2-3 real rides on the Nomad right now after getting the cockpit and suspension setup. I will continue to add to this thread, but as usual let me know any specific questions you may have.
    Pivot Pics
    Nomad Pics
    No action pics yet since I only have a few rides.
    Nice review sp!
    Reputation: expatrider's Avatar
    Jun 2010
    Good review. Which would you choose for the bike park?
    Reputation: davemk's Avatar
    Jan 2009
    Nice review, I agree completely. I am 6'3" and just under 200 lbs, I was planning on buying a M6 before the nomad came out. Both are great bikes but the nomad is a better fit for me and my riding style. Best bike I've ever ridden.
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    You guys are just making my decision for nomad easier and easier!!
    Bender to AZDog: I'm not the best person to give advice on not riding!
    Quote Originally Posted by expatrider View Post
    Nomad for park work hands down.
    Reputation: ScottW's Avatar
    I think you're right on with the review. I came off a Mojo HD which I loved and is a great bike. The Nomad climbs every bit as well and is plusher through the rocks when descending. I was concerned about a 65 head angle until I rode the bike, it's no problem climbing and this bike does get scary fast on the descents.
    I was interested in the Mach 6 but was put off by the cable routing and horrible graphics. The Nomad is very clean looking and the cable routing is great for me.
    I agree with you on the cable routing. It sucks on the M6 and the Nomad is the best I have seen yet. Since I am down with an injury I let my buddy ride it. He is currently on an HD 275 and he was shocked by the climbing ability as well.
    I have made the same move from Mojo HD to Nomad
    It was a toss up with the pivot but in the end it came down to this:
    slightly newer design and geo, better cable routing, not a press fit bb
    add to this that the Mojo DW sometimes gets hooked up on square edges
    Observations, Nomad is a better bike all round. It is the first trailbike that I have owned that feels perfectly balanced at speed in the air on climbs and steep descents. No idea how that have done it
    The Nomad is lighter climbs better and is awesome on the descents of course. The real surprise is ho much better it climbs, it feel like a lighter bike when in truth there may only be a lb in it. Its is easier to keep the front down. Only downside is that I have many trails where even the 30t front I have may be too tall
    Reputation: Terminator Z's Avatar
    Feb 2007
    Great review SP! Been waiting to hear your comparison since first hearing you were going to be building up a Nomad. The Nomad and the M6 were both on my short list for my next bike. Hands down the Nomad is a brawler and I would love to have one, but I worry that it would be too slack and aggressive for daily riding. I donít race, but I always put extra emphasis on my downs. I definitely want my next bike to be aggressive, but I just donít know if the Nomad is too aggressive.
    Iím also from North County SD and ride similar trails. As much as I like shredding technical jump and drop infested DH trails (I already have a DH bike), I know that the majority of my rides are going to be at Daley Ranch, La Costa, Hodges, and Elfin. In your opinion, would the Nomad be too much bike for a daily driver in that territory? One of my main concerns is technical climbing like the ďWay UpĒ trail. I know I could get by with a much shorter travel/pedal efficient bike, but thatís not for me!
    Nomad is my new daily driver
    It seems to ride light somehow
    Prior to that a mojo HD was my do it all go anywhere and this is easier
    Quote Originally Posted by Terminator Z View Post
    I have only ridden La Costa and Double Peak so far but it has been fine. I will be trying to get to Elfin this week where it will be great for the descents. I think it will be fine on Way Up but will give you more feedback when I get out there. Drop me a pm if you want to ride sometime.
  1. Broke my PIVOT. SO 2014 PIVOT ROHLOFF OR NICOLAI PINION HELLIUS 29ER ?
    By Williamsven in forum Clydesdales/Tall Riders
    Last Post: 11-01-2014, 10:03 AM
  2. Nomad C pivot coming loose
    By Wonko in forum Santa Cruz
    Last Post: 05-08-2013, 11:14 AM
  3. Replies: 24
    Last Post: 06-07-2012, 02:51 PM
  4. Replies: 0
    Last Post: 01-21-2012, 10:10 PM
  5. Replies: 11
    Last Post: 03-24-2011, 07:49 PM
