Results 1 to 30 of 30
    Reputation: crank1979's Avatar
    Feb 2006
    Nomad shock options??
    I'm just about to pick up my Nomad frame and am wondering what shocks people have tried and what they think suit the Nomad.
    I'm going with the Marzocchi 66RC2X forks.
    Shocks i'm considering are:
    * Fox DHX Air (read about problems in reviews here so that makes me a bit unsure of it)
    * Fox RP3
    * Marzocchi Roco RC (non pedalling platform shock??)
    * Fox DHX 5.0
    * Cane Creek Double Barrel (made by/with Ohlins so it should be brilliant??)
    What do people reckon is best for the Nomad with the Marzocchi fork set up?
    I went with the Rocco but I don't have it yet so can't help you. The only thing I can say is the feedback I read from Noel (Knolly bike owner), the Rocco is a real plush shock and combined with the VPP linkage should be a good match since VPP should not need a platform shock.
    So I ordered my Nomad with the free FloatR that I'll keep for backup or XC days when I feel lazy.
    What sold me on the Rocco is price, simplicity of adjustment, user friendly maintenance and reliability of Marzo products. The CaneCreek DB is probably an even better shock but you have to play with it to find the right adjustment and it's quite a bit more expensive.
    Feb 2006
    Thanks mate. That opens things up a bit for me. Definitely no platform shock needed then? When do you get your Nomad and Roco?
    Reputation: daisycutter's Avatar
    air all the way
    I have had my nomad for two wweks and I can tell you that frame was made for the DHX Air. If you are getting a frame and shock now you should have no problem with the shock isssue. I love my nomad it is the true multi use frame.
    QUOTE=crank1979@optusnet.com.au]I'm just about to pick up my Nomad frame and am wondering what shocks people have tried and what they think suit the Nomad.
    * Fox RP3
    * Fox DHX 5.0
    What do people reckon is best for the Nomad with the Marzocchi fork set up?[/QUOTE]
    IJR
    IJR is offline
    I Just Ride
    Reputation: IJR's Avatar
    Do like Banzai said and get the no upcharge shock then buy whatever you want. Mine came with the DHX air but I replaced it with a 5th coil. It rides so much better now.
    All Mt, DH
    Reputation: rogue's Avatar
    Currently run a DHX Air on my Nomad and 4 of my mates run the DHX as well to.. no probs as yet. One though (got his Nomad first) has changed from DHX Air to DHX Ti Coil and says he much prefers that setup [ less to worry about in air pressures - quote ]
    Remember the DHX Air hasnt really been around for a long time so its a bit of a wait and see how it goes over time.
    2007 Blur 4x
    2009 Driver 8
    Feb 2006
    So is the general consensus coil over air? I might go with a DHX 5.0 at first then and see how that goes. Mainly because i'm struggling to find availability info on the Roco and CCDB over here.
    truth seeker
    Reputation: Reptile's Avatar
    Mar 2005
    Avalanche or Cane Creek
    My 2 cents: Get the Nomad with Fox DHX air or DHX coil. Sell the OEM Fox shock (you should be able to get $300 easily for either shock new) and order an Avalanche (Chubie or Woodie) or Cane Creek Double Barrel. No OEM shock will perform as well as a shock dialed in for your weight and riding style by a custom shock manufacturer. If you can afford it, it is an investment you will not regret.
    Reputation: arandal's Avatar
    true dat but....
    5th coil also...you can get cheap cos' they are the same as a bullit (8.5 x 2.5)
    I have a nomad with a dhx air, and a 5th coil backup (from my old bullt) which means I have a backup always ... unless both break...and I am from New Zealand...whoops...
    Quote Originally Posted by crank1979@optusnet.com.au
    The Rocco is not a problem, many stores already have them. It's the Nomad that can be more problematic depending on the color/size. I'm waiting for mine a few weeks now but I'm patient because it's winter where I live so not much riding.
    By the way, if you are used to a coil shock, I think you should really think about either the Rocco, CaneCreek or even the DHX-C. Yes there are plenty of people that are very happy with the DHX air but there is also quite a few of those who started out pretty happy with the DHX air until they tried their bike with a coil shock like CaneCreek, Avy,... It really depends what you are used to, what you try, and also what type of riding you do. Have fun shopping!
    Dec 2005
    Progressive 5th AIr!!
    Obviously you folks need a little education on the correct rear shock for a Nomad, and trust me, I've had the opportunity to ride Fox (both coil and air), Progressive air and the Roco and I am here to tell you there is no comparison to the "feel" you get from the Progressive 5th air, it's more plush, supple, buttery and whatever other adjectives you might want to throw in there.Don't waste your time and money on these other sub par shocks, get a progressive and go big!
    freeridingfreddy speaks again.
    Quote Originally Posted by freeridingfreddy
    For some reason I'm not sure you really rode a Nomad with a Rocco, but I may be wrong!
    Dec 2005
    Quote Originally Posted by BanzaiRider
    You are wrong!
    You are wrong!
    Would you by any chance have a pic, I can't believe such an innovative combination shock/frame didn't deserve a picture when you tried it!
    truth seeker
    Mar 2005
    Cane Creek Double Barrel - NOT an option
    According to Malcolm at Cane Creek, the Double Barrel shock can not be used on the Nomad. Or, I should say, it can be used, but Cane Creek strongly discourages it and is not interested in selling the Double Barrel to Nomad owners. I'm not entirely clear on what the issues are - Malcolm says that the fact that the shock mounts on the Nomad use bushings instead of bearings affects the shock performance negatively.
    Not sure what I'm going to do for my build - maybe freeridingfreddy can hook me up with one of those ridiculously smooth, buttery, plush Progressive air shocks...
    Quote Originally Posted by Reptile
    haha
    That's a real shocker. Would you be so kind to ask him about why it works for the Intense 6.6. The Nomad and 6.6 are basically the same shock mounts/design in the rear and aappling72 bought a CaneCreek for his 6.6. I would even say the 6.6 is worst on the shock than the Nomad because it's leverage ration is higher. Quite curious about this one.
    Dec 2005
    Oh yes, I did take a picture and right after that I put my super plush 5th element back on so I could go on a real ride.
    Dec 2005
    If I had an extra 5th air for you I would hand it right over that way you could have the same amount of fun that I have on my Nomad, of course I'm assuming you can ride a bike.
    ...and again.
    freeridingfreddy speaks again...
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    Caution;  Merge;  Workers Ahead! No CCDB on Nomad due to bushings...
    I wrote to Malcolm at CC about a Nomad CCDB version and this was his response:
    "Ben, sorry we have no plans to build a Double Barrel that requires bushings, instead of spherical bearings on both ends. Bearings work much better."
    I say we keep writing CC about this!
    - -benja- -
    Quote Originally Posted by benja55
    Sorry Benja but my Nomad will run on a Marzo Rocco. It may not have the ultimate adjustability of the CaneCreek but it is cheaper and user serviceable. In fact CaneCreek are a bit of a dissapointment for me with this shock. They have a great reputation with their Cloud9 shock because it is simple, cheap, user serviceable and fits most frames. It looks like for the DoubleBarrel they went completely in the opposite direction, complex, expensive and company service dependant on top of being picky to which frame they support.
    truth seeker
    Mar 2005
    Avalanche Chubie piggyback
    I spoke to Craig at Avalanche Downhill Racing and he is going to put together a Chubie for my Nomad. He has not yet delivered a shock for a Nomad and wanted to be sure of the shock mount sizing, so I agreed to ship him my frame. I know it's a bit extravagant, but the Chubie is a great shock and I like to support companies like his that put out a great product and don't get a lot of support from the major industry players. The good news is that other Nomad owners will now have the Chubie as an option - and they won't have to ship their frame to get it!
    http://www.avalanchedownhillracing.com/chubie.html
    Hey that's an interesting choice also Reptile. Would be really fun to test ride my Nomad with Rocco versus yours with Chubie... I don't know if some magazines would be willing to pay us for a review! hahaha I can't wait to read your comments.
    * Fox RP3
    * Fox DHX 5.0
    I got my Nomad with the Fox Float R custom tuned high volume shock. It came that way. LBS didnt have a DHX air in stock for me, so he let me use the Float until the DHX arrived.
    I was blown away with the Float's performance. It has just the right amount of platform (custom tuned or not ?..... ), was ultra plush & yet the bike pedalls great. I hate having all kinds of tuning options, and since the shock performed great I decided to keep it. I also saved some weight and some $$$ on the way . If you can - check it out.
    Redwood Dancer
    Reputation: whangen's Avatar
    Quote Originally Posted by PizzaMan
    I'm going to stick my spoon in this pot of s**t and stir it up... hope I don't ruffle too many feathers (sorry for the mixed metaphor).
    I live in Santa Cruz where Fox does it's designing and SC bikes does too. I know a lot of the crew. I held out against the Fox DHX air for a long long time as too excessive, expensive, too stiff, too hard to adjust etc. I now feel sorry I was so rude to some of the factory dudes and dudettes when they tried to explain the new DHX theory to me. I got my initial bad vibes about DHX from flat parking lot test rides. This makes the bike half a pound heavier and makes the ride very stiff. OKAY, HERE'S THE TRUTH - It's not DHX ProPedal technology that fails in any way (it's superb), its that FLAT ROOTLESS PARKING LOTS SUCK FOR TESTING BIKES. SC bicycles needs a REAL 'test ride program' --- they dropped the ball big time on this one cuz there's a ton of people riding around with the wrong size frame, shocks, parts etc.
    That said, take a bike with DHX air or coil (or the Manitou versions also) and point it up some steep skinny tech ST littered with rocks and roots and you'll never go back... just trust 'ol whangen' on this one. If you can't spend the ten minutes it takes to learn the five adjustments, then you're just lazy (or can't follow simple instructions). ProPedal (ie. stable platform valving) really is the wave of the future. In a nutshell: It's a hardtail uphill when it's smooth, that is, till you hit a rock/root, then it's instantly full suspension. Then it switches back to hardtail. This developement is as important to suspension bikes as the new linear shock rates, maybe more so.
    RAIL OR F*!%#!*^G BAIL
    Quote Originally Posted by whangen
    As a matter of fact, I do have a DHX Air on my 5 spot. I know the shock pretty well, I didn't say it's a bad shock, it does add a lot of performance to many a bike, but I think the Nomad's suspension is so well designed & dialed in, it does not need any of this magic.
    I'm with you PizzaMan. My current bike is a well designed horst link similar to your 5spot. I've been through 3 different platform shock (Fox Talas Propedal, Manitou 3way air and Fox RP3 Pushed). None gave me satisfaction on small bumps. In my opinion, horst link or VPP suspension design don't really need any of this magic like you say. When the 5th came out it kind of gave a new life to bobing single pivot design and for some reason manufacturers decided to push the technology on all suspension designs. There seems to be more and more people who now want to get shocks that don't have any platform. Anyway, I'm certainly not a reference in suspension but I did just like you and ordered my Nomad with the standard FloatR plus also a pretty simple, no platform, Marzo Rocco. We'll see the result soon!
    Hung Like a Lightswitch
    I think it depends on what you are going to use this bike for. If this is a bike that you will be doing many shuttle runs, then you will want to get a coil shock, because as the air shock heats up, you looks control of damping and it blows through the mid stroke too easily. If you are using this for an XC oriented bike, but still want something to suck up the rocks and occasional drop, then the air shocks will work fine for you.
    I have a Nomad on order, and when the SC rep was told what type of riding I plan on doing with the bike (many shuttle runs with the occasional XC ride), he said that he would put the DHX coil on that bike more than any other shock. So I'm getting a Large white Nomad with a DHX 5.0 coil on it.
    Redwood Dancer
    Quote Originally Posted by hbfrdh1
    That's good advice... makes sense if you think about it. Never got my DHX that hot but then I only shuttle 2-3 times a year in Downieville or Nevada City and do the lifts at Mammoth or Northstar infrequently.
    Good luck with the Nomad. Get with someone on the phone directly at Santa Cruz and have them tell you the correct way to set up sag and rebound. It's not as simple as the old days, what with Propedal and the boost chamber at 100psi.
