I love my new 2010 Nomad but seems hard to wheelie & extremely difficult to do a manual. I did a lot of reading, a shorter stem would improve everything but climbing (not to worried). I went from a 70mm with 5 degree rise to 35mm with 0 rise. The 35mm stem seems weird, not good not bad just different. The front end doesn’t seem lighter & doing a wheelie did not improve. I have the stock TruVativ Stylo Team bars that the bike came with, I think it has ¾” rise. From doing more reading they say a short stem will benefit from a taller rise bar. I know the fad is too go low & wide. My question is will a taller bar help my problem?
I compared a couple of 6" all mountain bikes, & mine has a 1/4" to 3/8" longer chain stay. That does not seem to much of a difference, or is it?. Are all, all mountain bikes hard to manual?
I ride a 2010 Nomad. I run a 50mm stem with DH bars that are wide and have a high rise (Monkey DH lite). 35mm seems really short. It does take a little more to get use to in terms of the long stay but the benefits of the overall geo are amazing. It took me at least 3 rides to get dialed into the how the bike handles.
Dude, all you have to do is lean back more, OK? Throw your weight behind the bike
and manual. Practice in the basketball courts or the soccer field. You could have a
150 stem on there and still manual. Just get used to the bike and practice. Thats
what all the world cup riders do....
I found Nomad also hard to manual and bunnyhop (as it starts with pulling bars back like the manual). Started with low riser Easton bars with 65mm zero rise stem, now running 50mm stem with Sunline 711 wide V1 high rise bars, with two to three 5mm washers below stem. I think the washers and bar width help more than stem lenght reduction. However Nomad likes to be low in the front to be better at corners, so tricky to find good sweet spot.
I came from Reign and feel Nomad requires more power from upper body to fully use its potential, hence it gives ewerything back you give it in a manner that only Nomad can. I find it extremely rewarding bike to ride, because the more you push it the better it feels. Same goes to manualling, just lean back and pull a bit harder with determination...
Probably that just me or my other bikes but Nomad is the bike where I really learn how to manual after 7 years of MTB. 50mm stem and dh easton now but no problems with other stems so probably you just need need to get used to the nomad feeling
Find a stem/bar combo that manuals for you and you're an overnight millionaire. If the equipment change doesn't work out for you, take a tip from Fat Joe and "Lean Back".
Normally when we can't dance, the problem is with the floor.
Just learn out to Wheelie / Manual and you can do it on any BIKE (single! Tandem don't count!)
Best improvement? Just spent more time on the bike, rather than fiddling on it!
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
