Nickel gxp bottom bracket question
My lbs built my nickel and i have a x9 crankset gxp bottom bracket.
The nickel has a 73mm bb and sram says no spacers should be used but he used a spacer on the non drive side and said it had to be done.
this sound right??
 Originally Posted by vizsladog
this sound right??
No. I'm using an old FireX crank, GXP. No spacers.
Your LBS needs to RTFM. No spacer on sram gxp using a 73mm BB shell.
Get another bike shop....He's confusing Shimano and Sram. 73mm BB on Shimano takes one spacer on the drive side and none on the left. Sram takes no spacers on 73mm.
- You may not post replies
- You may not edit your posts
Forum Rules
