Results 1 to 16 of 16
    Lower headset for Tallboy C
    Hi,
    Can anyone PLEASE tell me the part # for a lower headset assembly for a TB C using a tapered fork?
    Been rummaging through all the posts and my eyes are glazed over.....
    Cane Creek part # or equivalent would be great..
    Thanks,
    Mike
    Reputation: argibson's Avatar
    It is any external cup 49mm type with a bearing for 1.5" lower steerer diameter. Cane creek 40 series is a good value, but tons of options.
    Team Summit Bicycles-San Rafael, CA
    RACE BLOG- http://http://summitcallup.ning.com/profile/RyanGibson
    http:// http://www.ebay.com/itm/Cane...item20c840cf5c
    zs= zero stack
    ec= external bearing
    Reputation: Steve.E's Avatar
    Cane creek zs40 (49mm bore) works great on my trc.
    Santa Cruz Blur TRc
    Reputation: robsetsfire's Avatar
    The Tallboy C uses a standard (external) 1.5" lower cup.
    Lower Cup:
    SHIS:EC49/40 - 1.5" Traditional (TR 1.5")
    The above post that stated they were using a ZS (zero stack) lower cup will not work. There is no ZS lower cup that runs a 1.5" steerer into a mixed taper (or even 1.5") headtube.
    To use a tapered fork these are the cane creek parts:
    The Cane Creek mid level:
    Cane Creek 40.EC49/40.Bottom Assembly
    The Cane Creek top level:
    Cane Creek 110.EC49/40.Bottom Assembly
    Reputation: gdtrfb24's Avatar
    When you use the cane creek headset finder is shows a EC49/30. What's the difference between that and the 49/40?
    /30 is for 1.125" steer tube
    Thanks. Yes, I have a straight steer tube.
    You want the 49/44 conversion headset. if you have a straight 1 1/8 steered. Non tapered.
    Quote Originally Posted by kidd View Post
    The fit finder is correct... the bottom half is 49/30, you can do zero stack or external. I don't even think they make a 49/44. The number before the slash is the size of your head tube. (49 for 1.5" lower) The number after the slash is the diameter of the place the crown race mounts on the fork. (30 for 1.125" fork)
    Top Headset:
    SHIS:ZS44 - 1-1/8" ZeroStack (ZS) Threadless
    Bottom Headset:
    SHIS:EC49/30 - 1.5" Traditional to 1-1/8" Conversion
    or
    SHIS:ZS49/30 - 1.5" Traditional to 1-1/8" Conversion
    I was thinking tour and bottom.
    Oct 2007
    I have a cane creek 40 set laying around
    PM Me. It's for tapered. If I recall you can use tapered bearings with a straight steerer if you use one of these base plates:
    2013 Cane Creek 110-Series Conversion Crown Race - Competitive Cyclist
    Thanks but I'm good. Purchased the ZS44 - 1-1/8" ZeroStack and the EC49/30 - 1.5" Traditional to 1-1/8" Conversion and had the cups installed today.
    Quote Originally Posted by gdtrfb24 View Post
    Just bought a Tallboy frame from the SC sale and trying to figure out the headset issue for a straight steerer, but would like to have the option of keeping the same headset if I go to a tapered fork. Does the EC49/30 - 1.5" Traditional to 1-1/8" Conversion bottom headset you bought have a crown race that is doing the reducing that could just be replaced?
    Or does anyone know if I should just buy the normal 1.5 bottom headset and figure out where to buy the reducing crown race. Does it work this way?
    As I understand it, the answer is yes. When I upgrade my fork to a tapered steerer, all I will need to purchase is a new 1.5 crown race for my lower cup.
    The other option is to buy a new 1.5 lower/bottom bearing cup which comes with a 1.5 crown race.
    Thanks for the info. I'l get on ordering the headset now.
Hot Deals
Contests
Latest Mountain Bike Articles
