Results 1 to 27 of 27
    Nickle build... need advise!!!
    Getting in a few days this mint Nickle (FRAME ONLY), RP23 rear shocks, sizing is small. After a very long wait (Nickles being a rarity nowadays) It will be soon be up for building. I have already collected the components to build it up:
    Fox Float 36 RLC 160- will have to lower it, how low should be good for the Nick? I will be going with the 27.5 build. what front travel is best? 120mm? 130 mm? or 140 mm? How can i mimic at least the ride and feel of a Blur TRC or a 5010? With the APP i guess this would perform better (in theory) than the Bantam. imho???
    Will be using XT build kits, WTB i23's, Ardents, Haven handle bar and stem, and a sweet mechanical dropper post...
    Reputation: smmokan's Avatar
    I think the sweet spot for that frame up front would be 140mm of travel. I have a Blur LT that is build with 27.5 wheels and I have a 150mm up front (with 140mm in the rear), and it handles great. The BB is a little high, but I prefer it as I live in Colorado and deal with a lot of pedal strikes.
    Reputation: Bro_cro_xc's Avatar
    Mar 2006
    Re: Nickle build... need advise!!!
    What types of trails do you usually ride? Which was your previous bike?
    Give us more info because longer travel is not always better...depends on usage.
    Thanks for the input smmokan!!!
    Quote Originally Posted by Bro_cro_xc View Post
    Bro_cro_xc I agree with you. Trails i ride are a mix of long sweeping fire roads, technicals single tracks. Reason I got the Nickle was to complement my Nomad and Superlight. Something in 'between' so to speak. The Superlight is a 650B conversion. Planning to put it back to a 26'er and swap on the 650B tires to the Nickle. I'm aware that it might raise the BB a bit but in previous forums they say it works well. Was going to get a 5010 or TR but cash is a bit tight and i hate to pass on a great deal on 'rare' Nickle. Next question is, would the 140mm up front and 650B work well? or do I have to lower the fork further??? thanks again guys!
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by saddle pimp View Post
    Reasoning? Other than using the wheels for the Nickle?
    Wait whuuut, who did he tell you that!?!?....
    i feel that the 650B SL is a bit heavy, maybe due to the wheelset, wtb i23, dt swiss champion spokes and nipples, Kenda Nevegal 2.1. I think it is better suited for the Nickle. as it will be my trail bike. I might be wrong bringing back the smaller wheel size but, I plan to make it as light as I can and I have a XT WH-M778 tubeless 26 wheelset I don't want to go to waste. =)
    Reputation: jrsbike's Avatar
    See following comments I messed up the posting.
    Attached Thumbnails Attached Thumbnails Nickle build... need advise!!!-dscf0586.jpg
    This is my 650B Nickel that came in at 27.5 lbs, Note how I routed the cables along the top tube to the top of the rear. This makes for a shorter and cleaner cable run. I don't understand this new business of long cable runs that can catch things and reduce efficiency. I installed Burgtech shock adapters which brought my BB to 13.5 which is perfect for where I ride in New England. After trying different lengths I found that my 26" Fox at 140 works best.
    Quote Originally Posted by jrsbike View Post
    Thanks for the picture, looks like you have it all figured out. At 26 wheels, BB is 13.6 (130 mm fork, SCB website) And I plan to slap on a 27.5 tire, I'm a bit worried about raising the BB a bit. But I'll take it for a spin once I finish the build. If I am happy with the BB height i'll keep it that way, but if not I'll get a burgtech Shock bushing... can you please share the link of where you got the off set bushings? thank you!
    I am surprised that the BB height with 26" wheels is 13.6. I was at 13.75 with the 27.5 wheels before installing the Burgtec bushings. I rode it that way for a while and found it fine especially since my rocky/rooty terrain results in pedal strikes. The new generation of bikes with low BBs wont work here for typical riders. Their address is
    Burgtec | Shop Burgtec Penthouse Flats. The Nickel geometry as published by SC is based on a 130 RS Revelation. The AC for a Fox 140 is just about the same.
    My trail are mixed so will test out first at it's current set up, will post pictures and review. Many thanks!
    Reputation: rinconjake680's Avatar
    650b Nickel here, also with 140mm up front, with no complaints. The bb is a little high, but the lack of pedal strikes for me is worth it. But I am very intrigued by the Burgtec bushing.
    Attached Thumbnails Attached Thumbnails Nickle build... need advise!!!-_mg_4156.jpg
    Quote Originally Posted by rinconjake680 View Post
    Nice build there... like you I'm interested in making the BB a bit lower,,, I'm at work right now and wont be home for a couple of weeks more, i'll try out the Nickle first at stock BB with the 27.5 wheels. from there, we'll see if I will try the Burgtec...
    Shout out to JRS... what size of bushings does the Nickle use??? thanks
    Got it!!! the build starts... one thing I noticed, there are no water bottle bolts under neath the down tube as pictured in some models... what version did I get???
    With the curved down tube, it appears you got the same as mine ('10-'11)
    But mine has bolt holes on both inside and outside of down tube.
    I had the chance to get a newer version, the olive green and with kashima RP23, but i opted for this, not impressed by the last version of the Nickle, I wanted the old classy santa cruz decals, and the curved downtube is working for me... is it because of the size? why there are no water bottle mounts on my frame? it is sized small by the way... itching to build her up... 2 more weeks of work...
    I would really like to know if you can use the offset bushings with 650b wheels. Will there be clearance problems?
    Anyone try this successfully?
    Quote Originally Posted by richulr View Post
    subscribing... =)
    what's the stock size of the Nickle?
    I saw an ad of a fox rp23 kashima 7.5 "x 2"
    Specs:
    Rebound Tune M
    Velocity Tune M
    Boost Valve Tune 200
    would this fit the Nickle? ty
    Jun 2012
    7.875 x 2
    I dont know what the dimensions are but you could check the Burgtec site.
    I did not have a problem. You don't lose travel and everything seems fine in back. I was wondering is you could use a shock with the same travel but shorter eye to eye and drop a little height that way. Both Fox and RS make these.
    Quote Originally Posted by DYI01 View Post
    7.875 x 2
    got it thanks!!!
    If I had money to burn its an experiment I would like to try
    second that!!! =)
    I know you have the same travel, but the offset bushings kind of bring the rear triangle a bit closer, right?
    It still clears the seat post under full compression?
    If so I'll probably get some.
    Done!!!
    build is finished... here is a short list of the specs!
    Frame: Small, RP23
    Fork: Fox Float 36 RLC lowered to 140 mm
    Cockpit: Haven 55mm stem, haven Handle bar, Tmars mechanical dropper post.
    Groupset: XT 2x10
    Wheelset: WTB i23 650 B, DT swiss spokes, 20 mm Thru axle XT front hub, Zee 12x135mm TA rear hub bolt on.
    Tires: Maxxis Ardent 2.25 front and rear, tubeless
    over all a fun bike, i feel it is more 'flickable' compared to my Nomad 2 even if it has the 27.5 wheels...
    Enjoying the bike very much... only a couple of rides so far... still more to come...
  1. Need Expert Advise For A Build
    By givati in forum 27.5
    Last Post: 03-09-2013, 10:39 PM
  2. Heck or Nickle 650b opt ?
    By grandsalmon in forum 27.5
    Last Post: 11-22-2012, 09:15 PM
  3. Wheel build advise
    By thehotrodpig in forum Wheels and Tires
    Last Post: 01-19-2012, 05:08 AM
  4. Wheel build advise
    By KEITH21 in forum Wheels and Tires
    Last Post: 10-22-2011, 08:54 AM
  5. first build from scratch - advise, suggestions
    By sprocket47 in forum Where are the Best Deals?
    Last Post: 03-22-2011, 07:42 AM
