Results 1 to 5 of 5
    Nov 2007
    N3 lower and upper pivot maintenance
    anyone torque the upper and lower pivot to 35 in/lbs? Seems to be too tight when doing a compression seated test.
    Attached Thumbnails Attached Thumbnails N3 lower and upper pivot maintenance-image.jpg
    Reputation: expatrider's Avatar
    Jun 2010
    Last time I set them at 3nm, so less than 35 in lbs - you just want them only tight enough to remove any play, no more.
    Nov 2007
    Quote Originally Posted by expatrider View Post
    thanks... did somewhat that, just tight enough to remove side to side play.
    Feb 2015
    Where are you finding these images at? I still haven't seen anything on the SC site about N3 maintenance.
    Reputation: nauc's Avatar
    if its not from the SC site, id contact them. thats too nice of a bike to use something you found online
    2010 GT Avalanche Expert
  1. SID Brain SA upper with DA lower?
    By Le Duke in forum Shocks and Suspension
    Last Post: 10-16-2014, 09:56 AM
  2. somewhere in socal- upper jaw to lower jaw
    By dezul43 in forum Downhill - Freeride
    Last Post: 09-10-2013, 08:18 AM
  3. Upper/lower Jedi
    By bestt in forum California - Socal
    Last Post: 12-23-2012, 11:31 AM
  4. Upper and Lower SF Skokomish, need help
    By ggluv in forum Washington
    Last Post: 03-20-2012, 07:06 AM
  5. Upper and Lower EG Pivot
    By iammemares in forum Titus
    Last Post: 01-18-2012, 10:07 AM
