Results 1 to 92 of 92
    Nomad 8 -- 8" inch travel Nomad 1 with 9.5"x3" Shock
    Thought I'd share this with you mtbr peeps.....
    In the spirit of keeping my Nomad as my one and only "do-it-all" bike, I Ianded the crazy idea of turning my Nomad into an 8" travel bike. After exploring various ideas on how to accomplish this, I decided that it was best to use a longer travel shock, while retaining the stock VPP links, and thus wheelpath (for at least the first 6.5" of travel).
    To get the travel I needed would require a 3" stroke, so with the 9.5"x3" shock size being a standard DH size, that's what I ended up with. After a few very rough iterations in the computer, I ended up with a new upper shock mount that puts the shock into more of a rising-rate over a stock setup.
    I decided to use an air shock for the setup. Why? Well, lots of Nomad 1 owners know that the DHX-Air has a bit of mid-stroke wallow. I believe this is the result of shock changing over from a rising rate over to a falling rate mid-stroke before the air chamber really gets a chance to get progressive enough to counter-act the falling rate. Of couse santa cruz figured this out, and revised the Nomad 2 such that it keeps shock in a rising-rate for more of it's initial travel. So because of my increased rising rate, I decided to do the build with the DHX Air to keep the added weight down a bit.
    Ok so enough mumbling, and onto the pics:
    The mount:
    Test fitting the mount onto the frame..... yeah it was painful to drill and tap into the frame like that , but those little side pieces are needed to keep the mount from flopping backwards during airtime:
    And of course, gotta have the pro look with a little anodize:
    Here's one of the two upper mounts I made mounted onto my buddy's Nomad:
    And of other mount on my Nomad:
    And the money shot of the only two Nomad 8's in existance :
    I've been testing this configuration for the past month and it has worked flawlessly. The Nomad 8's really feel like DH rigs over nasty chunder, and are still completely climbable on the XC rides (which I have been doing on a regular basis). The DHX-Air doesn't have the mid-stroke wallow that the stock rates had and feels properly damped for my weight....all in all, I'm super happy with the way it turned out.
    Final tally (with 180mm front fork)
    14.3" Bottom Bracket height
    66 Degree head angle
    Who says I can't have my cake and eat it too?
    Reputation: dropmachine.com's Avatar
    Darwin in action.
    Sorry man, but that is just NOT a good idea, for a number of reasons.
    First, if you can't see the shock is compressing at an entirely different angle, you're in trouble. I bet at the least, blown seals. At worst, snapped shock, death, destruction, chaos...cats and dogs living together...
    Second, if you did some research you'd see that the "wallowy" feeling of the DHX doesn't limit itself to the VPP bikes. I had one on my Kona Cowan, and I hated it. Its dead in the middle. Try a 2010 RP3, and you'll see how an air shock is supposed to feel.
    Third, Santa Cruz is smarter then you. They designed that bike to work in harmony as a unit. You throwing a new shock on there with some nicely-made and well intentioned hacked link screws that all up. Its a fun project for sure, but you can't be serious in thinking that the bike is just as good, but now has more travel. I can almost guarantee it does NOT work as well as it did, as leverage ratios and sag points are probably completely out of whack.
    That said, if you're happy, you're happy. Its a neat project for sure, but I can't help but think that you're just on the wrong bike. If you want more traction, do it the right way and get a Driver 8.
    Stuff.
    err, 27.5+
    Reputation: AL29er's Avatar
    Nice hack. I admire the ingenuity. It is a relatively clean way of creating a different mount location on a bike without a shock shuttle.
    I am of opinion that one bike can't do it all. I am a big fan of the bike stable approach. Why have one that does a mediocre job when you can have 3-4 purpose built rigs. A bike like a Nomad can do a lot, but it will never be a capable DH race bike or XC race bike. That isn't to say you can't race DH on it, just that it has limitations when the going gets rough and fast.
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    Quote Originally Posted by dropmachine.com
    How is the shock compressing at a different angle going to affect the seals or snap the shock?
    If it's pinned at both ends, it acts as a two-force member and thus can only exert force along its axis - no moments can be created in the shock. A moment is what I think you are alluding to as far as blowing seals and snapping the shock?
    Please correct me if I am wrong, i am no expert
    Cheers
    Quote Originally Posted by Brian_Pal
    Cheers
    Well, the easiest way to explain it is to look at the two original shock mounts. Picture a line that goes through them. As the swingarm moves through its motion, there is, for the most part, a straight line that compresses between those two mounts.
    Now if you change there those two mounts are. eventually you can see that the lis is going to want to "bend"to help those two points meet. So. all the stress gets transferring into the seals and shock body.
    Does that make sense?
    In this case, the new shock mount is considerably higher, wihch out to stress the hell out of that shock.
    Stuff.
    Ok first, how could I not see that the shock is in a different angle when I specifically put it in a different angle? Please re-read my post about the increased rising rate of my setup. And blown seals? I doubt it. This 9.5x3 is seeing MUCH less duty than a stock DHX-Air at the new compression rates.... in fact I'm running WAY less air pressure than i did with an 8.5x2.5 shock. The stress riser of this setup is at the downtube.... this setup is more stressful on the frame, NOT the shock.
    Second, I wrote "I believe" that the change from rising rate to falling causes excessive wallow on the Nomad 1. I didn't write "it is fact". But regardless whether or not I'm right, the net outcome is that my current setup does not have that felling. And yes, I've had all fox three flavors on my Nomad in the past, DHX-A, coil, and rp23.
    Third, you seem to know exactly how smart I am. I can formulate some opinions about you as well, but I'm going to refrain, since tone of voice is hard to determine on an online forum. All I can say is that this works for me and that's ALL that matters to me... to each his own.
    Quote Originally Posted by AL29er
    Thanks for the comments. I agree that my Nomad 8 is the jack of all trades, master of none. I used to have 2 bikes, but I found that I always had more fun riding the less "XC-ish" rig. That's why for me this is perfect since I'm never in a hurry to get up the hills and I'm not racing downhill anytime soon. I just ride for the enjoyment itself.
    Sorry, but completely incorrect. Brian_Pal is correct, two points mounted on bearing surfaces will ONLY see tension and compression forces and no zero moments (for all intents and purposes). The only time the body and seals would see a bending moment is if the shock were bottomed out so much that shock body completely buckled under the stress.
    Nov 2007
    Hypothetically, lets say that you were going to sell this Nomad. Would you keep it 8" travel or would you revert it to the OEM shock. If you reverted the the OEM shock, is the integrity of the shock mount diminished.
    In a sentence. Is the Nomad 8 forever a Nomad 8?
    I don't think anything bad about you at all. I can see what you were trying to acheive, and that thought was put into it for sure. Clearly from the machine work you aren't dull at all, and actually quite skilled.
    While I understand what you are saying about the shock and forces acting on it, I disagree with your statement. You're right in that the two bearing surfaces won't see any stress, except that one end is static and the other is traveling in a slight arc towards the frame shockmount. I would think that this means you would be applying out-of-line forces to the shock, as your mount is higher and not inline with the path of the two shocks mounts. Does that make sense at all?
    really though, giv'er and see how it goes. The funny part about theory is that its just theory until proven to be fact, right?
    Now, post riding pics and see how it goes.
    ** should point out, my only real worry here is that the frame fails in some way due to the longer shock. While its funny to watch them on Youtube, knowing a rider is seriously hurt is never fun. Unless they're just a little hurt of course, then it can be fun. Especially if its not me.
    Stuff.
    graps the nettle
    Aug 2005
    no...
    While I understand what you are saying about the shock and forces acting on it, I disagree with your statement. You're right in that the two bearing surfaces won't see any stress, except that one end is static and the other is traveling in a slight arc towards the frame shockmount. I would think that this means you would be applying out-of-line forces to the shock, as your mount is higher and not inline with the path of the two shocks mounts. Does that make sense at all?)
    go back and re-read what he said: two points mounted on bearing surfaces.
    what that means is that the shock ends are not fixed. those aluminum collars on your shock ends are mounted in DU bushings, like just about every other shock out there. the shock can handle some degree of pivot, and the only forces it is seeing are those trying to compress it. there are no out-of-line forces. this is how linkages can be used to achieve rising or falling rates and such. if the compressing loads on shocks had to always be in direct line with the actual compression of the shock itself, there wouldn't be any rising rate or falling rate links, and shocks would be blowing up everywhere.
    still, this might be considered use outside the considered warranty-able intent of the bike. just sayin'. and, how does the back wheel clear the seat tube on full compression?
    hold my beer...
    Reputation: Vrock's Avatar
    Wow, that mod looks great. And the "LR Evolution" make sense too. Anyway, it's weird to see someone doing a mod to a N1 Because you can add a 222x70 Coil Shock without all that work, a get good results too.
    Doing Something similar for the N2 Would be even better, a lot of people want a 180mm N2, And I think it's doable with a new upper Link and a Longer shock....
    Cool concept. Would love to see a video with the air out of the shock and cycling through full travel.
    X-prezo Super-D, 26in style.
    Reputation: socalMX's Avatar
    Pics of the complete bikes?
    thread killer
    Reputation: WTF-IDK's Avatar
    I think it's cool. I think it's even better if it works for you.
    Good work Cosmo.
    You're also the one that made you own adapters for the Hammerschmidt right?
    What's your machine shop look like?
    next time
    [QUOTE=spazzy] Might as well sell your bikes, E-riding is much more productive.
    From your username I am guessing that you use SW to model parts? Did you do a FEA of this part in the design phase? If so, what did you use as your shock force in the simulation? I did a simulation on a rocker arm and simply estimated the max force using a typical spring rate and the stroke of the shock - came up with a FOS of around 1.5, which seems a bit low for a production bike.
    This might be a stupid question, but, why didn't you just drill a new mounting hole in the stock upper mount? Was there not enough room? Your new mount looks like it would cause unwanted leverage on the stock mount. I wonder if you could cut off part of the top plate of the stock mount so you could put your mount closer to the frame. Kind of like the movable shuttle on other bikes.
    I do like your machine work. I hope it works out for you. I have always thought a 180mm Nomad would be a sweet bike to have.
    Reputation: BPSarge's Avatar
    Oct 2007
    I'm sure all Santa Cruz bikes at one time or another had some crazy idea's before they made it to the show room floor! The cool thing about it that it's your bike and not mine! Kidding! some more pictures or vid's would be cool.
    Nov 2006
    The one thing that you might ought to consider, is that you've increased the moment arm on that shock-mount to the frame by a factor of TWO ( the new DU is about twice as far of the down tube as the original). This may add a lot of stress to that shock mount (which is also transfering the load to the downtube in more of a bending load on the welds rather than the original shear load (kinda)).
    Not sayin' it will fail (I'm sure there's a hefty factor of safety designed in), but it wasn't designed for those loads. Basically, you've decreased your margin of safety, which is something I like to have a lot of on a 180mm bike.
    Quote Originally Posted by Renovatio
    I can easily convert the frame back to the original shock, and the mount's integrity isn't really sacrificed by the two small M6 tapped holes I put in it.
    Your first post sounded almost like more of a personal attack than true constructive criticism, but thanks for clearing it up... we're all good here.
    Well we can agree to disagree once again. I think MtotheF, spelled it out the source of confusion here... if you assume that the ends of the shock are solidly mounted, then you are correct - there would be much greater rotational torque on the shock body, but such is not the case here where the ends of the shock are free to rotate.
    I will agree with you about videos though, where no one is seriously hurt as being funny (as long as it's not me as well ).
    Quote Originally Posted by MtotheF
    Yeah... I passed the point of "warrantiable" when I started facing back the BB shell like crazy to mount on an ISCG adapter for my hammerschmidt:
    Hammerschmidt with ISCG Adapter on Nomad 1 with Grip Shift
    On full compression, my 2.7 DH tire comes within 1/2" of the seat tube (or about 1/4" from the FD cable hanger). I have a third upper mount started with the intention of slightly lowering the BB even more, but this would definitely cause rear tire interference with the hanger which I was planning to cut off anyways since I'm not using it. To date, the most travel I've used in real world riding has been about 2.75" of shock stroke.
    Quote Originally Posted by Vrock
    That was my first thought too - to put on an 8.75x2.75 and be done with it. But I wanted a tad more travel, and didn't want to raise the BB height any. Currently my BB height is pretty close to the stock Nomad, and I'd prefer it even a tad lower.
    Quote Originally Posted by WTF-IDK
    Thanks man, yes I made my own HS adapter, then I posted up the other thread explaining how to do it with an MRP adapter. My "machine shop" looks like a plain small work bench with an small manual mill on it... nothing exciting here. 'Timight' (owner of the white nomad) has a pretty impressive setup for a garage machine shop however.
    Good observation on the username... I did a quick and dirty model up of the linkages all as two bar mechanisms in SW to check the wheel path and shock angles, but didn't go as far as to model up the actual frame and run FEA.
    Quote Originally Posted by Wrench Monkey
    Thanks for the comments. I did weigh many options, including one of which you mentioned about cutting the mount into two sections and bolting up a shuttle mount piece in the middle. But after modeling it up, I realized I wanted change the shock rate as well, which meant moving the mount up anyways.
    Quote Originally Posted by HR Huck'nstuff
    Yep hear you and have considered all points you mentioned. As stated in my previous post, the I am well aware the new mount causes increased moment on the stock upper mount. Given my profession, it's a little out of character for me to skip stress analysis and probably should have done the FEA as Brian stated, but I've designed and built enough things in my time that I felt confident enough (and lazy enough to skip that step) that this would work before I started the project.
    One of my original plans for this project was to rebuilt the upper link, keeping the same pivot points, but altering the shock mount position. But after several iterations, I found it difficult to get the 9.5" length in there without extreme complexity in link and decided to go with the revised upper mount location for simplicity instead (at the expense of increased moment arm).
    However the proof is in the pudding - real world testing world testing has shown my setup hasn't given me any issues for my rider weight and riding style. Now if I weighed 50 pounds more and liked to huck 10-15 drops to flat, I would have definitely done ALOT of analysis beforehand.
    y0bailey: if I ever get around to it, I'll post that up, or at least pics.
    socalMX and scfreak:
    Didn't really take any complete bike pics after we anodized the parts since it was getting late, but here's a shot of the complete bike out of the trails a few weeks back while I was out testing:
    Basically looks like any other Nomad, only with this mod, and my Hammerschmidt mod.
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    I think itz damn cool Holmes !!!!! If I had listened to some people when I built my arm I would've never gotten to the point I am now with it and my riding. HUUUUUUUUUUGGGGGGEE KUDOS !!!! I used Solid Edge for my modeling.
    "Why are you willing to take so much & leave others in need...just because you can?"
    Awesome...I love how you look at your problem objectively.
    Too many people here forget that they are indeed just bikes. When you step back and look at what it takes to alter it and what you want to get out of it - you know the costs/benefits associated with the project. If it works for you, great!
    awesome work! man, i knew i should have majored in MechE instead of Civil, ha ha. what is the material approximate thickness where you drilled/tapped the two M26 holes?
    94 Specialized Rockhopper
    ^^ Thanks guys!
    Quote Originally Posted by dth656
    There's about 3 threads of engagment... looked about 1/8" thick or thereabouts.
    Apr 2005
    The increased angle of the shock looks very similar to what SC did on the new nomad to achieve the same rate. Looks good to me, and like you said, you like it and that’s ALL that matters. Bike companies make bikes for the masses, its people like you that make them your own. Cheers to you!
    Enjoy every ride!
    Fat Guy Riding
    Reputation: jschwart73's Avatar
    If I drilled holes in my frame and took the time to machine and anodize parts like that, I'd convince myself that it was better too.
    I'd be curious to see the shock curve chart for that. I assume you did the math on the leverage ratio with the new length and mounting position, right? Post that up here for the world to see!
    Quote Originally Posted by Empty_Beer
    A bike company should come out with a bike named after Mikey. the Santa Cruz Vandeman. That would pisss him off to no end.
    Reputation: gticlay's Avatar
    If the bike rides good for you, then good for you! VERY cool mods man!
    "It looks flexy"
    Quote Originally Posted by jschwart73
    Yeah, so a coupl'a guyz here can stand back and shoot holes in anything you say you've come up with...... pffffft Gotta come off with a confrontational disposition instead of actin' like somebody and just ask nicely......
    Darwin in action.
    Yeah, so a coupl'a guyz here can stand back and shoot holes in anything you say you've come up with...... pffffft Gotta come off with a confrontational disposition instead of actin' like somebody and just ask nicely...... Let's see th' fruits of your labors....
    Fat Guy Riding
    I still want to see the math behind it.
    No matter how you slice it, without solid engineering behind it (knowing how to design the part in Solidworks is not engineering), it's a hack. However pretty the parts look, it's a hack. Without solid evidence that there is actual benefit to the work, it's a hack.
    Prove it's not a hack. Prove that it improves the shock curve without detriment. You put it out there for the world to see, so be open to the skeptics. If you don't want it criticized, don't post it.
    Lord of the Chainrings
    Reputation: Mudd's Avatar
    Apr 2002
    Very cool! Love your injunuity.
    You're like me....
    People tell me that things can't be done. I like to prove them wrong!
    I want to see your "Hammerschmidt mounting plate".
    I'm assuming it's for bikes w/o ISCG tabs.
    Something I'd be interested in buying for sure!
    "Hesitation is the Mother of Failure!"
    ~~ 951 for Dirt & Roadster for Asphalt ~~
    Apr 2002
    So do you have a full-up machine shop with CNC at your disposal?
    Black Dragon
    Guest
    Quote Originally Posted by man w/ one hand
    I agree man w/ one hand.
    ps. GREAT JOB Cosmo
    Black Dragon, Mudd, m-dub:
    Thanks again for all the positive comments!
    Glad to see that I'm not the only one that had jschwart73's last comment "rub off" the wrong way.
    Prove it? What for? Say I put up shock force vector vs. wheelpath data and you are convinced.... what then? Do I get a cookie? If you're not convinced, then what? No sweat off my back either way, bro.
    Where did I say I didn't want to be criticized? When I post up "out-of-the-box" ideas like this, I DO EXPECT comments, observations, constructive criticism, and even the critics. And of course I'm open to discussion, why would I post this otherwise? However, I choose to respond only to constructive criticism. But for the disrespectful criticism and out right attacks, I'll just refrain from commenting at all, since troll feeding usually ends up in a pissing match - far from my intentions of posting this thread.
    Quote Originally Posted by Mudd
    I want t see your "Hammerschmidt mounting plate".
    Just click the link I posted about to check out my custom HS adapter. Somewhere in there near the end I also posted a link on how to do the same thing using an off-the-shelf MRP adapter.
    Black Dragon
    Guest
    In reading your chain of posts, it's clear that you need to find something that is actually important to get all worked up about, instead of bicycles. Cosmos came up with something that many of us think is a great idea, be it perfect or not. You're acting as if he claimed it was perfect and that everyone should run out and make/get one. He didn't say that and he doesn't need to prove anything. Your comments could have been actually considered and discussed reasonably if you hadn't slid in all the insults.
    Apr 2002
    Quote Originally Posted by cosmoworks
    Cool! Hammerschmidt with ISCG Adapter on Nomad 1 with Grip Shift
    thread killer
    You know Cosmo.
    If you keep messing with bikes you'll have to invent the air plane next.
    Isn't that how the Wright brother's progressed?
    next time
    Reputation: JohnnyG 1970's Avatar
    The mount:
    Thanks for posting your 8 inch Nomad. Very cool !!! Let the haters hate. Nice job !!! Thanks for sharing it. Nice post by the S/C guy-MtotheF He even likes it. WELL DONE !!!! Very cool/ outside of the box !!!
    2011 Santa Cruz TallBoy carbon & 2013 TallBoy LT carbon - S/C All the Time !!!
    ^^ JohnnyG 1970, thanks man!
    You know Cosmo.
    Haha... me invent the next air plane? scary thought!
    Reputation: Bullit_cn's Avatar
    Great work Cosmo boy
    Very impressive skills and determination to drill your frame like that
    Cheers,
    When trails gets tougher, Just stand up and deliver.
    Ride Good or Eat Wood
    Reputation: Red PeeKay's Avatar
    I'm not entirely sure why some people seem to have gotten so worked up about what Cosmoworks has done. His bike, his prerogative. People don't have an issue with modifying the hell out of cars or motorbikes, writing mods or apps for computers, so why not mtbikes??
    He seems to have done his homework and if he is happy, fantastic. He's certainly not trying to convince us to change our ways, simply sharing his passion! Well done mate, more ballsy than me..... drilling your rig. Like the forum member who chemically stripped his brand new Nomad 2 to get the raw finish!! More wolves less sheep I say!
    "Though my life is changing fast,
    My roots are planted in the past,
    Who I am, is who I want to be
    the leverage ratio is going to be a lot different with the shock at that angle, for better or for worse.
    All the haters are jealous they can't pull that off. Good job making what you need out of what you got.
    Reputation: sooner518's Avatar
    wow, very cool although I admit I have absolutely no engineering background and know nothing about why that would or wouldnt work.
    my main questionis this: why'd you do it to both bikes?!i would think you would want to keep one stock and mod the other one. but hey thats just me.
    looks great. hope it rides well for you and hope it doesnt break your bike or your face
    ^^ Bullit_cn, Red PeeKay, mullet dew, sooner518: Thanks for the props guys!
    Quote Originally Posted by Bullit_cn
    Yeah, I think I shed a tear or two when drilling up the mount.
    Quote Originally Posted by ihatepedaling
    Very true statement. IMO, it's better. This mod, holds less of a falling rate throughout the range of stock travel. Actually lets me run a lower air pressure resulting in great small bump performance with a stiffer mid-stroke. Near the end, due to exaggerated link angles, the rate goes into more falling rate than the stock setup near the end of it's travel, but by then the air spring has ramped up considerably.
    Quote Originally Posted by sooner518
    The other Nomad 8 is my buddy's bike, not mine. I agree, if they were both mine, I'd keep the second one stock and fit up lighter components to it for less technical rides.
    y0bailey requested video, but I'm going to post image overlays since that depicts what's going on better.
    The purple/blue is the Nomad 8, burgundy/red is stock....
    Free standing:
    Nomad 8 -- 8" inch travel Nomad 1 with 9.5"x3" Shock-nomad_comparo_uncompressed.jpg
    Fully compressed:
    Nomad 8 -- 8" inch travel Nomad 1 with 9.5"x3" Shock-nomad_comparo_compressed.jpg
    PTP
    PTP is offline
    WWW.PEDALTHEPEAKS.BIZ
    winter projest like this are always fun its great to see someone step out of the box and take things into their own hands. While there could be some negitive points that have been brought up that could cause issue. At the same time its your bike and this mod is not being brought to the mrkt in mass numbers. This is why some people are into bikes because they like to tinker with stuff. Others just like to follow, and this industry is big enuff for all to enjoy.
    While off topic I did a mod on some old xtr cranks for my bmx bike and i got a lot of sh@#$ from people on a bmx forum and i have been running them for over a year and am planning on doing it agan for my dj bike. Now i know this is not as advanced as your mod i took xtr cranks and a profile bmx fly wheel and machined the spline pattern into it so i could get rid of the stock spyder. Then i took apart and old xtr needle bearing bb and cut spacers since my bb is a mid press fit in my bmx. Its different and was something to past the time during the winter months.
    <a target='_blank' href='http://img243.imageshack.us/i/pb220270hw6.jpg/'><img src='http://img243.imageshack.us/img243/2092/pb220270hw6.th.jpg' border='0'/></a>
    <a target='_blank' href='http://img243.imageshack.us/i/pb220271al8.jpg/'><img src='http://img243.imageshack.us/img243/7922/pb220271al8.th.jpg' border='0'/></a>
    <a target='_blank' href='http://img243.imageshack.us/i/pb220272ia7.jpg/'><img src='http://img243.imageshack.us/img243/9716/pb220272ia7.th.jpg' border='0'/></a>
    <a target='_blank' href='http://img74.imageshack.us/i/pb220269ea8.jpg/'><img src='http://img74.imageshack.us/img74/5416/pb220269ea8.th.jpg' border='0'/></a>
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    Skillz! Good on ya!
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    Reputation: Karve's Avatar
    Mar 2006
    wicked - love to see mods like this - Nicely finished parts too
    all your base
    Reputation: primefocus's Avatar
    Feb 2007
    My favorite thing to find on forums, sweet diy projects. Awesome work!
    Reputation: V.P.'s Avatar
    Nice, what a cool mod : ) thanks for sharing.
    Ride lots...
    Reputation: DSDuke's Avatar
    Awesome stuff Cosmo!! I like the chainguide adapter and may just do that one myself someday. As for the 8" upgrade--not likely but it is pretty cool stuff!!
    Again--I admire your ingenuity and also the way you deal with the haters. Offering constructive criticism is one thing, but posting up just to talk crap is laughable cyber-courage from MTBR's usual host of douchebags. If you're wondering if that's you, then yes--it is.
    Keep up the cool projects.I can't wait to see the next one!!
    I hope you have a big trunk... 'cuz I'm puttin' my bike in it.
    Pretty trick idea, like others I'm wondering about the shock leverage curve/ratios. VPP is pretty sensitive to proper set up, especially sag. For the DH setup I am thinking of trying the 8.75x2.75 coil shock with 35-40% sag to get the VPP in the sweet part of the curve. Should yield 7 inch travel, just have to check the clearance between the lower link and the bottom out bumper.
    I am running the ISX evolver, stock 8.25x2.5 size for all around duties. Having the 7X7 inch for bigger stuff would be a great option.
    PTP: Cool project! Build on!
    NoahColorado, Karve, primefocus, V.P.: Thanks guys!
    Quote Originally Posted by DSDuke
    Thanks Duke! I had a knee-jerk reaction to posting any more data after certain comments made my thread turned me off from doing so.... but there are likely way more genuinely interested viewers of my post than not. So while my comments of needing to prove myself still stand, I'm sharing some of the data (see below).
    Quote Originally Posted by motoguru2007
    motoguru2007, leverage ratio and other data below:
    I basically pull a slightly rising rate at the beginning of stroke and hold less of a rate falloff than the stock setup. While I haven't modeled up a Nomad 2 to compare, visual comparisons of the shock placement of the Nomad 2 suggest that the shock curve (in the same travel range) should look similar to the changes I've done on my Nomad.
    I've got my setup to sag on 25mm of shock stroke, putting me at around 2.75" of sag, and pedaling efficiency doesn't feel any different to me in the real world. For comparison, I ran the stock shock at 20mm shock stroke sag (around 2" bike sag). Hope that helps.
    Apr 2002
    Cosmo, let's get together and start a bike company!
    Reputation: biketuna's Avatar
    Great Job!!!
    _______________
    1x10 IS SO FINE on my 21.9 lbs IBIS SL-R
    11-36 XTR in the rear, 36T wide-narrow upfront
    Apr 2002
    How about a VP-Free with a 9.5" eye to eye shock on it?
    Mar 2006
    Fantastic work there Cosmo, you got mad skillz. And to the haters , go chew on a cactus.
    Mar 2006
    All the talk over the years has been of putting a shorter shock on it to lower the bb height. i think quite a few people have done it. If you could lower the bb height with a mount but keep the same spring rate im sure that would be of interest to a lot of current vpfree owners
    Reputation: dmx1's Avatar
    Dec 2008
    Nice work Cosmo. Obviously you know what you're doing.
    Apr 2002
    Quote Originally Posted by Karve
    After switching to an Intense Socom; (essentially, the same frame design as the VP-Free), with a lower BB height, I really miss the higher BB height of the VP-Free. A lot more "pedal smacking" going on.
    Thanks Mudd, biketuna seis and dmx!
    My last rig had a much higher BB than the Nomad, so when I went to the Nomad a few years ago, same thing... pedal smacking all over the place - hated it. Fast forward two years later, and I still smack them every once in a while, but I've gotten better at pedal placement and now prefer the lower BB.
    Yep, every time I read/hear some say they wish their frame had a lower bb I think "damn, my VP Free'z pedals were smackin th ground the whole time I rode it, they still do the same w/my 1st gen Nomad even w/the 8.75x2.75 CCDB I have on it. Theres no way you can get much lower and still do any pedaling. I think a bike feels more balanced when the bb is pretty much in line w/the ft/bk axles....jus my thought on the bb issue.
    Hey Cosmo, sick stuff. Gotta be some companies checkin your work out, I would think. Never the less AWESOME job !!
    TheNakedViking
    great design...how'bout patent it?
    Great Post, I think an 8" Nomad sounds fun, Just watch SC will release one soon :-)
    Quote Originally Posted by jeffus
    Yep, that would be the carbon one!!
    gnar, brah
    Reputation: Andrewpalooza's Avatar
    Dec 2004
    totes rad dude
    man that shiz is legit. i may post up in some bball b fo' i do dat shiz.
    Trestle Bike Park
  67. #67
    T.W.O.
    Reputation: mimi1885's Avatar
    You are the Man!
    Thanks Cosmo for posting very interesting ideas on your Nomad 8HS. I'm glad to see that the graphs came out looking great. Great looking machining as well. How much does it cost to do the machining anyways both ISCG and shock mount.
    I may have missed it but how does NM8 climb VS stock. how about geometry difference? Has people from Santa Cruz contact you yet. I wonder what they have to say about that. Hopefully all the good things.
    If you are bored and wanna tackle something new try this,http://www.gruberassist.com/ looks like the way you solve problems you can think Out-side-the-box and
    Keep sending us more new inventions
    Cheers
  68. #68
    ^^ Thanks again all.
    Quote Originally Posted by mimi1885
    Cheers
    Wow, that gruberassist thing is wild! Sure be fun to have that on the climbs if none of my buddies knew I had the "magic power button"
    Bike climbs well. I have a slightly slacker head angle since i use a 180mm fork but retained almost the same static BB height, which probably makes it a tad tougher to climb up a super steep hill. But in general, it's similar. I'd say energy-wise, it takes a tad more effort to climb, but on technical climbing it's a little easier since it's easier to keep traction on the ground with how supple rear's setup.
    No SC contact though, but they really have no reason to. I didn't do anything earth shattering and they already have their 8" bike, the driver 8. But it'd be neat to see them release something along the lines of what I've done - lighter duty 8" travel climbable bike.
    There's about $20-$30 in raw materials for the ISCG adapter and upper shock mount I'm guessing. The other cost is my time.... can't remember how many hours I put into the ISCG adapter, but there's about 12 hours of machining time in the shock mount.
  69. #69
    T.W.O.
    It's been 3 months how's the Nomad 8 holding up. Hope it's still as strong as the HS. I just got one on my Maverick design too. Let us know how's working so far.
    BTW, what sag are you setting up on the NM8.
  70. #70
    It's been working great! I have almost 1/2 a year of riding on the travel mod, and I love it. I recently took apart the shock mount to change the color of the sideplates, and everything looked great.
    I run around 1" sag on the shock. Hammerschmidt's are the bomb! Like dropper posts, once you get used to them you wonder how the hell you made-do without them before!
  71. #71
    T.W.O.
    By any chance are you selling any of these parts you've made. for the Nomad? I guess I can get the MRP adapter and have the ISCG face. But the shock mount is no way anyone is making. I don't have the nomad now but after reading about it I'm interested.
  72. #72
    Like you said, there's no reason to make another ISCG adapter when the MRP one works. No dice on the shock mount - I don't have an interest in selling... sorry.
  73. #73
    T.W.O.
    Cool, thanks
  74. #74
    Mountain Lion Bait
    Reputation: renderedtoast's Avatar
    My Bullit2 handles all my downhill duties. I like my Nomad as it is.
  75. #75
    Reputation: vikb's Avatar
    Wow...another impressive DIY mod...thanks for sharing....
    Safe riding,
    Vik
    www.vikapproved.com
  76. #76
    Nov 2008
    heres another 8 in Nomad
    Cosmoworks
    One of the guys who works for me saw your 8 in mod and immediately started looking for a frame so we could do one. Thanks to your detailed analyzing of the linkage I agreed with him that it was workable and should be a worthwhile project. he already has a normal Nomad but wanted something burlier for the downhill trails. So this is how we built it.
    Fox DHX 5 coil - 3in stroke 9.5 eye to eye.
    2010 boxxer world cups( he hated the stickers so he removed them)
    A set of my 1 degree headsets to slack it out and lower it slightly
    26 pedals,sunline stem and bars, old saint brakes, sram x-9 shifter and derailler, Gravity dropper 4 in.
    The wheel set is a Maviv deemax which he bead blasted to make it silver and the hubs he bead blasted and had anodized blue - along with the 26 levers, brake mounts, bars and stem. He had the spring powder coated white. The seat will be going away - he is waiting on one that matches the colors of the bike.
    The final dimensions of this medium framed bike are, 44.75 wheel base, 14.7 BB height, 65 degree head angle, weight as pictured -37.5 lbs.
    I was a little aprehensive about how it would ride and how much trouble tuning the shock would be. I should not have worried! Although I would not class it as a downhill race bike, the handling is very good and feels right. I would say it is a very good all around freeride/downhill/parkbike. The shock setup was very easy to get it supple and to take the larger hit plushly without bottoming.
    Bottom line - if you know someone with a machine shop that like to mess with bikes - this mod is definitely a keeper, a bit on the advanced side of tinkering with the machine work, but not complicated.
    Attached Thumbnails Attached Thumbnails Nomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-8nomad-010.jpg
    Nomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-8nomad-011.jpg
    Nomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-8nomad-012.jpg
    Nomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-8nomadweb-002.jpg
    2008 SC V10, 2009 IBIS MOJO, 2009 SC V10, 2008 INTENSE 6.6, 2008 Intense Socom,2010 Nomad carbon.
  77. #77
    i like these DIY mods!! is that a pure bolt on adapter or did you have to drill? any more specifics on how it rides?
    good stuff and keep those creativity juices flowing....
  78. #78
    Nov 2008
    I machined it so that it rests on the down tube and on the top forward part of the standard mount and used the factory pin thru the hole. Was probably more screwing around, as I basically had to hand cut a template, then measure the template on the optical comparator then draw it up in cad and do the program - and then still had to tweak it a bit.
    Picture is a bit blurry at the ends where itis touching the frame - but hopefully you can see what I mean.
    Attached Thumbnails Attached Thumbnails Nomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-8nomad13.jpg
  79. #79
    Nice work BATM!! I like the extension that rests on the downtube... didn't even think of that!
    You probably had to tinker with it to make sure your adapter had no "rocking" play once it was bolted in. I guess either of us could have gone a step futher and incorporated some kind of adjusting bolt to push against the down tube or back half of the stock shock mount to take out the play once the shock is mounted.
    All in all, I like it! Thanks for sharing!
    The nomad 8 twins now have a half-sister out there!
  80. #80
    Nov 2008
    Cosmoworks
    Actually machined it about .1 tall on the leg that rests on the down tube and then did the old cut and try method to get it down to where the pin would go thru snugly.
  81. #81
    Reputation: mtb777's Avatar
    Dude, no matter what anyone says....good job...great idea, and fit and finish. As you stated, you are not racing DH and you could stress the frame the same as a race on the trail anyway. I did the longer stroke shock on my Heckler a long time ago and it worked great for me. Maybe no one else cared but I liked it! You took time to do a professional job and it shows. It seems if you removed and sold the bike if you added a filler bolt with a tight shim sleeve there would be no loss of strength with the bolt filling the lost material in the mount arms. It also seems that the new mount would take most of the shear through the original holes with the new holes taking care of additional rotation added by relocating the pivot above the original centerline of shock. Too bad I just sold my Nomad!!!!! You gonna put one of them there new Fox 36 180's up front? How much are the kits going to run?? Hehehehe.
    IF YOU CAN READ THIS, YOU'RE NOT RIDING (or building)!
  82. #82
    BATM:
    Makes sense. Once again, clean work!
    mtb777:
    Thanks mtb777. No kits to sell, but honestly if I sell this frame, I'd sell it as the Nomad 8, since I think it's a selling point. I have a 66 on the Nomad right now, but when that fox 180 comes out, it's definitely replacing the 66. It's almost a freakin pound lighter!
  83. #83
    Apr 2002
    Love it! You guys did a heckofa job! Wish I had access to a machine shop. I'd be right there as well.
  84. #84
    Reputation: Terminator Z's Avatar
    Feb 2007
    Just by looks, I'd prefer your 8 Nomad over the Driver 8. The DC, coil setup looks sick!
  85. #85
    Reputation: mtbmoto's Avatar
    Oct 2010
    Back from the dead....
    Just when you thought it was over....Nomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-img_20140223_143845.jpg
  86. #86
    all your base
    Feb 2007
    Quote Originally Posted by mtbmoto View Post
    Clean!
  87. #87
    Oct 2010
    Attachment 874240What you are looking at is my take on an 8 inch Nomad. This variation of an 8 inch Nomad uses a push link to achieve the increase in travel. The standard Push Link set up uses the stock shock that measures 8.5 inches eye to eye with 2.5 inches of stroke. But Push changed the suspension compression curve by creating a new upper VPP link. The shock mounts to the link in a much different location that the factory Santa Cruz link. The shock mount on the push link is about one inch further back (23.??mm is the best I can measure) than the Santa Cruz Link. To make up for the difference in length Push has created a supper sweet shock spacer so that the factory length shock will work. The Push link was created to change to the compression rate of the rear suspension. it increases the rising rate and initial leverage thus producing maximum small bump sensitivity, traction, and DH bump performance when used with a rc4.
    What I have done is removed the spacer installed a 9.5x3 inch shock. It in turn steepened up the head angle a little less than .5 degree. I have a Fox 36 180mm which slacked out the front quite a bit but I like a more dh style fork angle so I installed Cain Creak angle set using the 1.5 degree cup. The XFusion air shock works very well and has 2 speed compression adjustment. That shock allows you to run lower air pressure and have really good bottom out tune ability. As well as being very light.
    These modifications will make the Engineers at Push and Santa Cruz scratch their heads and have them asking why but All I can say is just ride it. The bike is so nice descending the rear suspension is so easily tuned. The feeling is truly bottomless. The climbing ability has only improved the slow tech single track is so much more fun. the bike sets in to corners like it is on rails and launches out of them like a puma chasing dinner.
    I have ridden the new set up for around 50 miles on some really good dh trails here in So Cal and it has held up very well. I hope the new Nomad will be able to hang!!!!
    Attachment 874236Nomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-vector-air.jpgNomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-top-jedi.jpg
    Attached Thumbnails Attached Thumbnails Nomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-head-set-ajustment.jpg
    Nomad 8 -- 8&quot; inch travel Nomad 1 with 9.5&quot;x3&quot; Shock-jedi-fog.jpg
  88. #88
    That's an awesome creation!
  89. #89
    Reputation: miles e's Avatar
    Very cool experiment- what does it do to the bb height though? Alternatively, I suppose you could remove the spacer on the Push link and run the stock shock length for a nice low BB?
    ''It seems like a bit of a trend, everyone trying to make things longer over the last couple of years" Sam Hill
  90. #90
    FYI, Sooner or later you are going to blow out the front mount of the shock do to the excessive leverage your new clamp add to the loads..
  91. #91
    Oct 2010
    Thanks for the props guys!!!
    Quote Originally Posted by miles e View Post
    The Original bottom bracket hight is 14.00 inches.This set up measures out at 14.25. That is a quarter inch higher than stock. That difference in bottom bracket hight is primarily due to the 2.7 inch Maxxis DHF front tire and the 180mm 36 Van front fork.
    I like your Idea of using a stock length shock with no spacer. That would drop that bb way low.
    How about running a 8.75 x 2.75 shock with no spacer? BB drops, forks go chopper style and about an inch more travel???
  92. #92
    Oct 2010
    Quote Originally Posted by patineto View Post
    Thats why the Push Link set up is so cool. It does not add any clamps to the frame. Check it out.
