Results 1 to 30 of 30
    Reputation: Burak's Avatar
    New Heckler Swingarm Maintenance
    Hello to all,
    my back swingarm is cracking, so i decided to unmount it and to check the mechanism.
    I used this sheet : http://www.santacruzbikes.com/tech/s...k_bearings.php
    My problem is that i'm stick at step 3 c and 3 d.
    i didn't success in removing the axle. I tried with a maillet but it did'nt work and i'm afraid to hit too strong. I hit the 5mm alen wrench side to push out the axle from the other side but it didn't work.
    Please can you tell me what am i doing wrong ?
    Thx
    Old man on a bike
    If you're swingarm is cracking, are you swapping out swingarms? I'll take it you mean creaking and you're doing a service? Do you have the latest Heckler? After you loosened the cap did it protrude a bit so that when you whacked it with a mallet that it moved the axle or are you saying that it's not moving and you think you're giving it a sufficient whack?
    suum quique
    Underweight Rider
    Reputation: AznRider's Avatar
    Snap a few pics, pic says a thousand words.
    Well i'm going to explain it again with my poor english.
    I have a sound coming form my swingarm while i'm pedaling on flat or uphill.
    I located the noise it's coming for the swingarm and it's doing a kind of "crack, crak crak"
    when I excerce a side force on the swingarm. So i decided to unmount it and i download the technical sheet from SC website. My Heckler is the new heckler model.
    I'm blocked at the step where you have to move the pivot axle out. i taked out the pivot cap, but i'm unable to take out the axle, i even don't know from which side i have to take it out.
    Axle cap side
    Other side
    Old man on a bike
    So when you unscrewed the pivot cap a few turns (and left it in partially unscrewed), and then tapped on the cap like the instructions said, the axle didn't move? Or you took the cap off and didn't try and tap the axle out with the cap? It's a good way to start, although you can tap the axle out with just a punch or similar.
    suum quique
    Quote Originally Posted by Bikinfoolferlife
    So when you unscrewed the pivot cap a few turns (and left it in partially unscrewed), and then tapped on the cap like the instructions said, the axle didn't move? .
    That's right that's the step where i'm stick. I hit with a maillet few time the pivot axle with the cap unscrewed on it but nothing move !!!
    If is this a punch i don't have it
    I tapped also with a large alen wrench on the cap side of the axle but without the cap and it didn't move either
    and i'm afraid to tape too much and damage the cap side
    Well, i changed my tools and took something heavier in place of the mallet.
    I found also something with the exact diameter of the axle so i can take out the axle without damaging the cap side. I hitted strongly and the axle come out.
    The result are clear all my bearing are ****ed up
    Jan 2005
    Woh man did you notice the cracks in the paint around the welds on your bottom tube?, you mightve hit it too hard bro! Looks like youve cracked the welds, fark i hope im wrong for your sake.
    Jan 2005
    I just noticed in your first pics that it looks like you have cracks in your frame before you wacked it hard. Keep your pics incase you need to show SC for warranty issues.
    Gotta wonder if thats were your cracking/creaking was coming from!
    Reputation: al_bullit's Avatar
    They are not cracks, thats the edge of the 'copter tape on the underside of the downtube.
    No man no "crack" around, i was just talking about "cracking noise".
    I think that the noise come from the balls into the bearing that are so rusted that it's giving that noise.
    Here is more pict
    You just saw the dirt under the protection sticker that i put under the bottom tube
    Jan 2005
    Doh! yeh its clear as day now! on the top side of the bearing housing on the other side it looks to have a scratch and when i put the two together. Well i jumped to conclusion i guess Stupid frame i wish it was cracked now just to be right, na just joshin
    Ah i see now, no it was hust white grease
    Jan 2005
    Dont qorry i do this kinda yhing all the yime
    Bike Breaker.
    When mine rusted I ordered a pair of these sks ones, though had a free set anyway, one thing to notice with mine I really sealed them up with grease.
    http://simplybearings.co.uk/shop/p55...7e204e0a3b1673
    Isn't the Heckler included in the lifetime bearing warranty thingie?
    Bike Breaker.
    Yes they do, though my fuel cost to the bike shop for them to see would have been a lot more than the sks bearings.
    there is no lifetime warranty for bearing...
    I called SC France & Belgium distributor and there is no warranty for my situation !
    Quote Originally Posted by Burak
    To quote from the distributors own website (www.raceco-mtc.com)...
    "Axe mono-pivot montÚs sur un axe de 15 mm avec garantie Ó vie des roulements"
    Which in english says "Single-axis mounted on a pivot axis of 15 mm with lifetime warranty bearings " according to Google (my French sucks).
    I'd be straight back on the phone!
    Ok i called my store, i have to unmount the bearing, there are going to send them to the distributor who is going to send it to SC California. Then "maybe" they will send back new bearing. May be ...
    But i already order the ProPack
    Man, that seriously sucks! I'm flabbergasted SC have such a complicated setup for France.
    here is my home-made press for swingarm bearing
    now i have to build the bearing remover
    I received the propack
    Underweight Rider
    Hmmm......ok that will remind me to get aftermarket SKF/INA/Timken bearings and stainless steel bolts from my local hardware store
    Yop, the bike is mounted and lubricated . Maintenance is over but we lived some hard steps : on of the bearing explosed inside the bore, and external ring stilled stick inside the frame, we got it at the end but it was very epic. Installing bearing, with the press was also stressfull. Getting them parallel was hard you have to be patient and do it little by little.
    Bike Breaker.
    Same happened with me though nex time I will strip the forks off as the bearig remover didnt hit the hearing square on, I had to sent the frame back to SC UK and they were superb and got a 'remover' from the states to get it out. I'll have my heart in my mouth next time i have the bearing out.
    Here we are, the bike is mounted and ready for the enduro race of tomorrow
