Results 1 to 33 of 33
    Nov 2006
    Nomad ISX-6 set up thread
    There's most likely not a lot of us, but it is necessary.
    I'm 180lbs without gear. Super aggressive trail and light FR on the Nomad, although I have not worked up the courage to really FR on this shock yet. Anyone out there really trust it?
    Running 145 in the main chamber. 150 in the piggyback. No SPC. 8 clicks of HSC. Maybe 6 on rebound.
    I've played with the IFP adnauseam, and cannot tell a difference between 75 and 150 psi, so I'm stickin' with the higher pressure.
    Most of the time it feels fantastic. There are times (maybe at different altitudes or higher temps) when it feels less plush. Anyone else experience this? Maybe I'm crazy.
    Overall I really like this shock. The bike sits with less sag and still seems as plush as my DHX coil. Can't seem to fully bottom it out though.
    Comments?
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Did you search this forum and the suspension forum?
    Nov 2006
    I've read everything in the suspension thread and there's really not much in the 'Cruz Forum. Just thought it'd be nice to have a thread specifically for the Nomad, since it is going to set up differently than many other bikes.
    Dec 2005
    Lots of guys are runnning the ISX-6 on the Banshee Rune. Same goes for some of the Intense bikes (like the 6.6? maybe this would be more relevant to you?)
    Maybe try asking in a thread that they'll see? I've ridden a Rune with the ISX and it felt awesome, but it wasn't my bike and I didn't want to mess with the shock...
    Support your local advocacy group: FVMBA!
    TNC
    TNC is offline
    noMAD man
    I've had one on an '06 Nomad for about a year now. It's been totally realiable. The tuning options are great. Don't be afraid of using this shock in an aggressive manner. It's what Manitou intended for this shock.
    I'm 185lbs. and it sounds like I ride about like you. My settings are quite different from you. 180 in the main chamber...60 in the piggyback bottomout chamber...fully open on the low/high speed compression...piggyback fully open...don't remember the rebound. Do you know if your ISX is the single or dual air chamber? Mine is a dual with the second "outer" chamber.
    one more time
    TNC - have you upped the main chamber pressure on yours lately? I seem to remember you were running 150 or something like that?
    Anyway im 220lbs kitted up and im running 160 in the main, 60 in the piggy. Might try pushing the pressure up a bit.
    Same as TNC - both compression fully open, rebound nearly wide open. Probably a bit too much sag and too 'active' for trail riding. Ive done a bunch of 5ft drops with no issues - nothing bigger as yet however Im no smooth lander!
    Bikes, beer and pizza.
    Nov 2006
    Mine's a dual chamber. TNC, I can't believe you can run 180. If I up the main to 150, it really stiffens the shock up.
    It is amazing the amount of response I get for only small adjustments in the tuning. Seems like there may be more than one way to achieve a good feel on the shock. Still playing with it, just curious what others were currently doing with it.
    TNC
    TNC is offline
    noMAD man
    Benz and HR...I can even run 185 at times if I'm toting 2 water bladders on a long, really techinical ride. If I run much less pressure in the main, I don't like the excessive sag. I bought all the tools necessary to work on Manitou rear shocks, and I've been into both my ISX and a 4-Way Air that is mounted on one of my Bullits. I was aware of a few on the forums who warned of running low pressure in the ISX piggyback. Manitou says you can run as low as 50psi in the piggyback if you're careful to maintain that religiously...including when you start changing the piggyback volume with that on-the-fly knob without repressurizing.
    After running a low psi for many months on my ISX, I wanted to change the oil in both my 4-Way Air and ISX. I carefully checked my ISX as I opened it up for any evidence of air that might have migrated into the oil from the air side of the IFP (piggyback piston). I could find no evidence of such, but it's hard to tell upon disassembly. I think you can tell more just from the performance of the shock. Air in the oil yields inconsistent tuning and ride performance...especially in notable temperature changes. My ISX has been dead bang reliable and consistent. What can I say? I'm not convinced by many who have warned about low piggyback pressure...as long as you don't go below 50psi. The piggybacks in most Manitou higher end shocks are almost identical in design except for the SPV/Intrinsic differences. The sealing portion of the piggyback piston (IFP), however, looks identical, so you should be able to run lower pressures as has always been designated by Manitou at 50psi. IFP depths are also set the same whether the shock is SPV or Intrinsic. In fact I think one can experiment with the IFP depth to some degree to induce more of the available travel into the shock if you're having issues getting full stroke. I haven't done so, but it looks do-able.
    After having been into both styles of Manitou piggyback air shocks, this crossed my mind. If air migrates into the damper oil from the IFP chamber, the shock should behave in a given manner. I'd think that the main chamber might need more pressure in an attempt to control compression. But in that case it would also seem to require more compression damping, more bottomout air pressure in the piggyback, and reduced bottomout chamber volume in the piggyback. Air in the damper oil usually allows the shock to move through its compression stroke too easily. Air is easier to compress than oil, and air in the oil keeps the damper from providing the designed resistance. Temperature should also change the way the shock works in a more dramatic way. The shock should also work better in the early part of the ride where the oil and air have had a chance to separate a bit, but then the damping should degrade as the ride continues as the oil and air mix and start to foam a bit as they go through the damper orifices over and over again. All I can say is that my shock has been consistent during all points of operation, and the shock performed the same with the same setup after service. Mine is also setup with a fully open bottomout volume, no high/low compression damping, and low bottomout pressure. I'd think the reverse would be the case with air in the oil.
    Also think about this. Manitou air shocks with SPV use relatively low main chamber pressure because of the overall influence of the SPV pressure in the piggyback. The Intrinsic ISX should need higher main chamber pressure to some degree because the piggyback pressure is mainly only a bottomout tuning element, not an SPV element. It's almost like some of these ISX shocks are operating like an SPV shock.
    It seems odd that this shock should provide such good performance with such diverse settings. I don't have the answer to that. Just about everyone who has used this shock has been really impressed, so I'm not sure what's going on with the different settings.
    one more time
    Cheers for the detailed response TNC - a simple 'yes' would have been fine!
    Joking - I am still stoked with the performance of this shock, recommend it 100%. To be honest I havent played around much trying to tune this shock, its been great at the above settings from day one - although I might try a 10 or so PSI more in the main and see how it goes.
    In my mind shock tuning is specific to a number of individual factors - style, terrain, feel etc... the crazy thing about this shock is how versatile it is across all types of terrain. As Ive mentioned before Ive done 25km trail rides with a short session at the park doing drops on it without any adjustment.
    The only issue I have is that there is no authorised service agent here - TNC is it the type of shock that could be overhauled by my lbs?
    TNC
    TNC is offline
    noMAD man
    benz, I guess it depends on the personnel at your LBS. On the Manitou site under the technology tab there are excellent detailed instructions for rebuilding all Manitou rear shocks. They're quite good or I wouldn't have been able to do it, frankly. I've rebuild dirt motor rear shocks before, but in reality I think they're more simple than some of these bicycle shocks. You do have to have about 3 or 4 special tools. The tools were surprisingly affordable through our shop. I rebuilt my 4-Way Air first, and the two shocks have some similarity in construction.
    TurnURComputerOff&GoRide
    Reputation: rural's Avatar
    I'm on an Intense 6.6 with an ISX-6.
    185 to 190 pounds depending on gear - 190 in the main chamber and 60 in the piggyback. The red thing on the piggyback is in position 1, can't remember the rebound and I've never been able to tell the difference when I've tweaked the small bump adjust thingy.
    Just wanted to add my thumbs up for this shock - I'm totally happy with it.
    Hi All,
    I've just picked up a Banshee Rune frame with an Evolver ISX6 shock on my on the weekend.
    I've set it up as below:
    Rider weight: 78-79Kg with gear on
    Main Air chamber: 110 psi giving about 30% sag (measuring 185mm eye to eye)
    Low Speed Compression: 1 click off zero
    High Speed Compression: 1-2 click off zero (I think I cant remember exactly)
    Rebound: 6 clicks off fully fast
    Bottom Out: On position 3
    Last knob setting: The dial is on the inside of the Bottom out ring. What does this one do?
    What I cant figure out is, you guys talk of putting pressure in the piggyback, however I only see one schraeder valve on my shock. The Evolver ISX6 that I have looks like the one currently on the Manitou website, http://www.manitoumtb.com/items.asp?...=12&itemid=154 , and what does this setting this do?
    TNC
    TNC is offline
    noMAD man
    Quote Originally Posted by lzyboy
    Hi All,
    The piggyback air chamber valve is sort of camouflaged by a red cap that looks like part of the piggyback volume knob. That may be what you're referring to as a dial on the inside of the bottomout ring...and make darned sure you keep at least 50 psi in that piggyback...realizing that if you have 50 psi in the piggyback at #3 setting, when you turn it toward #1, you increase the volume and thereby drop pressure below 50 psi.
    Thanks TNC!
    Hehe ... I had this sick feeling that it could have been hiding under that "cap" just as I pressed the "Submit Reply" button.
    But what does this "feature" do and is there a guide on how much "PSI" I should be running in this chamber? Surprisingly the manual has little info on this.
    TNC
    TNC is offline
    noMAD man
    The pressure can be as low as 50 psi all the way to 175 psi. Since the piggyback on the Intrinsic damped models is more for bottomout, I doubt you'll ever want to exceed that max rating. There are two schools of thought on this shock. Some are running 100-150 psi in the piggyback and less pressure in the main chamber. I'm running less in the piggyback (about 60) and more in the main chamber. Try it either way to find what suits you...just make sure you don't let the piggyback pressure fall below 50 under any circumstance.
    Ahh... this brings me in line to help understand the rest of this thread. I'll check to see what I've got in the piggyback when I get home from work. I hope that the guys in the shop put some air into that chamber!! Thanks again!
    arc
    arc is offline
    Sep 2004
    TNC, how hard is it to work on this shock? Does it require any special tools? I'd like to switch to a lighter damping oil, hoping to speed up high speed rebound.
    My shock is 2008, Manitou's website's newest manual is 2007. Do you know of any changes in the shock between 2007 and 2008?
    TNC
    TNC is offline
    noMAD man
    Quote Originally Posted by arc
    I know of no changes to the shock at this point. I have the first dual tube model, and the other dual tube versions are the same as far as I know. Yes, it requires at least 4 special tools to work on. The good thing is those tools are basically used to work on every other rear shock...coil or air...in the Manitou lineup. I also rebuilt my 4-Way Air. I'm surprised you need faster rebound. The stock oil is 5wt. Your rebound is too slow even with the dial completely open? How much pressure are you running in the piggyback and main chamber?
    As far as being hard to work on...not really. It does have a lot of o-rings. You need a good bench vise and soft jaws. The online tech manual on the Manitou site was very good.
    emtb.pl
    Reputation: krolik's Avatar
    I have manitou usa confirmed nothing changed except stickers
    emtb.pl
    Quote Originally Posted by TNC
    Ah TNC, after reading all this I get it now why your PM was so dry and short:P
    What's with that dual-tube thing? I can't find any info what type mine is (it's on it's way and will be here around Oct20th)
    TNC
    TNC is offline
    noMAD man
    Dual air chambers
    Quote Originally Posted by krolik
    The dual tube refers to an inner and outer air chamber that makes it a type of 2-stage air shock. It appears dependent on stroke position, so as the shock compresses the characteristics of the air spring can change and not be the normally soft mid-stroke and highly progressive end-stroke that is normal for most air shocks. The new Fox RP24 has a similar design with that second funky air chamber at the head of the shock. This is something creative that air shocks should have tried a long time ago to produce a more linear spring action.
    emtb.pl
    I get it.
    So the evolver comes in two versions??
    How can I determine which one I just purchased? There were no options to choose:/
    Are there any differences in the looks of it?
    TNC
    TNC is offline
    noMAD man
    I get it.
    I haven't looked at the Manitou site for awhile, but there were two choices. I also know that bikerX who posts on mtbr frequently ordered a single tube version because of his bike's suspension design. They do...or at least did...exist.
    Edit: I just looked over on their site. If you look at the 2008 pdf catalog file, you'll see it's still there in two versions. You can physically tell the two apart, as the twin tube has a large silver circlip that is retaining the outer chamber. See it in the pic where the main, large shock body has a silver line where the fat part of the body meets the moving shock shaft. That's the circlip. I haven't actually seen a pic of a single tube version, but it will just be skinnier for the most part.
    emtb.pl
    So maybye the single tube version looks simmilar to the ISX4 pictured on the next page
    emtb.pl
    Or this is single tube version:
    http://content.mtbr.com/TRP_14_340_16crx.aspx
    arc
    arc is offline
    Sep 2004
    Thanks TNC. I'm running 60/190 psi, low and high speed compression wide open and bottom out in position 3.
    Overall the shock is good but I'm having a hard time trying to get it perfect. Its a little harsh on trail chatter and then sometimes it blows through travel for no good reason.
    I haven't run out of rebound adjustment, running it quicker helps on the rooty sections but then it kicks back too hard on bigger stuff, leading me to believe it was packing down a bit on small repeated fast hits. I assume high speed rebound is not adjustable and going to a thinner oil would speed it up and everything else would be within range of the other adjusters.
    It wouldn't surprise me if there was a small speck of dirt in there somewhere as well, causing the HSC to stick open once in a while. Guess I'll have to check the LBS to see if he has the correct tools.
    TNC
    TNC is offline
    noMAD man
    arc, if you're getting that shock to blow through its travel, that's pretty surprising. Not saying it isn't possible, but a major trait of this shock is its strong mid-stroke and big hit performance without bottomout. In fact some can't get full travel without really softening up the shock. Play with your air pressures. If you're blowing through your travel, try the alternate method of higher pressure in the piggyback and adjust the main pressure down accordingly. There are numerous ways to tune this shock, so spend some time with it. It will be worth it.
    arc
    arc is offline
    Sep 2004
    Its not a consistent thing TNC, it happens on a similar feature but not all the time.
    Usually happens riding at medium speed, go over a rock, log or root about three inches high and just as the shock rebounds most of the way, dropping into a small depression. The shock makes a sploosh noise for about half a second as the bike slowly sinks deep in its travel. When the shock behaves normally, its just a little bump you ride over and forget about.
    Might happen three times a ride or not at all. Seems to happen most with the bottom-out set at three. Set at one, it does it less. Maybe having the high speed compression set for minimum starts overlapping the low speed compression area. For all I know there could be a little bit of air or oil in the wrong place.
    Do you ever get the feeling the valving is damped fairly firm on this shock and they're using the IFP for small bump compliance?
    TNC - you seem to be the man to ask, any reasons why I couldn't run one of these shocks in a VP-free? any suggestions on setup etc? Ta.
    TNC
    TNC is offline
    noMAD man
    Not clear on your comment about when the "noise" occurs in your description. If you hear noise out of a Manitou air shock under compression, I think you might have air in the damper oil. These shocks make a very noticeable sound as they rebound, but they're pretty darned quiet during compression. Also the fact that you have one set of results on one pass over this trail feature, and a different result on another pass, might indicate air in the damper oil. Air in the damper oil on these shocks and most any other usually results in inconsistent damper action for obvious reasons.
    Before you get too concerned, however, concentrate on some of the different tuning options to see how things shake out. If you continue to hear a noticeable sound out of this shock under compression, however, I think you have air in the oil. Be very careful to assess this, as it can be difficult to judge that breakover point right between compression and rebound. You should hear a very noticeable sound during rebound.
    On your question about the IFP for small bump compliance, I can guarantee that the main influence of the IFP in a regular ISX-6 is mainly for bottomout. There is not an SPV element in the piggyback of an ISX-6. I have both the ISX and a 4-Way Air w/SPV and have been into both of them. One disclaimer here is that Manitou actually showed an ISX-6/ISX-4 with an SPV option early on in the release of this shock. That has changed. ISX as I'm aware now is only supposed to be an Intrinsic damper and not SPV. Now...all that said, there will be some natural influence on small bump compliance if you raise the piggyback pressure. You can't get away from it. However, there's no platform SPV element or a "release point" with the Intrinsic damper. You just get a very steady and sort of linear small bump compliance restriction as you up the pressure in the piggyback...much like you get with a coil shock as you up the spring rate...just not quite so dramatic.
    arc
    arc is offline
    Sep 2004
    You could be right on air being in the damper oil, the oil could be aerating during the rebound stroke, causing a loss damping during the next compression stroke, then degassing quickly because the oil is pressurized during by the IFP. Maybe it seems to happen less on position 1 because the small pocket of air stays somewhere less troublesome.
    Probably a good time to get the oil changed and the IFP reset. Do you see a problem with 2.5 weight oil?
    What are the symptoms of a sticking IFP? Could that aerate the damper oil temporarily?
    If a sticking IFP is a common problem with this shock it might explain why Manitou has increased the minimum boost pressure.
    I was getting at something else with the small bump compliance thing. Keep in mind the only shock I've had apart is an Rp23. The ISX6 has a large volume IFP chamber compared to most shocks, so if it was moving during rebound and compression it would not ramp up and down in pressure as much. The IFP moving would let the main piston move, damping oil pressure would increase and open shims further. If you design it right you could damp it firmer on the LSC and still ride plush, and widen the transition to HSC. Maybe this is where the extra mid stroke damping comes from and why people seem to run compression mostly open.
    TNC
    TNC is offline
    noMAD man
    I don't know, arc. I think the air chamber volume behind the IFP is the same on all the Manitou shocks and probably quite similar to others. You even use the same IFP depth guage on the ISX-6 that you use on the coil series and air series.
    I'm not aware of a sticking IFP to be a common issue on these shocks. Usually the way that air gets into the damper oil is when the air pressure is too low and migrates past the IFP o-ring.
    I'm not sure how the shock would perform with 2.5 oil. I don't know anyone who's tried it. It's possible the external adjustments would still have enough range to be effective, but who knows. I went back with 5wt on both the 4-Way Air and the ISX.
    TNC
    TNC is offline
    noMAD man
    Quote Originally Posted by Pete-G
    Pete, I think the ISX-6 is probably the best air shock for a VP-Free. It has the compression and bottomout controls that long travel, big hit bikes need. It has a solid mid-stroke support, so the shock doesn't blow through its travel like most air shocks on bikes like these. I'm not exactly sure how setup would shake out, but I guess I'd start with something close to what some of us are running on our Nomads.
