Results 1 to 6 of 6
Thread: mY LizArd
    LizArd Help
    I need help w/ 99 Lizrd build. I'd like to do it up SS for trails.
    What size is the seatpost ? BB ?
    Do I need to run a wheel tensioner or will a bolt on hub hold the wheel OK ?
    Suggestions on a suspension fork ?
    Suggestions on gearing for northeast aggresive trail riding ?
    All about the ride
    bump
    All about the ride
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Quote Originally Posted by greenmacheen
    Seatpost should be 27.2
    BB should be 68 x 113
    Bolt on axle should not need a tensioner. QR wheels may require a tensioner.
    100mm suspension fork for a more XC feel. 130mm for more all around trail bike. Look for a fork that locks out in the extented travel.........Rock Shox/Fox.
    Don't know about gearing.....I am in So. Cal.
    Big help.
    I'm going to trade ona Vanilla RLC 130mm
    All about the ride
    Reputation: mr.chameleon's Avatar
    hope this helps. this is my setup minus the SS mainly becuase i love getting that 3rd ring
    <a href="http://photobucket.com" target="_blank"><img src="http://i6.photobucket.com/albums/y241/360madness/DSCF0662.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
    Mar 2006
    BB shell is 68mm wide. Spindle length is dependant on chain set fitted. Chameleon has track end drop-outs so no tensioner required - it should come with vertical drop-out/gear hanger adaptors. Gearing - as always best thing is to ride a geared bike on your trails, find the best compromise and replicate the gear inches. Mainly gentle stuff a gear around 52 inches works for most - adapt from there. A QR will work fine if you make sure it is a decent steel one - Shimano are the most reliable.
    Fork? I ride rigid but the reply above is spot on I think.
