FAT BIKES
WINTER APPAREL
TRAINERS
Page 51 of 52 FirstFirst ... 41 47 48 49 50 51 52 LastLast
Results 1,251 to 1,275 of 1282
  1. #1251
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    This guy has a set of red Opium rims laced to a 135mm hub. Again, contact CB as I'm pretty sure you can custom build wheelsets (ie: iodine rims on 150mm, Opium rims on 135mm, etc...). You can also try contacting the guy in the link.
    none at none in Kelowna, British Columbia, Canada - photo by ugottabjoking - Pinkbike
    2016 Wilson
    2015 Carbon Troy
    2016 Farley 5
  2. #1252
    Reputation: boost's Avatar
    Nov 2007
    Quote Originally Posted by pipes10 View Post
    That's exactly what I'm aiming for. Thanks pipes
    I'll see how I can manage to order or have this done from where I am (Hong Kong) but I'm sure there's a Crank Bros distributor here.
  3. #1253
    I am Specialized
    Reputation: tp806's Avatar
    Nov 2008
    Thread bumpage:
    '09 SC Nomad Mk2 alu: best AM/Enduro bike by far still going strong!!!
    2013 Iteration:
    Attached Thumbnails Attached Thumbnails Lets see those new Nomad Mk2's-331731_427859180616145_461695894_o.jpg
  4. #1254
    Love this bike my do it all...
  5. #1255
    Nov 2007
    mk2
    my other bike
    Attached Thumbnails Attached Thumbnails Lets see those new Nomad Mk2's-image.jpg
  6. #1256
    Reputation: vikb's Avatar
    Overhauled my Nomad this past year:
    - new front triangle [went from XL to L]
    - painted rear triangle to match [sort of!]
    - Velocity P35 rims + Hope Pro II hubs
    - Conti Trail King 2.4" setup tubeless
    - Shimano Zee 10spd with 11-36 cassette + new SRAM chain
    - fresh RaceFace 32T ring + MRP GS SL guide
    - Kona Wah Wah pedals
    - Selle Anatomica saddle
    - Spank bars
    - had Avalanche tune my Fox DHX Air 5.0
    - installed SC Pro Pack in VPP
    My bike feels new!
    How she looked when new.
    Safe riding,
    Vik
    www.vikapproved.com
  7. #1257
    We pimped out my GF's Nomad as well - mostly the Velocity P35 rims on her stock hubs + Conti Trail King tires in 2.4"....
    Safe riding,
    Vik
    www.vikapproved.com
  8. #1258
    I installed the eThirteen TRS dual chain guide on my Nomad. Whenever I am in the large chainring and a lower gear in the rear and back peddle the chain will want to slide over on the pulley wheel, then drop to the smaller chain ring. How can I stop this, it's quite annoying? I have the pulley as far forward as it can be slid (32 tooth chain ring) and I have the chain guide rotated as far clockwise. Any thoughts?
  9. #1259
    Rider
    Reputation: robin_hood's Avatar
    Feb 2006
    anyone know if you can swap the rear triangle from a 2010 to the new 142x12 rear triangle?
  10. #1260
    Reputation: Znarf's Avatar
    Man vikb your bikes are fantastic.
    Great colors!
    The GF will be happy!
    Greetings Znarf
  11. #1261
    Dec 2010
    nice bikes all of them!!!!...
    are some one interested in selling your frame???... I have a Talas 32 - 1.5in ST - 150mm Travel -15mm TA to use... Im between small and medium size...
    best regards...
  12. #1262
    Quote Originally Posted by Znarf View Post
    Great colors!
    Greetings Znarf
    Thanks! The GF's turned out super nice. She's stoked. We'll be taking both bikes to Sedona AZ to get 'em dusty!
    Safe riding,
    Vik
    www.vikapproved.com
  13. #1263
    Rider
    Feb 2006
    Lets see those new Nomad Mk2's-nomad.jpeg New to me 2010, loving it so far.
  14. #1264
    I'm planning to use a TALAS RC2 180 mm. Will this be a huge improvement with my Float 36 160 mm??? Or can I get 180 float instead? any feedback for those who have tried it is much appreciated...
  15. #1265
    Reputation: bullit43's Avatar
    Dec 2010
    Quote Originally Posted by saddle pimp View Post
    No it wont be a huge improvement ( or even a improvement),Talas is know for having more stiction than a Float,you wil gain in travel but loose in front tire grip and spolied your geometry.Keep your money and spend it elsewhere.
  16. #1266
    thanks for the reply... how about an angle set? what's the stock HA on a 160 mm Fox Float? How much will I add? .5, 1, 2?
  17. #1267
    some know me as mongo
    I'm not sure how you are using your bike but I am acutally lowering my fork on my nomad tonight from 170mm to 160mm to actually have a steeper headangle because I have been having a fair amount of front tire slip. if you have to climb alot of your rides don't make the front end of your bike too tall or slack. it will really kill your climbing performance.
  18. #1268
    Calm Like a Bomb
    If memory serves me correct, the HA with a 160mm Float and a CC XXII bottom cup (stack of about 10-12mm) is 66.5*. I'm running an Angleset to slack it out by a degree and its at 65.4*. I'm really not noticing much hindrance when it comes to climbing but it feels amazing on the descents.
    2016 Wilson
    2015 Carbon Troy
    2016 Farley 5
  19. #1269
    will try it out, i have a cane creek angle set lying around, still haven't got the chance to swap it out. I'll start with 1 degree then check if there is any noticeable change...
  20. #1270
    In my opinion, -1 Angleset is pretty much a must for Nomad. The default 67 HA is outdated for a bike in this category and makes the bike feel like xc/trail bike. Angleset makes it like a modern AM/Enduro bike, and is much more confidence inspiring on downhills.
  21. #1271
    a slacker angle would be the answer then? this would be my first time to play around with angle head sets so any advice with this set up is much appreciated. thanks guys!!!
  22. #1272
    Reputation: cman8's Avatar
    bought and built this nomad in january. finally got to ride it as the snow has melted. Let me tell you the CCDB air is awesome. Wish i could afford one for my other bike. KS LEV on the way
  23. #1273
    I can't believe there haven't been any new posts in this thread since 2013!!
    We've got 2 Nomad Mk2's in the garage that are still going strong in the PNW as our winter bikes.
    I just pulled out my Nomad and I'm swapping in some fresh parts to get it ready for the wet winter season.
    - new SLX brakes
    - upgrading rotors to 203/180 from 185/160
    - new SLX rear dérailleur
    - new chain
    - new Conti Trail King 2.4" rear tire
    - servicing suspension at both ends
    I keep telling myself that when I wear this bike out I can have a new ride, but I can't seem to kill it. All the main components are going strong since I bought it in 2009. It's still quiet and no issues with the suspension at all.
    I need to inspect the GF's Nomad and see what it needs before winter riding starts.
    Soi far I know I need to:
    - service the suspension at both ends
    - new Conti TK 2.4" rear tire
    - new brake pads
    - check chain wear and maybe replace
    Who is still riding the MK2 Nomad? Post up something and let's keep this thread alive.
    Safe riding,
    Vik
    www.vikapproved.com
  24. #1274
    Dec 2010
    Still going strong for me!
    Lets see those new Nomad Mk2's-dscf4436.jpgLets see those new Nomad Mk2's-dscf4437.jpg
    Updated to 11 speed recently and M8000 brakes on the way as I'm planning to do the epic trail in Mt Buller, Australia in November. So I figured some component refresh would be good.
  25. #1275
    Slower But Faster
    Reputation: BrentD's Avatar
    Still rocking my Nomad 2C. Picture taken on Tunnel Vision at Whistler in July this year. I'd love a Nomad 3 or Bronson 2 but still very happy with my current ride.
Follow MTBR on Facebook
