Results 1 to 3 of 3
    Thunder Chunky
    Reputation: Madman133's Avatar
    Nomad rear shock question
    Hey quick question for you guys. If you put a 8.75x2.75 shock on the nomad would it completely screw everything up? Has anyone tried before?
    Thanks,
    Taylor
    Purple Popcorn
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    Sorry for the hijack but I have a similar question -
    Would it be possible to run a 7.875 x 2.25 shock to lower BB and slacken HA a bit without any frame interference or other issues?
    Ground Steeze. @iggy_strbac
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    The Nomad will run an 8.75 shock...some even came that way from SC. I probably wouldn't run anything less than a 170mm fork with it personally.
    I don't know anyone who's run a 7.875 shock on a Nomad. I'm pretty sure you'd smack your cranks so badly it would be unrideable. The Nomad doesn't have a shock shuttle or other feature to make up for some of difference like a Bullit does.
