• 11-20-2012
    pipes10
    This guy has a set of red Opium rims laced to a 135mm hub. Again, contact CB as I'm pretty sure you can custom build wheelsets (ie: iodine rims on 150mm, Opium rims on 135mm, etc...). You can also try contacting the guy in the link.
    none at none in Kelowna, British Columbia, Canada - photo by ugottabjoking - Pinkbike
  • 11-20-2012
    boost
    That's exactly what I'm aiming for. Thanks pipes :thumbsup:
    I'll see how I can manage to order or have this done from where I am (Hong Kong) but I'm sure there's a Crank Bros distributor here.
  • 01-27-2013
    tp806
    3 Attachment(s)
    Thread bumpage:
    '09 SC Nomad Mk2 alu: best AM/Enduro bike by far still going strong!!! :thumbsup:
    2013 Iteration:
  • 01-27-2013
    saddle pimp
    Love this bike my do it all...
  • 01-29-2013
    atamayo
    mk2
    my other bike
  • 02-24-2013
    vikb
    Overhauled my Nomad this past year:
    - new front triangle [went from XL to L]
    - painted rear triangle to match [sort of!]
    - Velocity P35 rims + Hope Pro II hubs
    - Conti Trail King 2.4" setup tubeless
    - Shimano Zee 10spd with 11-36 cassette + new SRAM chain
    - fresh RaceFace 32T ring + MRP GS SL guide
    - Kona Wah Wah pedals
    - Selle Anatomica saddle
    - Spank bars
    - had Avalanche tune my Fox DHX Air 5.0
    - installed SC Pro Pack in VPP
    My bike feels new! :thumbsup:
    How she looked when new.
  • 02-24-2013
    vikb
    We pimped out my GF's Nomad as well - mostly the Velocity P35 rims on her stock hubs + Conti Trail King tires in 2.4".... :thumbsup:
  • 03-07-2013
    jamminadi
    I installed the eThirteen TRS dual chain guide on my Nomad. Whenever I am in the large chainring and a lower gear in the rear and back peddle the chain will want to slide over on the pulley wheel, then drop to the smaller chain ring. How can I stop this, it's quite annoying? I have the pulley as far forward as it can be slid (32 tooth chain ring) and I have the chain guide rotated as far clockwise. Any thoughts?
  • 03-11-2013
    robin_hood
    anyone know if you can swap the rear triangle from a 2010 to the new 142x12 rear triangle?
  • 03-12-2013
    Znarf
    Man vikb your bikes are fantastic.
    Great colors!
    The GF will be happy!
    Greetings Znarf
  • 03-14-2013
    Fparra
    nice bikes all of them!!!!...
    are some one interested in selling your frame???... I have a Talas 32 - 1.5in ST - 150mm Travel -15mm TA to use... Im between small and medium size...
    best regards...
  • 03-16-2013
    vikb
    Great colors!
    Greetings Znarf
    Thanks! The GF's turned out super nice. She's stoked. We'll be taking both bikes to Sedona AZ to get 'em dusty! :):thumbsup:
  • 03-20-2013
    robin_hood
    Attachment 782906 New to me 2010, loving it so far.
  • 03-21-2013
    saddle pimp
    I'm planning to use a TALAS RC2 180 mm. Will this be a huge improvement with my Float 36 160 mm??? Or can I get 180 float instead? any feedback for those who have tried it is much appreciated...
  • 03-21-2013
    bullit43
    No it wont be a huge improvement ( or even a improvement),Talas is know for having more stiction than a Float,you wil gain in travel but loose in front tire grip and spolied your geometry.Keep your money and spend it elsewhere.
  • 03-21-2013
    saddle pimp
    thanks for the reply... how about an angle set? what's the stock HA on a 160 mm Fox Float? How much will I add? .5, 1, 2?
  • 03-21-2013
    sir_crackien
    I'm not sure how you are using your bike but I am acutally lowering my fork on my nomad tonight from 170mm to 160mm to actually have a steeper headangle because I have been having a fair amount of front tire slip. if you have to climb alot of your rides don't make the front end of your bike too tall or slack. it will really kill your climbing performance.
  • 03-21-2013
    pipes10
    If memory serves me correct, the HA with a 160mm Float and a CC XXII bottom cup (stack of about 10-12mm) is 66.5*. I'm running an Angleset to slack it out by a degree and its at 65.4*. I'm really not noticing much hindrance when it comes to climbing but it feels amazing on the descents.
  • 03-21-2013
    saddle pimp
    will try it out, i have a cane creek angle set lying around, still haven't got the chance to swap it out. I'll start with 1 degree then check if there is any noticeable change...
  • 03-22-2013
    mehukatti
    In my opinion, -1 Angleset is pretty much a must for Nomad. The default 67 HA is outdated for a bike in this category and makes the bike feel like xc/trail bike. Angleset makes it like a modern AM/Enduro bike, and is much more confidence inspiring on downhills.
  • 03-23-2013
    saddle pimp
    a slacker angle would be the answer then? this would be my first time to play around with angle head sets so any advice with this set up is much appreciated. thanks guys!!!
  • 04-06-2013
    cman8
    bought and built this nomad in january. finally got to ride it as the snow has melted. Let me tell you the CCDB air is awesome. Wish i could afford one for my other bike. KS LEV on the way
  • 09-22-2015
    vikb
    I can't believe there haven't been any new posts in this thread since 2013!! :eekster::skep:
    We've got 2 Nomad Mk2's in the garage that are still going strong in the PNW as our winter bikes. :thumbsup:
    I just pulled out my Nomad and I'm swapping in some fresh parts to get it ready for the wet winter season.
    - new SLX brakes
    - upgrading rotors to 203/180 from 185/160
    - new SLX rear dérailleur
    - new chain
    - new Conti Trail King 2.4" rear tire
    - servicing suspension at both ends
    I keep telling myself that when I wear this bike out I can have a new ride, but I can't seem to kill it. All the main components are going strong since I bought it in 2009. It's still quiet and no issues with the suspension at all.
    I need to inspect the GF's Nomad and see what it needs before winter riding starts.
    Soi far I know I need to:
    - service the suspension at both ends
    - new Conti TK 2.4" rear tire
    - new brake pads
    - check chain wear and maybe replace
    Who is still riding the MK2 Nomad? Post up something and let's keep this thread alive. :p
  • 09-22-2015
    bumblebeezack
    3 Attachment(s)
    Attachment 1017293
    Still going strong for me!
    Attachment 1017295Attachment 1017296
    Updated to 11 speed recently and M8000 brakes on the way as I'm planning to do the epic trail in Mt Buller, Australia in November. So I figured some component refresh would be good.
  • 09-23-2015
    BrentD
    Still rocking my Nomad 2C. Picture taken on Tunnel Vision at Whistler in July this year. I'd love a Nomad 3 or Bronson 2 but still very happy with my current ride.
    Attachment 1017399
  • 11-30-2015
    vikb
    So little Nomad Mk2 love on MTBR these days. :(
    I busted my Nomad out as it's winter here in the BC version of the PNWet. Decided to add a bit of fender action to keep my butt dry and protect the expensive bits of the bike from the constant stream of gritty water and mud that is our local trail riding for the next 5 months.
    https://vikapprovedblog.wordpress.co...ing-the-nomad/
    The Nomad still rides amazingly well and holds it's own against bikes that are 7yrs younger than this 2009 model. :thumbsup:
    If you are still rocking a MK2 post up a photo. :cool:
  • 12-01-2015
    saddle pimp
    I agree... mostly are rocking the latest Nomads... still rocking mine...Went COIL front and back... might install a PUSH linkage soon... still in the fence though...
    Attachment 1032737
  • 12-01-2015
    vikb
    I've got a Pivot Mach 6 as my summer bike and ride the Nomad in the winter. I got my rear shocked tuned by Avalanche and it's 1000% better. :thumbsup:
    My only real compliant with the bike is that it's heavy compared to the new carbon wonder bike. I get tempted to tear it down and rebuild it with bling parts, but then I get cheap and figure heavy is better in the winter for training purposes and really do I want to trash a fancy bike in our PNWet slop-fest? :eekster::confused:
    You've got a nice looking rig there. :cool:
  • 12-03-2015
    BrentD
    Here's mine, 2011 Nomad 2 Carbon, all coil at 31.5 lbs still rides great though the Bronson 2 looks very nice and could easily figure in future plans.
    Attachment 1033286
  • 12-03-2015
    EnglishGent
    Here's mine [emoji3]
  • 12-04-2015
    vikb
    Great to see the MK2's being posted. Looks like some sweet rides.
    I figure in 2019.....10yr after she was made I'll take my MK2 down to Santa Cruz to shred and roll it into the mothership for a visit. ;)
  • 12-28-2015
    b2xtreme
    Another Nomad 2...
    Drive side photo might have been more interesting.. x0 crank, x9 type 2 rear.
    Thinking of upgrading the rear shock... anybody experience with the Debonair?
    Works 1.5 angleset waiting to be installed...
    Attachment 1038537
  • 02-19-2016
    vikb
    Got out for a nice late afternoon ride yesterday. Rode until it was getting hard to see in the forest without lights and then cruised back to my car. :)
    Nomad Mk2 is such an amazing bike. Buying it was one of the best decisions I've made in my riding career and one a smiles/$$ basis it is way out in front of any other bike I have owned. :thumbsup:
  • 07-02-2016
    thedrizzle
    Bit of a grave dig but....
    My new (to me) Nomad C.
    Fox dhx rc4 w/ ti spring and push link.
    Fox 36 talas 180 -160.
    Easton haven carbon wheels.
    Ks lev 150 dropper.
    X9 10sp drivetrain.
    Zee brakes.
    Zee cranks.
  • 07-02-2016
    vikb
    Nomad Mk2 [red] and Nomad Mk1 on ground [gunmetal] ^^^ working our way around the trails clearing trees after a storm.
    It's a worthy thread to keep digging up. ;)
    My buddy upgraded to a new bike and gave his Nomad Mk2 to his son...a year later he's on pinkbike looking to buy a used one for himself as he really misses it. :cool:
  • 10-31-2016
    vikb
    Got the Nomad out for the winter season here in the PNWet. At ~8lbs heavier than my summer bike it's a workout rolling this beast around, but she rides great and is a lot of fun. :thumbsup:
    Was on a ride yesterday with two buddies on the latest bigger wheeled carbon wunder bikes. This obsolete Nomad cleaned more climbs and lead the pack on many of the descents. ;)
  • 11-21-2016
    vikb
    The Nomad taking a break mid-ride yesterday. :cool:
  • 11-21-2016
    vikb
    Attachment 1017399
    Nice. Keep riding the Mk2 and get a Nomad Mk7 when they come out with hover jets! ;)
  • 11-21-2016
    vikb
    Not the bike's fault there are chubby middle aged folks spoiling the photo. :nono:
  • 11-22-2016
    BrentD
    Great suggestion! Recently back from a week in Queenstown, NZ on mine and couldn't have been happier with the bike. It's already booked for its third trip to Whistler next year, such a great bike for the Sea to Sky corridor.
  • 11-22-2016
    vikb
    I'm going to try and jam a 26" x 2.75" Surly Dirt Wizard into the rear of my Nomad. I think it can swallow 26+.
    I'm just on the other side of the Strait of Georgia from Whistler. Wave when you get there. ;)
  • 12-09-2016
    vikb
    We got a rare dump of snow here on Vancouver Island so I got the Nomad out and we shredded the trails.
    I sold my fatbike after moving to the coast. My 2.4" Trail Kings were more than enough rubber for today's conditions. I got up and down 95% of what I normally ride.
    Despite a lot of sticky snow hanging off the bike it pedalled, shifted and braked just fine.
    Because it was a weekday and snow riding isn't a thing around here I got first tracks on most of the trails.
    It's supposed to dump another 10cm+ tonight. I might get out early tomorrow so I can beat the weekenders and score some more fresh tracks. :thumbsup:
  • 02-05-2017
    vikb
    We don't get many significant snowfalls on the south end of Vancouver Island so when things got white this weekend I made sure to get out for a ride. Once again 2.4" tires were more than enough to cruise the trails. :thumbsup:
    I suspect that will be the last snow my Nomad sees this winter. :cool:
